SKYLINE R33 GT-R 1995 MANUAL 4WD
TWIN TURBO WITH A LOW 80000ks
NOTE: NO TEST DRIVES NO TEST PIOTS I WILL BE DOING THE DRIVING UNLESS YOU ARE GENERALLY INTERESTED IN BUYING THE CAR AND A DECENT DEPOSIT IS LEFT THIS IS NOT A TOY THIS IS MY PRIDE AND JOY
VIN:6U900BCNR33002606
IMPORTED INTO AUSTRALIA 04/06
Up for sale is my weekend car I barley drive it rare midnight purple very clean car pain is in very good condition for its age as you can see in the pics 260kw very safe tune and reliable can be retuned if your chasing big power Carbon Fiber front lip and rear spoiler blade the mod list below
700cc injectors
Dash 7 turbos
Hks pod filters
1 bar of boost
Alexi power fc
Nismo front pipe and the rest is stainless steel from cat back
Upgraded fmic
Alloy radiator
Split fire coilpacs
Nismo clear side indicators
Button clutch
Aftermarket wheels 18" 90% thread wrapped in 265 tires all round
Greddy electronic boost controller
LOCATED MELBOURNE
CALL OR TEXT ME ON 0432062780
PRICE:$24000 with Current reg and rwcpost-62515-14499983048061_thumb.jpgpost-62515-14499983409851_thumb.jpgpost-62515-14499983691606_thumb.jpgpost-62515-14499983902064_thumb.jpgpost-62515-14499984179508_thumb.jpgpost-62515-14499984459161_thumb.jpgpost-62515-14499984827446_thumb.jpgpost-62515-14499985174226_thumb.jpgpost-62515-14499985420748_thumb.jpgpost-62515-14499985621151_thumb.jpgpost-62515-14499985749068_thumb.jpgpost-62515-14499985897247_thumb.jpgpost-62515-14499986027522_thumb.jpgpost-62515-14499986228224_thumb.jpg
  • Like 1
https://www.sau.com.au/forums/topic/461628-skyline-r33-gtr-midnight-purple-vic/
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
