My drivers side window decided that it didn't want to work anymore, due to the window relay. After paying for another one my Dad had a go at fixing my original one, with success. It turned out to be a dry solder joint, shown in one of the pics. Hopefully these pics will help anyone else with similar problems.
Door card will need to be removed to access the relay and soldiering skills will be needed.
Tools required:
Soldering iron
Solder
Solder Wick( removes old solder when heat is applied)
Couple of flat screw drivers or butter knifes to open relay casing.
This is the relays location behind the door card.
This is the relay.
With the plug end removed.
The offending circuit board from inside top view.
The underside of board, and I've high lighted the offending solder.
The dry joint can be seen better in this close up.
This is what's needed to do the repair.
First use the solder wick to remove the old solder from the join. This will allow the new solder to fuse better.
Once done, you can then re-solder the join.
Once cooled, slip the board back into the cover. The board locates in the grooves in the cover.
Once re-assembled return to the car and plug it in and test to see if problem solved.
I hope this has been helpful.
  • Like 1
https://www.sau.com.au/forums/topic/461756-r32-window-relay-fix/
Could i be having the same issue?
My drivers window switch works! Although the passanger window switch doesnt from my side (passanger window works on passangers side)
Also an R32 :) thanks!
I've had this issue also. I ended up replacing the drivers side switch panel to fix mine. If you can, try and borrow another switch panel from someone and test it to see if it works.
    • Is there a significant price difference between the Evo/gtr/350z brembos vs the F50? Looks amazing.
    • I was actually being a tightarse at the time LOL... My OCD is tickling me into running a 2nd 8AN Teflon hose all the way down and removing the 2x OEM hardlines. My other side of my brain is telling me to run 2x hardlines front to back (also acts as a fuel cooler, so win win).
    • As I mentioned in an earlier post, I had some trouble with the Silvia's brakes dragging back in 2023. I managed to sort it out then, but the same problem came back to bite me late last year. Just take a look at the picture – I had a feeling the handbrake was acting up again, and I was right. Anyway, I'd been wanting to upgrade to bigger brakes for a while. Not that the Silvia's brakes were bad, but it was more of a "want" than a "need", you know? It was funny, though – at the time, I couldn't find any Evo Brembos, 350Z Brembos, or GTR Brembos for a decent price (of course, tons of them popped up online after I already bought my kit!). I ended up going with an F50 Brembo kit, which came with adapters, brake lines, 330mm rotors, and top hats. The F50 Brembo caliper was used in a few other cars too, like the FPV. I also decided this was the perfect opportunity to ditch the Silvia's ridiculous rear brakes and that awful handbrake (some of you were definitely right about that!). I picked up some R33 calipers and all the necessary bits – rear drums, backing plates, and new hardware to refurbish the calipers. Of course, it wouldn't be a project without a few hiccups. Turns out the brake master cylinder was playing up and basically (to put it simply) keeping the brakes engaged. I had it overhauled, and after some adjustments, everything was working again. The whole process took a while, as you can imagine. To top it off, the front right wheel bearings were shot and needed replacing too. This is a rare occasion where I'm posting an update while it's all still fresh! These pictures were taken just this afternoon.
    • I was just going to say that it's good to see you picking up the pace again. Hope the surgery goes well. More downtime just means more time to come up with new ways of digging a deeper rabbithole
    • How do they compare in size? I have the Yaris coil packs in mine and they work fine. But they are either bigger or sit differently so the engine cover doesn't fit anymore. Not the end of the world but not great either. Do the R35 ones sit flush?
