For sale
R32 GTR factory air box and snorkel with K&N filter $100
R32 GTR engine fan $50
R32 GTR bonnet latch support $50
R32 GTR bonnet latch mechanism assy $50
R32 stereo surround $60 black smooth
R32 ash tray black smooth $20
R32 manual surround and boot smooth black $40
Or $100 all three
R32 twin core alloy radiator. 70mm end tanks, 58mm core comes with silicone hoses and mounts $120 (clears engine fan)
Rb26 twin turbo pipes and hose, polished excellent condition $80
OS Giken adjustable cam gears $200
Genuine drivers Recaro sr3 reclinable bucket seat on genuine bride rail $350 (has tear)
R32 GTR battery clamp $40
R32 passenger vent in mint condition $50
R32 drivers window switch assy $50
R32 gtr lower cluster surround, with clock (not working) $50
R32 GTR boot trim $100 with board carpet and all side pieces good condition no tears
R32 GTR centre gauges $40
R32 GTR a/c climate control module $50
R32 GTR ecu $70
R32/R33 GTR front drive shafts $100ea both available. Great cv's and boots
R32 GTR G senser good condition still white indicator $100
R32 heater vent servo motor $50ea both passenger and drivers side available
R32 GTR dash with mint demister vent. Slightest bubble near passenger vent. $50
R32 GTR kick panels $20ea side
R32 passenger window switch $30
R32 genuine Nissan floor mats great condition rubber underneath not cracked at all $40 (3 piece rear only)
Located Gold Coast can freight worldwide
0414596256
Text for more photos as I've maxed out what I can upload
  • Like 1
https://www.sau.com.au/forums/topic/461470-r32-gtr-part-out/
Climate control module is in perfect working condition. I have one left missing front fascia $40
I have a stock genuine steering wheel and horn $70 has wear around the outside
Message me on 0414596256 for photos
    • Can't you put the pistons to TDC and then do the valve seals? Or will the drop down too far to pull them back up?
    • One thing I can tell you is, do it properly the first time. If you encounter unexpected problems just let the car sit for a week or two if you have to get some other parts or figure stuff out.  I'd have said go and use as many OEM parts as possible but since you want to change the turbo later on a custom kit is probably the better choice. Since I have no experience with RB25 just compare parts diagrams and images before buying a line kit and it should be easy to see if it has everything you need. Amayama has very good parts diagrams and part number lists, that is what I used a bunch to figure out what I might need. And don't forget to plan ahead and possibly renew other stuff that's easy to get to while you're in there doing the turbo lines. Happy wrenching
    • Update 4:   Hi all, good news. Engine is running and all the gaskets and seals seem to be working as intended. No leaks so far, even the JB Weld seems to hold. I flushed out the old coolant a few times and put in fresh coolant, not Nissan stuff, I decided to try the Ravenol Protect FL22, they claim it works for a wide variety of JDM cars and the opinions on it by some people were pretty good. And it has the nice poison green color! And man am I glad I bought a coolant system tester earlier this year, vacuum filling works wonders on this engine. I can definitely recommend this to anyone still doing it the old school way. All you need is compressed air supply. Will have to do a small test drive as soon as I can, I removed the gauge cluster again as the tacho needle was still bouncing around a bit but it was much better than before already.  I also found some cracks on all 4 tires inner and outer sidewalls. Apparently these tires should 't be parked on for extended periods or be kept under 0 degrees during storage, which I did not know. Clearly the previous owner didn't look into those details either, he probably bought them just cause they are cool semi-slicks. I'm just wondering how tf I am supposed to reach 30-80 degree tire temperatures on the public road consistenly, these tires were never going to work for my use case. I'll probably order Continental SportContact7 ones as these are the best allround summer tire available right now and I don't think I'll need anything crazier for now. Do let me know if you have experience with various tires and which ones you recommend.
    • You have no idea how many goddamn boxes I received these past three months haha Most have been put to use by now though, luckily
    • Not going to pretend I didn't do a bit of junky work this time around, but mostly due to the fact that some things I am not willing to spend days fixing right now, like wiring. I try to do most things properly the first time around.
