What would you guys consider the basic mods that are like a must have for M35s? Coilovers, seats, exhaust, intake, wheels, brake cut mod, boost controller? Other stuff? Say you bought a standard one, what would be the first things you would be buying? Likewise, what do see as pointless or a waste? An example I think I read somewhere was a strut tower bars don't really work with M35s?
https://www.sau.com.au/forums/topic/461490-m35-mods/
As above. And the m35 exhaust is restrictive as hell, so dump and cat work helps. Also depending on ks, watch the stock turbo, they tend to starve n cook, so a highflo helped me.
They tend to run hot, so any additional cooling cant hurt longevity.
Also, have money,if no one mentioned that before u got one, start saving. They're a unique lux cruiser that are hard to fault after some coin. At least thats been my experience
https://www.sau.com.au/forums/topic/461490-m35-mods/#findComment-7648945
The stock sway bars are almost useless, and the bushes will probably be worn too.
SuperPro make some solid bars, huge improvement for $250 each.
For me, I like the comfortable stock suspension, though I've never driven one with BC's.
Careful choosing hardness if you do, it's a heavy car and the shock mounts rip out from fatigue.
https://www.sau.com.au/forums/topic/461490-m35-mods/#findComment-7648966
I have skimmed that thread and will read it in more detail but this was a little different (I thought) as I was looking specifically at the basic "must haves" not at anything and everything people have done.
https://www.sau.com.au/forums/topic/461490-m35-mods/#findComment-7649106
Hahaha, an Evo wagon would be ideal, quite pricey and rare though.
Haha, pretty sure you're not allowed to import them. Unless they're a personal import. Supposedly 4 in Australia according to a few ads.
(Don't take my word for it though).
https://www.sau.com.au/forums/topic/461490-m35-mods/#findComment-7649154
Pretty sure you are right on all accounts, I know 2 are in the country.
https://www.sau.com.au/forums/topic/461490-m35-mods/#findComment-7649186
I've only ever seen one. In the 2 ads i've seen over the last 6 months or so, both have stated that there are only 4 in the country.
Edited by Burger
https://www.sau.com.au/forums/topic/461490-m35-mods/#findComment-7649191
Before i got my M35 i pre ordered a few things. When i go it i installed Coilovers, HDi intercooler, cat back exhaust, Boost controller, and an ajustable BOV.
All of those combined made a huge difference, but after a day on the track the Stag showed a few weak spots. Overheating, no grip with current tyres and a lot of understeer.
I am now changed the direction which i was going and looking at improving cooling (Alloy radiator, trans cooler, oil cooler, thermo fans etc), after all that I'll be looking at bracing and sway bars and tyres obviously.
https://www.sau.com.au/forums/topic/461490-m35-mods/#findComment-7649473
    • Starting with issues 1 - 5, we have already run into a problem...!  Issue #4 contained 2x front brake calipers, instead of 1 caliper and 1x steering knuckle. Will have to call DeAgostini on Monday to sort it out. Anyway here's some photos.  Issue #1 is the front bumper, headlights and number plate. Issue #2 is the front wheel (with "We produced with spartan air." text on the centre cap!) and tyre, the front lip spoiler and cylinder head cover with ignition coils under the centre cover... which will never be seen again. Issue #3 is the bonnet and cylinder head. Issue #4 is the front strut, brake disc (with laser etched metal discs) and brake caliper. I stopped here because of the issue with the missing steering knuckle.  Next update will be #5 - #10 in a few weeks.
    • DeAgostini is one of a few companies that release quite large (the largest commonly available size actually) 1/8 scale models in a series of weekly issues over 100 - 110 instalments.  They release different models for different markets and DeAgostini Japan have release the BNR32 Skyline GT-R Nismo last month. I've made two of these 1/8 scale sized cars (one an R35 GT-R from 2012 - 2014, the other I'm just about halfway through, a BNR34 Skyline GT-R from the 2Fast 2Furious movie) so when this R32 was announced there was no way I could ignore it as it's my favourite out of all Nissans.  Each issue costs around $20 so it costs about $2.2K when completed. I suppose it is very expensive for what it is, but the quality and details are really very good, and there are many "gimmicks" like fully functioning exterior and interior lights operated with a remote control, working steering, all doors/bonnet/boot/fuel lid open and close, the side mirrors fold in and it even has a speaker for the engine revving sounds when you turn the lights on.  Each issue comes with a magazine that tells the story of the BNR32 Skyline GT-R Nismo from the first design stages of the BNR32 to Group A homologation and the various racing version that were run in the Japanese Group A and JGTC, and Australian Group A.  So I plan to update the build in this thread 5 issues at a time.  https://deagostini.jp/r32/?srsltid=AfmBOooKjxDc4EUK2rmXqMBPgyHfFJ24s4oEPJBNpnF-lFlsRoW0PE6P
    • As per title.. has anyone used so far? Keen to hear results, comparisons. In the market for a new mani for my new turbo. Any issues cracking?
    • Re read everything that has been written about this in this thread.. Let us know if you're still confused.
    • This would be a new pump with new gears. I'm just unclear on whether it's a good idea to run more oil pump flow if you don't actually need said flow. Oil level is set a minute or so after shutting off a warm engine so wouldn't the high RPM oil level in the sump end up lower all things equal? Plan is OEM clearances, main concern in my mind is whether the OEM pump can keep up with the flow requirements of any additional oil coolers.
