Hi,
I have two AB FLUG front diffusers here to suit R32 GTR.
Im not using these anymore due to my driveway.
Ones been test fitted the others brand new in packaging.
Chasing what i paid. $445 each
Text me on 0422216160 if interested.
Cheers.
  • Like 1
https://www.sau.com.au/forums/topic/461560-r32-gtr-ab-flug-front-diffuser/
  • 3 weeks later...
  • 2 months later...
  • 4 weeks later...
  On 22/04/2016 at 11:35 AM, dmac_25 said:
Also how did your pickup fit on the high octane sump?
Its a RB30 bottom end, had to adjust it a few times to get it on the money where i wanted it.
Should be some pics in my photo galley of the way it sat and the adjustments we made.
    • Hi, is the HKS  Tower Bar still available ? negotiable ? 馃
