When Are Traction Arms Needed?
ok just changed the rear cradle on a s2 rwd auto stagea to the narrower s14 cradle
i have adjustable camber arms in
toe is -15mm on both sides, i need longer toe arms
i was told that when i got adjustable toe arms to also get traction arms
car is not overly low
question is, do i really need to get traction arms?
was going to run a street set up from this:
http://www.nissansilvia.com/forums/index.php?showtopic=317341&view=findpost&p=4301102
ie:
Recommended Road Settings
Front
Caster = 7 degrees positive (slightly more on the LHS to counter the drift to the gutter)
Camber = 1.25 to 1.5 degrees negative
Toe = Zero
Rear
Camber = 0.75 to 1.25 degrees negative
Toe = In 2 mm each side
traction arms are always needed otherwise your car will crash to the ground. HA. HA.
adjustable ones help with reducing bump steer when you lower the car, so you need them if you have noticed a bump steer problem and want to spend some time on an alignment hoist dialling it out.
or, you could just chuck them in, adjust them to % of stock length based on how much you shortened the camber arm by and feel like it improved things like most people do
  • Like 1
What's 'not overly low' more specifically?
If you drop the car from standard heights to anything more decent it's probably lowered an inch or more, and you might want to change the traction arms too. eBay arms are <$100, you'll spend more than that in one proper alignment.
You can definitely run without, I did for years. Putting in adjustable traction arms did help with bump steer a little, however the main culprit turned out to be a busted shock on one side.
Sorry haha, was late and I obviously wasn't reading correctly.
I don't know how advantageous it would be running aftermarket traction arms in a street car. Personally I would but if you track it sometimes and are semi-serious about it, then it's probably worthwhile.
 Share
    • Much less twat-tastic. CF wheels are too garish for civilised use.
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
