Evening all,
I've had a look at the pin-out diagrams but I'm struggling! Would anyone know which pin on the RS Four S is the one that transmits the Throttle Position Sensor output to the ATTESA ECU? Basically I've got a Haltech Sprint 500 in the car now but I'm getting a TPS Circuit Error, and I'm buggered if I can work out which wire should be feeding the signal to the 4wd ecu!
Many thanks
Alex
Edited by Big Mac
https://www.sau.com.au/forums/topic/461410-need-some-ecu-pin-out-info-please/
It's been an error code kind of week :) have a search for "secret squirrel tweak" it has the details required.
BTW its likely your Air Con relay won't work either, the Stageas appears to trigger it differently to Skylines
Yeah I had to manually wire the A/C relay straight to the controls to get that working! Works OK although you don't get the ECU compensating by raising the idle rpm, but I can live with that. I'll have a look for the Secret Squirrel info now, thanks!
I didn't install my Link but I believe it was necesary to take a signal directly from the TPS.
ECU pinout attached if it helps
Pinouts WGC34_Series_1_-_STAGEA_RB25DET_Auto_ECU_ translated.xls
Pinouts R34_ecu.pdf
OK, have just had a read of that, now I have more questions lol
1) pin #37 on the original ECU send the TPS voltage to the ATTESA?
2) Does ATTESA require the correct TPS voltage/signal to operate correctly, or is it just a case of giving it the 3.7v as per Secret Squirrel trick? Or does this just fool it into thinking the throttle is part open the whole time?
3) If I just splice the signal from the TPS>ECU to the wire that was on pin #37 on the original ECU, would that then give the correct feed to the ATTESA?
Thanks again, much appreciated!
Here is some info from GTRUK - it may (or may not!) help you:
Asim is correct; the Attessa control module does require the RPM signal and an Earth to function properly. However these two items are shared within the factory ECU wiring loom and are not wired exclusively for the Attessa. The RPM signal (pin 7) drives the rev counter and TPS and engine temp sensor share the same earth output (pin 30). Therefore so long as the RPM and Earth is wired correctly to relevant pin location on the ECU they will by default be giving an output to the Attessa unit. The only exception to this rule is the TPS (+ve) signal which is not shared; the ECU takes the input from pin 38 and then feeds an output to the Attessa via pin 56. I’ve attached a copy of the diagram that I found on the net. I used the diagram to create an adaptor harness so that I could keep the factory loom intact and simply Plug n Play with my new ECU.
  • 4 weeks later...
Just a quick update to put this one to bed (and in case anyone has a similar issue!):
On the RS Four S it is indeed pin 37 that relays the TPS signal to the ATTESA ECU.
All sorted on my car now, thanks to all who replied for your help :)
Pity I didnt see this earlier. I guess its all working now? I went through a bit of a headache getting a standalone going on a s1 stagea.
ATTESA pin -> ECU pin - Description
Pin 3 -> Pin 5 - Tachometer signal
Pin 23 -> Pin 37 - TPS
Pin 34 -> Pin 43 - Sensor ground
  • 3 weeks later...
Yes mate all working like a champ now thanks! Turns out the chap who'd installed the TPS follower circuit had gotten two of the wires the wrong way round so no signal was being received; reversed this and now everything's hunky dory :)
    • Seemed to be good when Jeff owned it but they did a shit job on my car, probably worth a think before spending 10's of thousands of dollars where they might be cutting corners
    • Starting with issues 1 - 5, we have already run into a problem...!  Issue #4 contained 2x front brake calipers, instead of 1 caliper and 1x steering knuckle. Will have to call DeAgostini on Monday to sort it out. Anyway here's some photos.  Issue #1 is the front bumper, headlights and number plate. Issue #2 is the front wheel (with "We produced with spartan air." text on the centre cap!) and tyre, the front lip spoiler and cylinder head cover with ignition coils under the centre cover... which will never be seen again. Issue #3 is the bonnet and cylinder head. Issue #4 is the front strut, brake disc (with laser etched metal discs) and brake caliper. I stopped here because of the issue with the missing steering knuckle.  Next update will be #5 - #10 in a few weeks.
    • DeAgostini is one of a few companies that release quite large (the largest commonly available size actually) 1/8 scale models in a series of weekly issues over 100 - 110 instalments.  They release different models for different markets and DeAgostini Japan have release the BNR32 Skyline GT-R Nismo last month. I've made two of these 1/8 scale sized cars (one an R35 GT-R from 2012 - 2014, the other I'm just about halfway through, a BNR34 Skyline GT-R from the 2Fast 2Furious movie) so when this R32 was announced there was no way I could ignore it as it's my favourite out of all Nissans.  Each issue costs around $20 so it costs about $2.2K when completed. I suppose it is very expensive for what it is, but the quality and details are really very good, and there are many "gimmicks" like fully functioning exterior and interior lights operated with a remote control, working steering, all doors/bonnet/boot/fuel lid open and close, the side mirrors fold in and it even has a speaker for the engine revving sounds when you turn the lights on.  Each issue comes with a magazine that tells the story of the BNR32 Skyline GT-R Nismo from the first design stages of the BNR32 to Group A homologation and the various racing version that were run in the Japanese Group A and JGTC, and Australian Group A.  So I plan to update the build in this thread 5 issues at a time.  https://deagostini.jp/r32/?srsltid=AfmBOooKjxDc4EUK2rmXqMBPgyHfFJ24s4oEPJBNpnF-lFlsRoW0PE6P
    • As per title.. has anyone used so far? Keen to hear results, comparisons. In the market for a new mani for my new turbo. Any issues cracking?
    • Re read everything that has been written about this in this thread.. Let us know if you're still confused.
