Rb26 400hp Drop In Package And Triple Plate Clutch
Complete r32 rb26 engine with all accessories. Power steer pump, Ac pump and alternator. Engine has:
Long nose crank
N1 oil pump
Tomei adjustable cam gears
Tomei type a camshafts
Gates racing timing belt
Trust stainless manifold with external Tial wastegate 48mm
Sard 700cc injectors
High mount bush bearing turbo a/r 1.00 rear housing, 72mm rear wheel, 74mm front wheel, no shaft play at all has Braided lines
Awd sump and complete intake with plenum
Clear timing cover
Red wrinkle coated cam covers
Standard coil packs and harness
Included is the cooler piping from turbo to chassis pipe, dump pipe and catback exhaust to suit r32
All parts ready to drop in as a package. Engine compression tested 153-158psi across the board, has just been removed from a running/driving vehicle. Engine comes with warranty.
$6000
Exedy triple plate clutch, 3.92mm-3.92mm-4.04mm clutch disc thicknesses. Comes with throw out bearing in com good condition to suit, all only done a few thousand kms
$1000
Located Gold Coast can freight auswide
0414596256
post-44496-14492269009809_thumb.jpgpost-44496-14492269259507_thumb.jpgpost-44496-14492269460601_thumb.jpg
 Share
