Under the parcel shelf you have a bunch of electronics, a rear strut tower brace and a battery. Then under the strut towers there is a fuel tank that straddles the diff. Below that is the rear cradle.
What do you want to do with the tether point? Are you trying to setup an anti-theft tie down point?
  • Like 1
Do you mean a child seat anchor points? I don't think so, on my R34 GTT sedan there are aftermarket points that were put in as part of compliance. They're pretty basic though and should be easy enough to install yourself if you're keen.
As mentioned above, points get put into the parcel shelf as part of compliance. They punch a hole through the speaker grills so the anchor points are accessible from within the cabin.
In case it's relevant, you can't really do rearward facing seats in a 34 GTR because it will make contact with the front seat which apparently it's not meant to do.
  • Like 1
Ended up taking my rear seat, and parcel tray off.
The points are there, just next to each speaker.
I did have to cut a hole into the parcel shelf to access it, luckily not through the speaker grill.
Thanks for your help guys!
  • Like 1
    • I don't really know general street pads too well, but there is no reason you can't get a low dust, long wearing, no squeal pad that works for those calipers at a reasonable price....they would just be a low end to medium price daily style pad.  If new pads don't have much bite or they loose it over time, it is probably just the pad glazing up which you can fix by giving them a good thrashing every now and then (or get the mechanic to deglaze them at next service) Track or semi track pads are where you have to put up with excessive dust (and potentially squealing as a side effect of that) in return for good bite and performance when very hot. Street pads have nothing like that sort of punishment, even long downhills with the brakes on are easier than a track session
    • lol yeah I'll check that, reminds me of the LDV thread!  I don't think that is the problem here, the starter doesn't even solenoid click. I did do a super quick test by removing the starter motor's power cable from the engine bay fuse box and the battery voltage was still 10v, so something super fishy is going on. BTW here is a R33 fuse box table I threw together from a few sources....use at own risk! R33 Fuse Box and Sources.xlsx
    • Johnny's approach, throw all the Nissan electronics into the trash. Best thing I've done to my shit box, go DBW.
    • Sounds like the JAX guys must have installed some really awful pads, are they BenShit/BenDicks pads by any chance?
    • Result of another R35GTR build. Similar specs as above except this is running our bigger size SS-2 profile option. Made similar power except this car runs on Pump 98 fuel. Build specs are: Nissan R35 GTR 2015 model stock engine and box. ETS street intercooler boost logi intercooler piping with tial bov, boost logi turbo inlet pipe ID 1050 injector DW 300C fuel pump Decatted oem down pipe and y pipe& HKS exaust 3inch intake pipe Upgraded actautors HyperGear SS-2 high flow option Final result is 639whp / 477wkws hubs, Ron 93 / P98 fuel at 20psi.
