Hello,
A mates 2004 350GT 6MT was experiencing rough idle and stalling at cold startup. Using the Nissan Datascan software, no codes were found and it looked like a dirty throttle body.
Cleaned the throttle body (TB left connected to the harness) and assembled all back together. Performed the Accelerator Released, Throttle Valve Closed and the Idle Air Volume learning (turn key and accelerator pedal methods) and when the car is started, it idles at 725rpm. Turn the key off restart it and it will idle at 900rpm.
Reading the codes, comes up with no errors. The Idle Relearn option in the Datascan software continuously fails unless the "clear self learn" is performed first but still won't stick.
Scouring G35driver has come up with some ideas but none have been successful.
Before booking it into Nissan to perform the learning, does anyone have any ideas?
Thanks
Firstly the 'clear self learn' is only for the long term fuel trim figures, it doesn't make any difference with the idle air volume learn, so it is unusal that this is making any difference.
Secondly, the accel pedal/key method to do the idle air learn requires exact timing. When you get it right, the RPM should drop down to about 400rpm, then climb to over 1000rpm before settling down at the right RPM, if you aren't seeing this happening, then it isn't actually doing an idle air relearn.
That said, the process via Nissan Datascan should work, so maybe check for other possible causes, like any new vacuum leaks, which might be what was causing your orignal issues.
I'm not sure why the Nissan Datascan is failing to set the Idle Relearn. It works fine on my 300GT so it maybe something with my ODB2 adaptor
When I do the accel pedal/key method, I'm getting the correct flashing lights etc. All of the pre-requisites (battery voltage, electrical load off etc) have been checked.
Do you get the all the right learning responses if any of the pre-requisites are not met?
Thanks
I don't think the pre-requisites (throttle closed/pedal), will prevent the process running, just mean it might not set it correctly.
As scotty mentioned, there is likely another fault which needs to be resolved before it will work.
As a test I tried different timings; 4 secs instead of 3, 10 secs instead of 7 and the MIL light still flashed as it usually does. So it looks like there is no real indicator to whether you get it right or not.
However, after doing the idle relearn, the idle will sit at ~700rpm until it is turned off. I wouldn't expect it to do that if my timing was off.
Putting the ECU in diagnostic mode, it has 10 slow flashes followed by 10 fast flashes then repeats (no codes detected?)
I've ordered a different OBD2 adaptor so see whether that works any better with the Nissan Datascan
The hassle is it isn't OBD2 protocol, no matter how many you try it most likely will never work. I have tested way too many readers over the years, and the Consult 3 is the only unit I can use for diagnostics and relearn procedures.
I have used the nissandatascan tool to do this process before and it works fine, but that was using the adaptor supplied from them.
Everything the nissandatascan tool is able to do works on my 05 with that adaptor.
It should be fairly obvious when the idle relearn actually runs, rpm drop quite low, then jump up over 1000rpm, then fluxuate a bit before settling down at the correct RPM. If you don't get the timing right with the manual method, you won't see this fluxuation.
I bought a new scan cable (A's Dev with FTDI chip) and it works perfectly on my 300GT. Tried on my mates 350GT, still no go.
We contacted Cockram Nissan here in Christchurch who first quoted $100 to put the consult machine on it but when a tech got involved, the price went to $300 and them needing the car for 2 hours. Their reason was they have seen this before with throttle body cleanings and they need to apply a "patch" to fix it.
Has anyone encountered this?
never heard of that before.. very common to need to do the idle air relearn after a TB clean, but never heard anything about a 'patch'.
Maybe try to get more details about it.
Sounds like bull crap to me. Even if it did need a patch it would only add 5 minutes to an already simple job. (as long as they had the patch file.) More likely they are trying to make some coin out of you incase the car is a headache.
I have sorted many M35's and V35's using consult 2, 3 and 3+, consult 3 is by far the best to use. Other than Nats there is no need to go to Nissan, many decent aftermarket scanners should work. (Snapon, Launch etc)
$150ph with a 2 hour minimum? I need to put my prices up. :/
    • I mean this in no disrespect to u mate; Are there clear tagged examples/explanations in our SAU forum for example, in my interest, this is how to do R34 Gtt suspension the right way? U guys did so much taking risks with experimentation that deserves recognition and those results helps us morons take the RIGHT path to buy quality / buy once. 🍻
    • Pretty much what you'd expect at that power level. Hypergear turbo, long list of supporting mods, full Haltech catalogue, etc.  I'd say this goes for most drivers, suspension is still a dark art for most people. And it's really hard to convince someone how much better their setup could be...
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
