Hi, just curious to know if my awd system is working correctly or has an issue that hopefully the gtr gurus could point me in the right direction if theres a fault somewhere. Since the only gtr ive been in is my own i dont have anything to compare it to.
Basically the 4wd light comes and goes as it pleases randomly for no apparent reason, but it will decide to work correctly about 50% of the time, would there be any reason for it to do this (system has been bled, no fault codes and tyres/rim are all the same sizes). Any possible idea?.
Also ive noticed that when the awd system is working it works completely fine when going straight but if cornering it seems that its all rwd, even under hard acceleration. Is this normal? Or have i got a fault somewhere?
https://www.sau.com.au/forums/topic/461736-r32-gtr-possible-attessa-issue/
There is a few threads in here you can search
My advice to most is a new Nitrogen canister (original is 25yo and very likely not doing it's job) and a new digital G Sensor (also very old and slow technology)
and if you want to go a good step further have the transfer case o'hauled and tightened up.
Cheers
  • 3 weeks later...
No, can be done with everything on the car (even the exhaust, although does make it easier) after 26 years mine was pretty tight and i had to machine a custom socket to get it off. using a g-clamp as i had read in another thread resulted in the canister unscrewing itself which could be pretty dangerous if the thing still had change, surprised they didn't make it with a left hand thread to avoid that ever happening. Was definitely worthwhile to replace the canister, overlooked by the vast majority i reckon.
    • Where is the best location for boost pressure source when running mac 3port boost solenoid?  my new turbo does not have a fitting for that on the compressor housing.  how come Garrett make a turbo without that?  im confused
    • From my memory, which isn't that great, we did have issues getting the large throttle body on my old LS1 to play nicely at idle, first it would stall, then it would only idle at 2k rpm, then it would hang at 2k rpm for a few seconds and then drop and stall, then, finally, the best we got was it would hang at 1.5k rpm for a few seconds then drop to around 800 rpm The tuner stated that large cable throttle bodies are a PITA, and if I wanted anything better than what we ended up with I would need a electronic throttle body and all of the aftermarket ECU stuff to run it
    • So, my intake arrived  I'm not happy with the coating finish so I went to Supercheap and got some black wrinkle paint and some prep stuff I was initially thinking about using grey wrinkle paint, but finding a quality product that gives the texture I want was "unfindable...", so the tried and tested black wrinkle paint is again finding its way into the engine bay for the OEM look I'll sneakily head into work and get the big ovens cranking to cure the paint over the next week or so I've also contacted MX5 Mania today to talk about the install and tune, so painting it is my "main effort" prior to sending the car off In other news, the correspondence from the US supplier is fair to midling to say the least, I'm still trying to track down the intake box thingie with the larger intake pipe to suit the throttle body, it still is "awaiting fulfilment" (no stock currently available), if it isn't here soon I'll just get MX5 Mania to fabricate up a CAI that is easy to service the air filter
    • Thanks mate. I thought it would be that way.
