So after my car being off the road for 6 months finally got her booked in to be tuned Tuesday next week.
Finished a few small mods and maintenance issues and last night I did my coolant.
Only real modification's worth noting for this topic are:
-removed aftermarket fuel rail and FPR in place of going back to stock.
-installed recalibrated 'Nismo' AFM's after having Z32's.
-removed 'Apexi' pods in place of going back to stock airbox.
Now I'm getting the dreaded poor idle, running rich and it won't rev over 2500RPM.
So after a search this all points to AFM's and the soldering inside (my units are virtually new though (refurbished) so I would like to think this isn't the issue)
The only thing I can think is that when re-wiring the standard plugs back in I've possibly mixed up one of the wires? If I recall there was two wires the same colour...
I've attached the best drawing I could find googling but naturally I don't read Japanese.
does anyone have a better standard wiring diagram for the standard RB26 AFM plug?!
...Or does anyone have any other thoughts on what else could possibly be wrong?!
https://www.sau.com.au/forums/topic/461595-rb26-idling-and-rev-issue/
Hi Ben
It has a Nistune ECU and was tuned with the standard RB26 AFM's (was installing Z32's until I realised they don't mate up to std airbox)
So I was under the impression that going from the standard units to Nismo (equivalent) items it obviously needs tuning but would still be driveable or has the Nistune ECU picked up that these are different units and decided to crack the poops with me?!?
Nistune hasn't "picked up" anything. The Nismo AFMs are the same physical size as the RB26 units but scaled the same as the Z32s. Consequently they are reading completely the wrong voltage relative to the amount of air that is flowing through them (compared to what the original AFMs would read with the same air flow). The ECU doesn't know you've changed the AFMs and is trying to run the engine according to a different amount of air than is actually flowing.
Agreed - Was just typing this as well until it popped up that you replied.
    • Thanks Dose.....    I appreciate it!!
    • I'll probably be putting the shit box back on the dyno again soon, I want to dial in the closed loop boost control properly. I'll have a camera facing the car/motor for fun too. Just note, there are essentially 3x 10AN inlets going into the catch can and 1x going back to the intake pipe. Most of the time the catch can "return" to the sump actually is the crank case breather, pushing air out.
    • I have the R3C with a Nismo slave and by no means does it behave like a stocker, it ain’t THAT bad. On take off just give a bit more throttle than you would say a coppermix and it’s fine. It will not slip though.
    • Okay. Final round of testing done. Got a friend to hook up a fancy scanner to the car and we also ran some compression and leakdown tests, she is healthy.  The MAF was definitely the culprit. So for future reference anyone with similar issues that find this thread. I suggest the following steps, in order of affordability:   Check your spark plugs for any fouling, replace plugs if they are bad or re adjust the gaps making it narrower (0.8mm would be good). Check every coil's resistance with a multimeter. It can be done by probing the IB and G pins on the coil pack. Resistance should be around 1.4 (+/- 0.1) Ohms Check the MAF. If you have Nissan connect or a good scanner with the 14 adapter it should allow you to see the voltage on the MAF reading should be around 1.1 - 1.2V when car is idling. But if you don't, buy a new MAF from Amazon and test, then return it. (For instance, I got a Chinese one for $40 that was reporting 1.3v on idle). If you still have scanner, you can run tests on the injectors to see if they are working, just remember to unplug the fuel pump fuse/relay and have no pressure on the line. Then listen for the noises that the injectors make. Clean/replace injectors as needed. Once you find the issue and fix, order thousands of dollars worth of OEM parts to refresh unrelated things (Optional)   PS: Thanks to the absolute legends of this forum for the responses and help to someone that went a bit over their head. (me)
    • Ha ha ha, so they stopped the bearings spinning on the one you want, but then decided the crank hub should slip instead 😛   Stick to RB, at least you can work on it yourself. And now it doesn't smell of vapour   Also I still believe there's a chance your new flap doesn't "pop", as even though the engine might breath hard, it has a direct path with no restriction to the inlet, which when on boost should pull a bit of suction for you. If you do get pressure in the catch can id be very intrigued. Time to put a boost gauge on it, and a session at the track, then solid cover your vent and do another session
