I assume you have the standard 320mm brakes Nick?
I do indeed mate... With the twin piston calipers. Not like the 350GT Sedan which came with a 330mm disc, but only single piston calipers.
  • 4 weeks later...
  • 2 months later...
What parts? Discs? Pads? Both?
You didn't take a wheel off and take some measurements to double check? I always do that on the first purchase when it's something that's not as commonplace as a Fa(i)lcon or Bomb-o-dore.
If there's one thing I learned as a student from my first boss in the broadcast business, it was "measure twice, cut once". Now you've learned the same.
You are right. The 330mm discs were for the older beasts whereas the 2009 sedan got the 320mm instead. The only theory why I suspect 330mm might still be an indicator is because in the US, the base model coupe had the larger 330mm discs in their 2009 model but the sedan still got the 320mm. That's not to say that their years lined up with the JDM spec though. Unless I got the wrong information, I found that my 2009 model, though built in Dec 2008, was released as a 2010 model in the US.
Problem is, I'm trying to look up the current DBA catalogue for further confirmation of numbers but they've severely trimmed down the Infiniti options and there's not as much detail as there used to be. It only lists the sports package, which is 355mm front and 350mm rear - that's what I have on my coupe.
It's odd, given that DBA still list discs for the G35/V35 but cut down the G37/V36 to just the sports package size in their catalogue. Curious stuff.
Edited by The Max
Well I assumed they are 320mm as ordered... will double check tonight. Mechanic didn't say; just said they don't fit.
Clearly I put too much faith in people who I assume should know this stuff. To be fair I guess they're a hard car to get parts for.
So frustrating
So frustrating
Ask him to measure that the disc rotor on the car so you know what to buy next.
It's just a matter of doing the homework. I've given up on trying to track down the older DBA catalogues I thought I had on file. Here's what I've found in the 2010 G37 Sedan workshop manual http://www.nicoclub.com/FSM/G37/Sedan/2010/BR.pdf (Nov 2009 revision of the manual itself):
  • Front Caliper 2 Piston and Rear Caliper 1 Piston type:
    • Front rotor outer diameter - 320mm x 28mm
    • Rear rotor outer diameter - 308mm x 16mm
  • Front Caliper 4 Piston and Rear Caliper 2 Piston type (in other words, the sports model):
    • Front rotor outer diameter - 355 x 32mm
    • Rear rotor outer diameter - 350 x 20mm
Again, it's worth taking the time to take a wheel off and measure it for yourself to confirm or get your mechanic to measure it up for you while he's at it but it's safe to say that if your mechanic said they don't fit, the discs you got in were too big.
Edited by The Max
Screw that! I've always been a firm believer in people helping themselves and if they do end up slipping in their own shit, then I'll step in to help out, knowing that they tried.
This is why, I might be a search-Nazi when people ask the same question over and over again but I do practise what I preach.
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
    • Don't worry about. Just don't try to drive hard enough to make boost and you'll be fine.
    • Yes. This has already been said. It is a loop of hardline in front of the radiator. Because.... the pump is on the LHS and the steering rack hydraulic connections are where they always are on a RHD steering rack....on the RHS. The high pressure line goes down under the engine, along the crossmember, like it does on all Skylines. Don't just throw expensive braided hoses/other kits at it. Work out what is wrong and fix that.
    • Still got the afm on the intake, clamps are shut tight, only loose hose is the one that goes from the j pipe towards the IACV, since it's next to impossible to find a factory hose and the barbs are different sizes (I'm still using clamps on this hose to try and help it seal on the iacv side) I've ordered parts to make up the hotside of the intercooler pipes, I'll plumb it in and see what happens in a few days I suppose The turbo's internally gated, can I just unscrew the tension rod to let the gate open?
    • Did this ever go further ? Would love some updated info
