Oil Cooler Recommendations For R34 Gtt?
How did you get on with this?
Well, it's been an epic saga but I think it's all sorted finally. Check this thread: http://www.sau.com.au/forums/topic/462362-oil-cooler-too-eager-faulty-thermostat-or-incorrect-temp-sensor-location/
I most certainly would not recommend the Mocal sandwich plate or the Driftworks kit overall: http://www.driftworks.com/thermostatic-oil-cooler-kit-for-all-engines.html
  • The Mocal plate doesn't have ports for sensors and it takes heaps of mucking around to work around that. Also the internal thermostat-controlled bypass port is tiny, meaning that the majority of the oil always goes through the cooler, irrespective of temperature, which is not ideal for a street car especially in Vic.
  • The Driftworks kit comes with prefabricated hoses. They're really heavy duty but with scrimped fittings, so you can't change them or shorten the hoses. The main issue is that whilst one end has a 90-degree fitting the other is straight, and is really tough to route past the alternator in the RB25DET. In my install we had to bend the hoses too tight and they started leaking from the fittings -> new hose time.
The Mocal core is ok.
Also do not buy an oil cooler kit second hand. I can't stress this enough. I saw this advice before buying, chose to ignore it, and have paid the price many times over in headaches and labour.
If I had my time again here's what I would get, all new parts:
  1. The Greddy/Grex sandwich plate. It's a better design than the Mocal with two sensor ports, a larger thermostat bypass port, and 45-degree angled in+out for the lines.
  2. Quality core: Setrab, Mocal or similar
  3. Quality lines and fittings: Speedflow, cut to suitable lengths and professionally assembled. I'd also get the Nomex/Kevlar type to save having to pad braided lines to prevent scuffing.
I'd also install the cooler core underneath the right headlight if at all possible (mine's between the intercooler and radiator) for two reasons:
  1. Less impact on water temps in hot weather when pushed hard
  2. Ability add blocking plate over oil cooler without impacting other cores
On a more positive note, my setup works well, out at Calder Park in February (mid 20C's) I never had to back off because of oil temps, and only a couple of times because of water.
Hope this helps.
  • Like 1
 Share
    • Hi Dave and welcome!
    • I have S15 helical too. It is a bit worn. I think the drive behaviour you describe is related to this wear. Wear of helicals is something that no-one seems to have paid a lot of attention to, but now that they (as in original Nissan ones) are all a bit old - we're starting to  see the consequences. The ends of the helical spurs wear into the casing. That's where they perform the braking that diverts torque. Some of the more modern helical designs have proper wear surfaces introduced there, but the Nissan ones are just steel on steel (or iron).
    • I've had a range of rear diff centres - open, viscous, helical, mechanical, welded, etc.   I can't go past a refreshed factory 32 gtr centre for consistent lock and street driving. The next step up for me would be the nismo 1.5 way , which likely suits you better as track sounds like the focus. Will chatter in carparks but its not the worst.   I have never tried a quaife rear diff, an option I've looked at before and might be one for you .....   Currently playing with an S15 centre at the moment and I hate it.  The transition from single wheel spin either side is just weird.
    • Honestly, I did think the PDM could do it and thought Haltech told me the pump didn’t like it. But after re-reading the emails and comments above, I clearly misunderstood lol.
    • I also run a CD009. I'm currently on a 4.08 and it's not great. I originally intended to run a 3.3 but had issues, more on that later. I'd stick to anywhere between a 3.3-3.7 as found in the 350z.  As for brands of ring and pinions, absolutely stay away from Speedtek. They are absolute garbage. See my build thread for more information on that. I went through two of there 3.3's and both had bad runout. They were paperweights and they have still yet to refund me.  I ended up putting in a Nissan 4.08, which was better then the original 4.36 but is far from ideal. I'm going to pop a 3.5 in this winter. I'd stick Nissan. I've also heard of a company "Neat Gearboxes" that makes them. Haven't tried them, but they can't be worst then Speedtek...
