Hello everybody, this just happened to me today. So haven't visited my tuner yet. But hope maybe someone here knows whats wrong.
Was driving, and hit the gas hard on high boost. Around 6500rpm it felt like i hit a wall and both waste gates closed. Limped back home, car wasn't making any boost at all and wouldn't rev past 4000rpm.
- Oil pressure is normal
- Engine temp also normal
- No crazy sounds or smoke
- No oil leakage
Car spec: Full tune GTR R33
- N1 Block
- Greddy T517z turbo's
- Hks F-Con 3.24
- Greddy Ebc
- High boost 1.4 bar, 600HP
- list goes on for few pages more...
https://www.sau.com.au/forums/topic/461458-r33-gtr-boost-problem-help/
At a guess. Boost leak. Probably partially blown a cooler pipe off. You should probably inspect all piping and check all clamps as a start.
What he said.
You running stock piping?
How old are the turbos? K's etc... only asking as i had the same problem when the rear one on my 32 let go, worst case senario though.
I would start with cooler and vac hoses aswell, then move onto manifold and turbo gaskets...
Turbo's are less than 3000km's old. And its not really a leak because there is totally no boost being made, so some hose must have gone off completely.
If a cooler hose partially popped off that is exactly what would happen. All boost is leaking out before it gets to manifold. 2nd scenario for no boost would be gates stuck open but that isn't going to stop it from revving over 4k and eventually it will build boost. 3rd scenario busted turbos.
Check the piping if u can't see anything obvious take it to an expert to diagnose.
  • Like 1
So this all happened last night so went out today in the sun. My intercooler piping connecting to the intake manifold has completely gone off! Sadly can't put it back my self by force, so will have to go to my tuner. Point is how safe is it do drive like this, or should i tow it. Will be expensive but with a car worth €40.000 why not.
Lol i do, bot the piping must have moved. Can't cat it back to place, without getting the car on a lift and getting beneath! Believe me if i could get the pipe back by my delf i would do it!
You probably shouldn't own a GTR then lol:)
Don't have the tools you described, and sadly in Amsterdam our side roads are not straight. We don't have asfalt roads, the road is made out of small blocks. So jack stands would be very un safe. So a garage is needed.
You own a GTR and don't have a garage to put it in?
Thank the FSM I live in a place where we have plenty of room.
But just for clarity.....my driveway and parking area in front of my house and under my carport is paved with pattern pave concrete which is stamped with a cobblestone patter which is just as uneven as the cobblestones on your street. I still use chassis stands on that surface. I just use a piece of compressed fibre-cement sheet under the jackstand as a bigger spreader plate.
I have seen people working on cars in worse conditions than your city backstreet in places like Belarus, the sphincter of the universe, Israel, etc etc all the time. People make do with what they have. I would not own an old car like these without the tools necessary to do the bare minimum.
The sphincter of the universe is where exactly?
Imagine a bird that Americans eat at Thanksgiving and that we eat at Christmas. Now imagine a country of the same name that borders Greece, Bulgaria, Syria, Iraq, Iran and Armenia. That country and that bird, when typed into this forum, gets auto translated into "the sphincter of the universe". Ordinarily I think that's not quite quite fair, as there are other places in the list of borderng countries that are certainly a lot more sphincterish.....but anyway, at the moment I think it's fair enough and I wouldn't be too happy being in the southern part of that country like I was this time last year!
    • What could be causing my clutch problem besides a bad master or slave then? Both those parts are new
    • Just came across this, but in QLD I start leave again in 2 weeks, if it is still available I might drive up and check it out Unless, @MBS206 do you live near here????, if so I could hit you up with a finders fee https://www.gumtree.com.au/s-ad/hope-island/auto-body-parts/nc-mx5-factory-hard-top/1328976391
    • My hold point for future mods is that I want a OEM detachable hard top first, but, finding one is a pain, MX5 Mania are looking for one for me, but, as hens teeth are more common, finding one in Australia is proving problematic  I can get a OEM one from overseas, hell, you can still get new ones in 'Merica, but, shipping is a absolute killer and I cannot justify the cost, or the risk of it being damaged during transport As for the aftermarket hardtops, whilst they do the job of being a hard top, and are fine for a track car, they don't seal well (read: leak like a sieve in the rain), and you need a plastic/poly rear window, plus they are a bolt in option only and not made to be easily removed I liked how the hard top on my NB could be fitted, and removed, by myself, in less than 5 minutes I know it sounds bad, but I'm waiting for someone to write off a car with one so I can swoop in on their pain, it will go to a good home though, so my guilt of this is tempered
    • I’ve got one on mine and it’s fine,
    • No, you don't want to plug the vacuum line, as that will turn that side of the booster into an air spring and probably make it feel worse. I'm not saying that the GTR master itself doesn't need a booster. I haven't paid attention to the GTR one to know what size it is cf the non-GTR ones. But when you think about it - they have to do the same job, which is to move a little slave piston a few mm to do what it is supposed to do, and that final action is the same on all the cars. So, it is very unlikely that the GTR MC is any different than the others, because it has the same pedal stroke and the same output requirement. The booster just makes it feel easier. I'd suggest you probably have an actual hydraulic problem. It's totally common on these old shitboxes.
