Car came with the HKS oil cooler kit, which includes a thermostatically controlled sandwich plate on the block.
I've just done an oil change and it sucks and is messy so I'd like to add a relocator.
What's the easiest way for me to do this and retain the thermostat control to the cooler core?
I thought about buying a basic relocator and attaching the the block side on top of the existing sandwich plate, any issues with that?
Something like this - http://www.rhdjapan.com/trust-greddy-grex-oil-filter-relocation-kit-nissan.html
Edited by ActionDan
Still going to be messy, even if you relocate it.
you need missing pieces from this kit
http://www.rhdjapan.com/trust-greddy-oil-cooler-filter-relocation-kit-r32-r33-r34-y33.html
Look at the illustration image to get an idea of what you will need to achieve. Top image shows what you need to do with a sandwich plate, bottom image is without and a inline thermostat instead.
I say just leave it. Surely its not that much of an issue to just degrease in there? unless you will be replacing the filter every month.
You're directly connected to this forum aren't you... it's all just lines of code in your brain... you're everywhere.
Anyway, I know what I need from that kit, but as that would be next to impossible to get (as bits) I considered just getting a generic relocator and bolting on top of sandwich plate.
And to be fair, probably only need one oil change a year, time based rather than Ks, but the mess 0_0
stacking them is completely fine.. I am going to do the same thing (one day) when I am bothered..
below pic is great, shows it fits without hitting naything
  • Like 1
I'm not back near the car until the weekend, I'll get some pics then.
I've got a relocator on the block, a separate earls thermostat (with pressure and temp senders) and a large cooler where the AC condenser was.
812ta3bDrvL._SL256_.jpg.
Even in a race/rally car it ran too cool at times for me, particularly when driving to events or between stages. And the setup help temps well even on 30klm stages at 40o at Targa High Country last year.
I previously had the filter upside down in front of the sump and the cooler in the PS wheel well but there isn't a lot of room there for a large cooler and I wanted the thermostat, so I redesigned.
I also have a hks cooler kit and i used a greddy relocation, replaced the barb fittings that come with greddy kit and got fittings to allow the hks lines to be used as well
the oil filter is on a simple bracket of right angle 3mm steel (because I hate filter mounts that twist when you try and remove them). countersunk stainless bolts into the filter mount on one side and into 3 thread inserts on the car side. Nice and solid.
the stagea mount is just to give a little clearance between oil lines and the engine, I think most people just do it rb30 style and bolt the relocator straight to the block which also works fine.
    • Yeah the issue here is that we have a lot of topics, unless we matched on the exact word & phrase we'd get a million topics and the one you want will not likely be in the top 20 or so.
    • Yeah great idea, I have already added R32 Wiring Diagram but we can add as many as we want. 100% ! This has been something I've wanted to do for a while. I thought we could have a way for people to 'suggest' a link be added to the library when they come across something good.  We could kick this along by allowing members (maybe a subset) to tag threads they find to allow us to more easily find/locate/use good content, ie a tag 'for-library' which can then be added to the library and maybe have the tags reviewed and updated to better match the content. This would make it easier then to find the content when not using the library. We can also create pages that have lists of content with specific tags. That would allow us to add a tag and then have it automatically added to a page. We could have a page just for the 'for-library' content that we could then moderate and put wherever.  This excites me, the lack of structure with the amount of content is a little overwhelming.
    • Of course you can. That was a waste. Straight down one oil drain gallery and out the sump hole. Could at least have run the engine a little (obviously with at least minimum oil level on the stick).
    • Oh really? Maybe I'm being silly. I'll get some more shots. I had it higher but found that it went too high after a drive, I never knew this but exhausts can move around a bit when hot (makes sense, just never knew) and when it was higher it would make nice cooking plastic smells. That said, I could put some heat tape on a'la 90's R33 exhausts     Ha, I've spent a lot of my life in castle hill waiting for cars to be done. I think I'd prefer something closer but thanks D.
    • @Duncan Yes, changed filter every time. I don't have the service manual for the car yet (Car was imported and they removed everything when importing). I've been using the oil change threads in the forum as reference.   @Milkmun The second oil change was after ~4 months after the first months and I wasn't sure about reusing engine oil that was opened. The third oil change happened within 3 weeks of the second oil change and I used the previous leftover oil to just "clean up" the system. (Poured it through while the sump plug was open")
