So, this is my dilemma. They are hard to get a photo of, and can only be seen in certain light BUT they are everywhere.
the guy a bought it off used a Scourer to remove mould off the car. He left it sitting under a tree for nearly 2 years.
So my concern is, how much Clear/Paint is on the car.. i know these can easily be removed but i don't want to attempt it if there is a risk of causing a bigger problem.
I'm planning on the selling the car in 6 months or so.. So I'm hoping i can eliminate some of the issues. The paint is still shiny and looks great considering.
Also has some rust which needs attending to, most of it is easily repaired.. Couple of spots are of concern.
Or would it simply be better to not worry about the Scratches.
https://www.sau.com.au/forums/topic/461767-r33-light-scratches-everywhere/
Was about to say. Looks like someone hit it with a scourer.
You could remove a lot of those marks if you put in the effort with a cut and polish. But it has scratched a lot of the clear and will be making life hard for the next owner. So it really depends on where your morals lie.
That is why I want to get rid of them, I was unfortunate to not have noticed ( was a nice sunny day )
Who ever buys it shouldnt have to worry about it.
as stated I'm sure most will come out, just unsure how much i can cut it back etc
that's shallow scratches. good machine polish will remove them without taking too much clear off
the thickness can be measured but needs a $700 paint depth gauge, no point buying unless you are a pro detailer
Edited by junkie
Wouldn't a panel shop be able to do it just the once for you? Surely it would be better than having an expensive tool lying around never to be used again.
The tool will quickly pay for itself when looking at any cars in 'original condition and 'original paint' etc.
That is true, you could have it for years and only use it a couple of times but for those couple you will be pleased you bought it.
These photos were after a polish. Except the Polish I use is fine as, no grit etc. So maybe a more Hardy polish and a Wax may help.
Otherwise I'll hit it with the Buff, I'll just make sure Im using a light touch.
Once I clear this up I need to have a look at the rust
Panel shops are not detailers or "Paint correction" specialists.
  • Like 1
If you are desperate enough to know how much Depth your paint has, I'm sure a shop somewhere wouldnt mind having a look if they have the tool. Might cost you though.
Would probably be easier to either buy one yourself or just wing it though. I've decided to have a go on the boot. atleast it's an easy enough panel to paint or replace as there is heaps of white ones without my issue.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
    • Was that Australia Delivered Duncan? Does it have siren etc?   I used to have remote start on an old 32 two decades ago, it was a cool feature. I used to wake up early in winter for work. Start it and by the time i was out the door a few minutes later the engine was warmed up and the heaters had the car toasty. It was great.    I don’t mine the ambience lighting.  I drive a western star and it has footwell lights and ambient lighting and it’s great! From the pics of seen of them installed in a skyline I think it’s a nice touch
