was it overboosting?
Went over to my cousins house the othe night for a few drinks and we ended up looking in my engin bay. He noticed that the boost controller was plumbed back on itself. Was my car overboosting, and if so wouldnt the turbo have shit itself from 18 months of overboosting
Cheers Jon
ps can someone tell me how to put photos in I have taken 2 to show what is going on :D
It sounds like the waste gate is still connected to the plenum line, so in effect the solenoid carn't bleed off any eccess leving u with less boost if anything.
? for u getting a car from WA & want to register it in NSW are your compliance rules the same, do u have a australian compliance plate?
When we changed the plumbing the turbo doesnt spool up as much, the car seems to have more grunt and the power comes on much harder and smoother.No I dont have a boost gauge because I thought that I was running stock boost soI didnt feel the need for one. Silly me:)
The way it was set up was ok. The boost solenoid (that was bypassed) allows the boost to jump from 5-7 psi above approx 4800 rpm. If it is set up the way it was u will not have the 2 stage boost. In otherwords u will get 7 psi from as low as 3000rpm. Its up to u how u set it up, I would go back to how it was.
The way its set up in the before picture is no good as u thought as it will over boost but from memery the size of that tubing will only give u approximatly 14psi thats why it wasn't hitting the boost cut. the after picture is ok but will only give u 7 or 8psi like Damo said. If u ask me ur better off bleeding a bit off to give u 10psi. Won't give u the bottom end punch of 14 but will increase life of engine and turbo and give u almost the same top end if its a pre 95 model.
P.S. my quickest time of 13.8 was done on 10 psi :flamed:
the series 1 and 2 have boost cut at 12psi and more.
Without that little nissan boost controller colenoid connected you would only be running 5 psi.
The nissan one bleeds of a little, and runs the car at 7 psi after around the 4500rpm mark.
 Share
    • Because there is still an engine underneath that turbo. PSI is not a measurement of power, it's a byproduct of resistance. What would be really decent is to have a CFM gauge on the output of a turbo to see how much it's actually pushing. 21psi (as an example) is not the same amount of air at 3000rpm as it is at 7000rpm, even if the boost controller is controlling boost at "21psi". The engine is inhaling and exhaling way more air at 7000 than at 3000, even if it's less efficient.
    • don't want anything more or less, I don't really understand why the torque still goes up to 6000-6500, while the boost peak is around 4000. if it only comes from the cams or from the boost controller etc.
    • I'm not sure you understand the physics of what you are asking. Can you draw on the dyno graph what you want to have happen? I'm thinking this is a functional impossibility here, unless you chose a turbo literally so laggy that torque is at max at 7000rpm and artificially choked prior to that. Power and Torque are intrinsically linked. Power is just Torque over time. What you're really seeing in the torque graph is "Power per RPM" if that makes any sense whatsoever. You still get more power at 7000rpm than 5000rpm, because it is "power per RPM" and you have more RPM. at 7000 than you do at 5000. You still feel more powerful at 7000rpm. The torque graph will influence the rate of power increase per RPM.
    • Welcome!  If possible,  would live to see some pics. How long was it away getting the work done? Hopefully it feels like a new machine.
    • yes indeed the graphic format makes a visual difference but there is on average 120nm more between 4000 and 6000rpm on the curves it is not nothing. you are right, the cams influence the torque curve. I was able to chat with one of the Hypergear tuners, he confirmed that a boost control allows you to manage the pressure after the spool. the absolute pressure (psi) on the graphics is measured where? It seems that the cams affect the maximum pressure depending on the regime but I may be wrong.   not pleasant to drive before 4000? if we spend our lives between 1000 and 3000 rpm as you say then we might as well just run diesel turbos
