Hi All,
My AC drain pipe was sitting against the dump pipe on my R33 after I put in a Hypergear turbo (ATR45SAT). I had it taken to JEM to get tuned but on the way home it started smoking so I bit the bullet and cut the drain pipe so I could get home without it smoking up and catching fire.
I'm not sure what to do now because if I use the aircon its going to drain onto the dump pipe and steam, rust and more than likely crack.
Has anyone come across this before? If so what did you do to fix it or get around it?
Pictures below
AD709293-2F53-459D-B56A-A6FADF6617BD_zps
E28070AD-2D5F-4D05-B6F9-8CAFD865F3C4_zps
Thanks!
https://www.sau.com.au/forums/topic/461606-air-conditioning-drain-pipe/
Thanks to the thick adapter Tao welds on it pushes the dump back too far which melts the drain. If it gets bad enough it will flood inside the car. The dump will be fine as long as it isn't wrapped.
Yep I'm not sure why it's so thick, I was worried that the dump would actually fit when I was looking at it.
So you think its OK for the drain to drip onto it? Not wrapped dump anyway :)
Fark, is that what the burning smell was when I went single. Just checked and mine is burnt down. So does it need to be rectified or is it OK to leave?
Glad to know I'm not the only one - Waiting for responses but someone on SAU FB page said just get a heat sleeve and get that onto it which I'll probably do if Scotty says that letting it drip on there isn't OK
Edited by kingtube69
Get a steel pipe that will fit neatly inside the hose and clamp it on. Get a p-clamp that fits around the pipe then and bolt it somewhere that will bring it out of the way
Thats a basic idea but you can bend the pipe etc to make it fit properly
Not only will you find disgusting water splashing in the passenger footwell, you'll find your car filled with mosquitoes!
It doesn't leak into the cabin, its cut on the engine side and can still drain out its just that I dont want it running onto the dump pipe
The issue is that the bend in the rubber hose actually sits on the dump if its in place :(
Yet... Let it melt back a bit more.
Poorly designed 'drop in' turbo considering most of you are running the exact same JJ dump.
Those hypergears must sit so far back....ive got like 4" clearance with my bolt on td06
Its got plenty of clearance using a OEM dump pipe. Or should JJR be making dump pipes following OEM dump pipe angle? But Having said that not all jjr dump pipes touches either.
That Xforce dump in my R33 years back was trouble free, and so is Tomei.
I will seek alternatives ways to get the IWG assembly shorter.
Hmm, it's not that the lower part of the pipe sits against it so it would be hard to tie it off to the side. It's that the bend off the pipe sits against the bend of the dump pipe. Bit of a pain in the ass but I'll work something out.
    • ...just a note of warning, you shouldn't drive it about with the TCU in limp mode with only 3rd gear available ~ apart from the fact you end up sheering the ATF at the torque converter interface, the high clutch in these isn't especially the strongest, particularly bolted to the RB25DE mill...which is likely a 4AX01 box with lighter duty high clutch (the RB25DET got the bigger high clutch)...be careful out there...
    • Hoping to do similar mods to my RB20 once I get it running and reliable again
    • As you're looking at using a Link ECU, then large injectors are not a problem. But there's not really any need to go 1000s on an RB20 unless you're planning >>600HP on E85, which would seem unlikely. There are other options for injectors. The Xspurt ones are available from a number of places and you can get them in the mid 600s and 725cc, which is probably a sensible place to be. These are all EV14 based. If you are not using the stock AFM (at all, which would be the case with a Link) then a large turbo intake pipe to suit the ATR turbos is not an obstacle, so you should use one instead of a highflow. Results will be better.
    • Hey guys,  I'm after some advice and this here is the best place to get it imo. I was a member a looong time ago under another account, with a lost email address. Its nice to jump back on and see some of the same names still giving good advice.  I mothballed my car when i moved to perth in 2013, and after getting towed across the nullabor a few times it has officially done more km's on a trailer than under its own power. Now that i have started the process of tidying up and modifying it, i see the fruit available (and the fruiterers selling the produce) is different than back in the day. hence my questions, as i used to 'know' what to get and now, i'm not so sure. Engine wise the car (92 gtst) has a walbro 255, k+n, fmic, cam gears and and turbo back 3"exhaust. Wish list is a Hypergear high flow or ATR43G1, Link G4x and some newer injectors before a tune up. My goals are modest, only low 200's power wise. i know i could achieve this with less, but i've been swapping out old for new where i can. Every cooling hose has been replaced, along with mani gaskets, WP, thermostat and radiator, fuel pump and timing belt, tensioner and idler, and i rebuilt the steering rack. Regarding the injectors, the fruiterers all seem to sell what used to be considered quite large injectors. There are a lot of options for bosch 1000cc EV14's, and i would like to know if that is a suitable choice for my build. Is modern injector design good enough to run these at the low duty cycles that i likely would be? is there a downside to running a too large injector these days? or, would there be an upside to running a smaller injector at higher duty cycle? I can see that there are smaller injectors still available, but the ones i have seen specifically marketed for RB's are pretty large (see: https://golebysparts.au/collections/fuel-rail-injector-kits/products/nissan-rb20-fuel-rail-bosch-980cc-1150cc-injectors-turbosmart-fpr800-regulator-kit), and i dont know enough about them to say one not marketed for RB's would fit or not. I have searched the forums, and amongst all the posts on older tech, I did see gtsboy recommend EV14's, but no size was mentioned... again, i'm not clear on if the smaller size bosch injectors are also EV14's as they do look similar.  also, if someone can recommend a tuner familiar with RB's in the Geelong or West Melbourne area i'd appreciate it. Thanks in advance guys. Cheers, Rowdy
    • FWIW the depth of the groove in the rubber pad is not super essential, the blocks are rubber and squish a bit. If you are worried an angle grinder will make a deeper groove quick smart
