Rb26 400hp Drop In Package And Triple Plate Clutch
Yeah, The Japanese had/have a problem with doing crap like that to undeserving shitboxen.
By TurboTapin · Posted
I run a CD009. See my DIY for info on what I spent. 6800$ isn't cheap, but it's not terrible either. Keep in mind, you'll still need the following parts. - Shifter relocation kit - Driveshaft - Slave Cylinder - Rear final drive (This doesn't have to be done right away.) - Some new way to detect speed. -
Yikes. That might do well in the Automotive Abominations thread!
Seems a reasonable price, some other things to consider, driveshaft & xmember, you'll need to run the speedo off the abs, an after market lever/bracket. You'll most likely want to change the diff ratio, do you need any kind of certification in the uk for it? If the car is quite low, the cd will hang down lower than the 25 box.
He said in the OP Wollongong area.
