Item: R33 GTR Nismo intercooler (part number14461-RS580) 270 x 600 x 100 core.
Price: $1,800
Condition: Second hand but very good condition. Was on the car for roughly 10,000 kms
Payment: Direct debit to my account, Or cash on pickup (if in Sydney)
*Pics of cooler are coming. I just need a chance to take some.
Item: Bosch EV14 2225 cc injectors (set of 6)
Price: $500
Condition: Flowed up fine. Needs baskets if you want to run them ($6 each). In the car for roughly 5,000 kms at a guess
5BBD9D0F-04D3-466C-8AE8-145818AC7BC0_zps
Item: Garrett – 5 turbos.
Price: $1700
Condition: Used for 10,000 kms. Going single so no need to them anymore.
These have had the turbine housings ported out to match the gasket, rear housings have been ceramic coated and Ive had the actuators modified by Racepace. This increases the leverage on the arm. Currently set to 19psi but have had them at 24.
449FE644-C725-452A-A4CD-3D56595A3C8E_zps
Photo of modified actuator arm.
37B88D82-C051-4CF1-A2DB-AB1561CCC5F4_zps
Photo with gasket overlaid.
5E62BC2E-0E66-4206-B1DD-0A10763492DF_zps
Item: Tomei Series 1 dump pipes
Price: $ 550
Condition: Fine. Have been ceramic coated
D5089FF2-37F4-4BC5-8040-4ADEA54F4005_zps
Item: Racepace twin 3 inch exhaust system
Price: $3,200
Condition: Fine. Few scratches here and there as you would expect. This exhaust was made by the previous owner of Racepace for his own car. As far as I know, it’s the only one they made. It’s a shame to let it go but won’t really work with the single setup. Front pipes (which are tuned length) have been ceramic coated also. Made 472 RWKW on -5's on Unigroup's dyno. No restriction here.
Underbody shot of exhaust on the car.
From rear of the car.
It would, I believe with an ever so slight modification. You're welcome to try it.
33/34 is the same bar 20 mm.
Item: HKS AFM delete pipes
Price: $150
Condition: Fine. I sprayed them black to look more "standard".
Payment: Direct credit into my account, Or cash on pickup (if in Sydney)
*Surge tank not inlcuded :P
83747408-BDED-481D-A4E9-C644DF3AA119-142
How they look on the car.
Ive done quite a few k's in piggies car & i also pulled the racepace exhaust off his car.
I can tell you its a well made unit and fits like a glove!
This exhaust sounds horny as hell!
Ive gotta say its not exactly the quietest exhaust on idle but somehow its volume really doesn't change that much when you're up it!
Dont have to tell you all this is a rare 1 off exhaust system that will make your R sound fat as hell!
Now hurry up and buy this thing so Paul can give me the monies to make him a new exhaust! :D
  • 1 month later...
  • 4 weeks later...
  • 3 months later...
    • Not noticeably. Arguably, the catless turbo is going to work harder in a different direction, as it will spool up faster, go to higher speeds more easily. Only if it was tuned in the original condition. If it was a stock tune, using the AFM before and after the cat/dump change, then no, no retune needed. If the car is running on a MAP sensor, then it might well benefit from a retune. It might even run a little dangerously without a retune, but it could quite easily be fine.
    • We had this blend that uses 98RON + 10% Ethanol which brought it to 100RON. It's no longer available anymore unfortunately.
    • Does it make a difference in your turbo having a shorter life if you have a cat converter as it causes that back pressure versus less/no back pressure with a decat? (Not sure if this is accurate) Also slightly different question if you went from a oem cat to a decat or vice versa will it require a tune? I heard if you change the dump pipe onwards it requires a tune?
    • No. Have only gotten as far as contemplating the task of having to put in the required fairly heavy wiring and fusing to run it (along with the big alternator), and preferring not to. But otherwise, it would be nice to have a little extra freedom as to exactly where the compressor is located and free up some space around the exhaust side of the engine.
    • Following from this in a related by not closely-related sense... Because I was buying a bunch of other GKTech stuff, I got some rear subframe collars. The history that leads up to this is: 25+ years ago the car arrived into the country with stock subframe bushes. At some point shortly thereafter I added Whiteline pineapple rings, set up neutral, and it improved the rear end behaviour. Well, it is my vague memory that I was happier with it with them in. Less axle tramp on launches, generally better, etc etc. ~2012 it got a new non-HICAS subframe with new stock bushes. No pineapple rings. I reckon that ever since then I've been dissatisfied with the axle tramp. Recently I've been f**king around a lot with all aspects of the suspension. One contemplation has been to relocate the rear lower control arm front mount points (and do the other things needed to make that work) to improve longitudinal rear grip by getting rid of some of the stupid anti-squat that Nissan ladled into the R32. But.... before doing that I thought I'd put some collars in. And.... The collars are good. The rear sounds a little bit different, but there has been no significant increase in NVH coming up into the body. In terms of rear behaviour - expansion joints on long sweeping elevated freeway ramps that would sometimes cause the rear to jiggle around a bit, no longer seem to do so. It appears that jamming chunks of metal into the gaps in the rubber so they can't move much is a really good thing. And the launch behaviour and general forward traction situation seems to be greatly improved too. It's impossible to be really sure, because the tyres are completely shagged - they are freakishly willing to let go right now. But as an A-B test with the same tyres it certainly seems to grip up a lot better. Highly recommended to anyone who still has stock bushes.
