Hi guys is there a write up on how to remove the standard head unit in an M35? I've done searches but can't find anything. I've found some V35 write ups/videos but they don't seem right with the M35. They say to remove the silver panel where the clock is in a V and where the time and A/C display is in an M then remove the panel under the steering wheel and undo a couple of screws. Is this right for a Stagea? It doesn't seem right to me but hey I'm probably wrong.
Thanks and merry Christmas
https://www.sau.com.au/forums/topic/461861-m35-head-unit-installremoval/
Glove box out, panel under steering wheel out, clock panel out, gear knob off, center console out, the two panels with pockets on either side of center console out.. i used the v35 youtube vid for guidance and got it pretty quick
Edited by stripey
Just something I had trouble with, double check your harness before plugging it
DONT NOT GROUND THE RED/BLUE WIRE!!!! it is actually the cabin lights/parkers/tail lights!!!
I blew up the fuse by doing so with the harness I got.
Also, not sure if you got a metra kit for the double din conversion but make sure you have the air con control board as the oem one is most certainly just one big board shared with the stereo.
Had to take everything apart after I got one to install it and that's not something you want to do 3 times like I had to ;)
I'm not going double din, staying single din. Isn't the aircon separate to the stereo? I've only got a normal single din with gauges on top then I think aircon on top of that...
Got the head deck out and can see what you mean now. They should sell these at autobarn shouldn't they?
Also, what's outlined in the pic below I assume is the aux in? Does autobarn or similar sell an adapter to change what used to plug into that to a 3.5mm head phone jack for the aux in on new head deck?
    • Haha yea it's a bit of a weird setup at the moment, just wanted to make sure I sorted out any headaches before dyno day. At the moment I've changed the exhaust manifold, turbo and downpipe, 460lph fuel pump and rising rate reg as well as the previously mentioned headstuds and gasket. The nistune was already mapped for the car as it was and drove around for a few months no worries. The plan is to run flex fuel hence the big pump, which I've wired direct to the battery through a relay to avoid voltage issues.
    • Um. Was the ECU the same as the one previously there? I know R33's needed R32 GTST ECU's or other tomfoolery to run Nistune. This is such a wild setup. Most people would plumb in the turbo then not drive the car (i.e tow it to a tuner). What's actually changed since it last ran?
    • I'm a bit stuck with this one fellas, I recently decided to undertake a turbo conversion on my GTS-4, ended up pulling the motor to replace all the seals and do an mls head gasket and arp head studs while I was at it. Everything has gone according to plan, no oil or coolant leaks, compression checked out, and decided to give it a test before I book it in for a tune As it stands right now, the turbo only has oil lines plumbed so that I don't put boost into my untuned engine, and I'm using the factory GTS-T crossover pipe with a maf and poddy as a temporary intake. The car starts with relative ease and idles amazingly, however as the title suggests it really doesn't want to rev up, runs very smooth but almost feels choked out and unresponsive to the throttle, almost like it's running lean or something? I've triple checked my vacuum lines and timing with a timing light, injectors haven't been touched as of yet to avoid flooding the engine and worked perfectly beforehand, new plugs and coilpacks, I've even unbolted the cat just to see if it spontaneously collapsed, no dice The car currently has a nistune r32 gtst ecu installed so I have no way to check for fault codes. At this point I'm a bit stumped. Is this normal behaviour for a car with a turbo bolted onto the exhaust going nowhere? I'd imagine the turbo wouldn't cause this much restriction in the exhaust without the boost going through the intake. Any ideas? If necessary I can link a video of how it responds to full throttle while in neutral.
    • Insert tab A into slot B?
    • Instructions seem simple enough to understand.....
