GTR Boost Control
JayDee
 Share
I am wanting to slightly boost my R32 GTR to about 12psi with a bleed valve. What is the correct way to do this. I know that you can remove the restrictor in the boost solenoid line to get something like 1bar but I don't want to go quite that high(close to ceramic turbo limit). Can I put a bleed valve in the same line as the restrictor to get my approx 12psi and is this the correct way to do it?
I have done a search but found nothing on this issue other than to remove the restrictor totally. I want to get adjustment in between having the resitrictor and having no restrictor.
Removing the boost restrictor generally gives between 12-14psi.... i'm currently running 1bar (boost restrictor removed and bleed a little) on my stock R33 GTR turbos and have been for over 20,000kms
when you say "and bleed a little" in what line is your bleed valve located. Do you mean a T peice in the line that normally has the restrictor in it with a bleed valve going to the atmosphere???
Ok, so this tells me how to get boost level ABOVE that with the restrictor removed. Thanks for that but it hasn't answered my initial question. So referring to my original question, How do I get boost between that with the restrictor in and that with the restrictor out. I want it t be ADJUSTABLE(bleed valve) between standard boost and boost with no restrictor. There must be 1000 people who have done this, anybody???
Or tiny holes drilled in the vacum line :D
fit your bleed valve to the hose that usually has the restrictor in it.
 Share
