Hi, just curious to know if my awd system is working correctly or has an issue that hopefully the gtr gurus could point me in the right direction if theres a fault somewhere. Since the only gtr ive been in is my own i dont have anything to compare it to.
Basically the 4wd light comes and goes as it pleases randomly for no apparent reason, but it will decide to work correctly about 50% of the time, would there be any reason for it to do this (system has been bled, no fault codes and tyres/rim are all the same sizes). Any possible idea?.
Also ive noticed that when the awd system is working it works completely fine when going straight but if cornering it seems that its all rwd, even under hard acceleration. Is this normal? Or have i got a fault somewhere?
https://www.sau.com.au/forums/topic/461736-r32-gtr-possible-attessa-issue/
There is a few threads in here you can search
My advice to most is a new Nitrogen canister (original is 25yo and very likely not doing it's job) and a new digital G Sensor (also very old and slow technology)
and if you want to go a good step further have the transfer case o'hauled and tightened up.
Cheers
  • 3 weeks later...
No, can be done with everything on the car (even the exhaust, although does make it easier) after 26 years mine was pretty tight and i had to machine a custom socket to get it off. using a g-clamp as i had read in another thread resulted in the canister unscrewing itself which could be pretty dangerous if the thing still had change, surprised they didn't make it with a left hand thread to avoid that ever happening. Was definitely worthwhile to replace the canister, overlooked by the vast majority i reckon.
    • Hi soviet_merlin, We appreciate your concern regarding this possibly being some sort of PR/Political hype, I assure you that is not the case, I wish we could claim something like that, but in this case, we merely reached out for comment on the basis of the outrage we too felt, as those heavily in the automotive industry. Ps. the original source in the social media post is CarExpert not CarExplore.    Best, CE.
    • Made a bit of a discovery, but while I was cruising, I randomly decided to test to see if it worked and it showed up on my IC7. The entire time I tested it before, I never thought to turn the ignition on. I only tested it with head lights turned on but with the ignition off. Huge oversight on my end. I’m a dummy. I know.
    • G'day all, I have drilled and tapped the hole for the relocation of the timing belt tensioner. That was straight forward. I'm unsure if I need to also put another hole for the smaller stud that the spring behind the tensioner catches on (this is how it seems to work in its original spot). Or do you not use the spring behind it and just torque it down? Thanks in advance, I did a search but couldn't find anything related and it doesn't mention it in the rb30det sau guide.
    • Hi All,  just thought I would provide an update as I know smooth (Matt) was on this forum from 2003.    my brother Matthew passed away end of may 2024 at the age of 41 from liver failure. I am not sure how many of his original team krazy friends are still on here or active but thought it reasonable to let the forum know.    if you have any photos or pictures it would be great if you could share them.    it took me a while to work out he was active on here.    thanks so much
