I'm selling my car which i have owned since 2009 and has sat in a garage for most of the time i have owned it. Currently has 116000 KMs on the clock and has rego until march. Has also had it's 100000 KM service and has 222 KW at the wheels.
located in bathurst.
Parts list
Garrett 2871r turbo
Exedy cushion button clutch
3 inch turbo back exhaust
Bosch 040 in tank fuel pump
Z32 AFM
Apexi pod filter
600cc deatsch werks injectors
Split fire coil packs
Profec B spec 2 boost controller
Apexi PFC
Gates timing belt
HDI front mount intercooler
ISC 52mm radiator
ISC N1 coilovers
ISC camber arms
dba 4000 series slotted rotors front and rear
Work XD9 rims
Defi boost, water and oil temp gauges
Nismo drivers and passenger seats
Mongoose alarm system
Price: 19000 ono
I might of forgotten a couple of things so any questions give me a call on: 0401859316
https://www.sau.com.au/forums/topic/461766-blue-r34-gtt-for-sale/
  • 1 month later...
hey guys, been around this car since Tim bought it (pretty sure I drove him down to pick it up). It's been very well maintained the whole time Tim has had it and no expense spared.
Few things I can think of that Tim has forgot:
When he did the 100k service he did head gasket (cometic I think) also new ARP head studs were used
The Apexi PFC has the hand control unit
Nismo B pillar carbon fiber garnishes
The 3 inch turbo back is also a full nismo unit front to rear
Also as he states it has 222rwkw, he didn't say that's only on 15psi, so the car definitely isn't working hard for the power and its nice and responsive with plenty of room if you wanted to push for more power!!!
Paint on the car isn't very old at all either
Will be a great buy for anyone in the market
Hi bro, just wondering about the seats in your car. Can you remember were you got them from as they are what i like and want??? Cheers
Hey mate, i bought them off someone on this forum about 3 years ago. I'm not sure where he got them from.
So i cant help you sorry mate.
Id love to give you my r34 s2 seats in perfect condition and $1000 for your seats? I know the answer BUT had to ask... i can't find them anywhere. Cheers bro good luck with the sale and a free bump..
    • Unless things that you want to do include reference to time. Simple Boolean logic is only good for digital inputs or analogues that have been thresholded into digitals. But unless you also have a timer function available (which would more ideally be located inside the program, rather than being forced to implement a timer outside the ECU and bring it in as a seperate digital for every time delay you want to implement), then you can't do some of the things that you might want to do. My PLC ladder logics are obviously littered with program blocks, because that's easier than building it all in ladder gates, but the most frequent of those program blocks is a simple timer, because you actually can't otherwise do that in ladder at all.
    • Log voltage. I'm suspecting the alternator. Or even maybe a bad earth somewhere. ie, seeing as it is rev dependent, I am thinking it is alternator dependent.
    • Yeah so N1 and any other larger than factory pump are pretty famous for pumping the sump dry...obviously we don't often get to spend 20 or 30 seconds at high rpm/full noise on the road so I'd still be suspicious that is what is happening here.
    • You are also getting pressure dips on gear shifts. They're just not dipping as far, but they're dipping quite below the amount of oil pressure you should be seeing, for how much RPM drops.   It quite little could be the oil pressure relief valve is starting to stick open a little/is slow to close.
    • Can you log battery voltage, and TPS, and put all four of those into a single image (even as split graphs)?   The oil pressure drops aren't following RPM as such. I'm intrigued if you may have a ground loop between different sensors. With the engine not running, log your sensors and for example cycle the throttle pedal. See if any sensor values flutter or move about. This won't be a perfect test either as the ECU won't be cycling all of its actuators like it would be while running. What EMTRON do you have? Do you have a link to the wiring guide for that ECU?
