Most try and tell me its gutless and fit an RB25/26/30.
Dont you hate that....well i do :)
A nice turbo setup on an RB20 works great, already have 8.5:1 compression and spin nicely to good rpm.
Problem is when its time for a new engine, do you just throw another stocker in and drive it into the ground or do you build an engine up...if you are building an engine i can see the sense of going bigger...but not if the engine is healthy. :)
How does the GTS4 driveline work, is it rear drive like a GTR until you light up the rears or does it normally have a % of torque to the fronts...never been in a GTS4
I thought I'd join the conversation too as I have a 32 gts4 as well :)
Roy the front only engages when the rear loses traction, such as when you launch :D
I've done a 13.7 so far with a FMIC, stock turbo and 3" exhaust (manual also), but I'm looking for a TO4E turbo kit to fit to the car in the hope of getting a 12 one day!
TurboX i had the same problem as you .. I was at the drags and I blew the headgasket. Pulled the head off and found that the number 6 cylinder had corroded through the water line and ruined it :)
Its exactly like a r32 gtr, only when the rears are slipping does the torque get transfered to the front.
I might add that my worst understeer happens in the wet at low speed, in the dry its not so bad but only cause you have to push it alot harder to lose traction!
Firstly i appreciate all the ppl that say "GTS4 understeer" have probably never driven one, but if its pretty much RWD is the slight front end push a result of the extra weight up front?
So is the gasket thing simple an age thing, or are these new head gaskets that have failed after aonly 1yr ?!?!?!
I thought I'd join the conversation too as I have a 32 gts4 as well :(
Interesting that your head gasket problem sounds exactly the same problem as mine. I wonder if this is more common than we think? I have a feeling that the water had seeped in behind the metal sealing ring and was sitting there for a while as it was slighlty corroded, but not on the ring sealing surface, just as well.
I am going to just put the new one on and fill the corroded bit with hylomar so hope it will be OK as the metal sealing ring block surface is OK.
I am tending to think that it went because I cranked the boost up a bit and slightly advanced the timing on my fourth run trying to crack 13's ( - Did everything you should NOT do at the drags! ) I probably detonated it through the already corroded metal ring. :rolleyes:
Dont you hate that....well i do :rolleyes:
As mentioned , same as GTR. Interesting thing if one of your tyres goes down a bit you can always tell because the AWD starts to be on all the time at a low %.
If you get new Wheels/Tyres you have to maintain the same rolling dia to make sure its not on all the time as well as I found out after purchasing some new back tyres. Thought I would go a bit larger and had to swap them straight off again.
I actually have another two NA RB20DE's I bought for spares from EKW for $200 each complete (no G/Box) :) Both seem perfect with all access.
I am not sure on the exact differences in the Block but I do know that the combustion chambers are double? the volume by looking at them in the head.
I was nearly going to do up the NA head until I realised just in time before they started work after cleaning it up. :Oops:
Anyone out there know if the NA block is same as Turbo block???
Could always do a 2.4 with the RB26 Crank I guess.
hehe, just like in HPI with tomei pistons and gtr rods, Don't forget the trust IHI old turbo kit with ex gate. i reckon its cool that the trust kit still uses the original manifold - saves buying a new one :rolleyes:
Forget the IHI buy my TD06, it goes well on an RB20 so on an RB24 it would be great. End shameless self serving plug :Oops:
I want to do the whole RB24 thing, only prob is pistons are more expensive then 86/87 mm ones, and the bloke who i hassle for parts keeps remiding me its more expensive then following the flock, and as coin is something i hate spending ill have to come accross some cheap HKS/Tomie RB24 pistons pretty quickly if im going to do one.
I would have thought the NA combustions chambers were the same size or smaller due to increase compression???? Dont know though.
If
Sorry Roy, my post on this item was a bit ambiguos - the NA Head has much smaller volume chambers than the Turbo Head. As you say, for higher comp. ratio.
Unfortunately the NA cams are the same as the Turbo - Bummer! I really did think they would have more Lift/Duration but apparently not. I was looking forward to more duration at least :D
    • Nah, just take the other one off too
    • Oh yeah forgot to also mention need to also unplug the IACV as well. Thanks for the reminder @MBS206 Unplugging the TPS takes it out of closed loop so you're able to screw down the IACV without the ECU trying to add/subtract timing to maintain the idle (not sure PowerFC can even do this, but Nistune and the OEM definitely does)
    • For sale is my 1999 Nissan Skyline R34 GT-T, tuned to 234 kW / 313 hp. I've had the car for a few years as my daily driver. The car is original (as far as Skylines go), with only a few minor upgrades to enhance performance and driving experience, as typical for such a car of its age. Overall, it is in great condition with no body rust, thanks to its earlier import date. It features a top-notch security system (not literally, but it's great!) with remote start and still functional 4-wheel steering via HICAS. It comes with several performance and handling upgrades, including:     Hypergear 450HP Turbocharger running 17 PSI boost, installed mid-2021 by Jaustech     550cc injectors     Nistune ECU     Front-Mount Return-Flow Intercooler     X-Force Stainless Steel Exhaust     Upgraded engine mounts     Bottom end bearings replaced     BC Coilovers     Lenso DR1 rims     Bridgestone Potenza Adrenalin RE003 TL 245/40R18 97W tires, fitted early 2023 The interior is mostly stock, with a few additions:     Viper Satellite Tracking System with remote start     Bluetooth Double-Din Touchscreen Head Unit     Steering wheel cover Cons:     A few paint imperfections here and there     Driver’s seat shows more wear than the others. It's not torn at all, but I've added a seat cover to protect its condition. I also have a CarVX Vehicle History report available for serious buyers, so you don’t need to purchase it yourself. Price: $26,000 ONO.
    • I've had two suzukis in the past have an extremely hard time turning over and not starting after sitting for a few weeks. Ended up the alternator would seize up causing the starter to force. Same issue both times.  Maybe they're sourcing their alternators from the same place...
