Hi guys, who in Sydney does the conversion from Jap to English for the screen display in dash? I read a huge thread and it seemed like Jetwreck does it, I've PM'd him but haven't got a reply (maybe he's busy IDK). Is there anyone else that people know of that do these regularly?
Thanks in advance.
https://www.sau.com.au/forums/topic/461553-jap-to-english-conversion/
Can any authority on this subject create a DIY thread with all info? Would be awesome if we could just direct people to a single thread with an easy-to-read list of contacts and Q&A's.
Pretty please?
PM either Andy (Andy65b) or Craig (Jetwreck).
I don't know if they are still doing them, but may be able to point you in the right direction.
Original thread was in the V35 section: http://www.sau.com.au/forums/topic/194126-software/page-2
  • Like 1
I can pretty much decipher most of it between pictures and a translate app it's just annoying and I like stuff to work properly lol.
On a side note it's got the standard CD player under the standard gauges in the centre, it won't tune to above 90, will a new head deck fix this or is the aerial/antenna an issue too?
for FM, i think you just need a FM extender
http://www.ebay.com.au/itm/Nissan-Skyline-V35-Stagea-M35-Elgrand-E51-FM-Band-Expander-18-MHz-FM-Converter-/252197779040?hash=item3ab828b660:g:2Y8AAOSwBLlVHQKm
also if you want a aftermarket CD player, you need to make sure you don't have BOSE system dash, otherwise, you need to trim it or change to like this:
You like it now.... give it a year and when you have a double din you wont ever use it.... noobies
a couple of days in my case drove from launie to hobart keeping eye on economy. Then realised it likes fuel so just look at fuel gauge now, however my son does like it
Haha probably. But at the moment I'd like to keep the stock gauges in the dash so no room for double din
Jetwreck no longer does conversions, and from what he told me; whoever does them now charges an arm & a leg.
It's really nothing but novelty value; you won't even look at it in 6 months.
Fwiw, band expanders are a pita; the numbers on the screen don't reflect the actual station, and it drove me mad in about a week. Pull out the Jap head unit and replace it with something that does the job properly with stations you can actually tune.
Ahhh yes thats the exact answer I was after! So the issue is with the head deck not the antenna/aerial. Cool
    • Ha ha, yeah, I've had one following me around in my parts boxes since about 2007 I believe. Just a little iddy bit hole drilled in the one I have to let it vent out once pressure was removed from the engine side. Still no idea what I'd put it on, ha ha.
    • Just read this... Just a little bit of a wild one! Do you think the driver was testing out a new feature/device for how to lose the cops in a high speed chase?   I also suspect, if the box has a road sweeper that does magnetic metal pick up, he does a LOT of work in the machining industry. Which is what most of that looked like, machining chips from a mill or lathe. And I bet they're RAZOR sharp! And from an environmental perspective they really do need to actually collect all of those little pieces too. I wonder how many people still cop flat tires over the coming months on that road?   As for insurance company, yeah, it'd be interesting to hear what they say to the owner. But realistically, he's right, that "It's his fault". In the way that, it was his truck that spilled it, so they need to clean it up. However, neither he, nor his insurance company may bear the end cost if they do an investigation and find out it was caused by someone elses negligence (And they know who)...
    • Yeah, no matter what bad things people can say about Julian from Autospeed, he at least was capable of thinking and his inclusion of a check/relief valve in the plumbing for the Audi boost controller, that I made a copy of and used for years**, completely eradicated that problem. **It's still lying on my workbench where I put it about, um, 18 years ago and have never found a home for it!
    • I didn't actually know this! I've seen photos of the H1, mainly outside shots, and they just look "different". I guess there'd be a few little changes like nicer rims, and probably the fact they have nicer looking paint with some depth and shine, which will make any vehicles body look different to the very flat colours of the defence force.   I've watched the guys on GHPC convert their Humvee to LS1, and they've done some really nice front shock upgrade. I'm waiting for the next video on it with the rear end done. I can't remember if they've already done it, or I dreamed it, but I believe they're also supercharging theres. They will be in the future doing proper long travel suspension too.   If you ditch out your big V8, as rubbish as it must be, send it to my place. I'll let the unreliable V8 motor and box be here. I just like V8s... So I'll find something to do with it... Even if that something is just taking up valuable space in the yard. I might have something Skyline I can send back in payment... Or even Ford Barra motors  (From memory you're in Canada yeah?) So you can then play with the legendary Aussie 4L version of an RB...  Except they don't have that distinctive random miss at idle like the RB25 does.
    • Or you mean the age old problem of early 2000's manual boost tees, where they never let the pressure out of the line between the boost tee, and the waste gate, so after your first trip on boost, the damn wastegate liked to stay open and be laggy on gear change?
