R32 Gts-t Nissan Skyline Parts Rb20det Pimpama Se Qld
All parts to suit R32 GTS-T NISSAN Skyline parts RB20DET unless otherwise stated.
Body parts matt black.
Tail lights $40 pair
Splitfire performance air filter good condition not oiled $20
RB25DET Turbo $150
TYPE M LSD Diff $100
TEIN Coilovers $400
heater core $20
RB20DET STD ECU $50 can include plug and short loom
front strut brace $80
driveshafts $80 pair
HKS Turbo timer direct plug in $40
side mirrors electric and foldable $20
rear bumper $20
dump pipe back exhaust with cannon $50
front guards with indicator compliance holes $50 each
bonnet $20
bootlid $20
alternator $50
FULL RACE BUILT RB20DET LONG ENGINE $500 - yes not a typo done minimal work
gearbox $50
heavy duty organic clutch $50
bosch motorsport race fuel pump and surge tank $200
walbro in tank race fuel pump $100 still wet with fuel
fuel tank still sealed and fuel wet $50
Thermofan $70 fits standard three core radiator
No swaps. Cash only. Pickup only. If it is not listed it probably isn't available bar the small things - enquire then.
Sold the car and clearing out shed.
Plus miscellaneous parts from a shell. Everything stripped out. Ask me what you are chasing. No accident damage.
Prefer email. If you don't leave a phone number you may be ignored.
[email protected]
Pimpama SE QLD
Edited by immelmann
  • 2 months later...
    • Sadly I can confirm if you are actually seeking to drift, you will quite easily spin up one wheel. Even if you're going in a straight line. I am not entirely sure of the metrics/terminology here but there's only a certain amount that the helical will actually spin both wheels. I've seen it on video with my own car where two lines of smoke switch over to just one after you really get in to it. Unlike with a clutch diff where you can keep your foot planted until the car regains grip, in my experience with the helical you want to be utilizing traction control allowing LIMITED slip or lifting (partially) when you start to spin up both tyres with a Nissan helical. Which makes them pretty sub optimal for drifting duty. That said... this is probably a helical on numbers alone. Just put the Kazz in
    • Let's just fix the problem by f**king the rest of the gearbox.
    • Unlikely, as per Greg's post. This is not helical diff behaviour unless one wheel is up off the ground. Shimming what? You don't "shim" a mechanical LSD. Probably not in the sense that you have heard of people "shimming" a diff. And the process that Nissan f**kwits call "shimming" a diff involves super-preloading a VLSD cartridge against the side of the diff to create a friction/wear point (in a place that it wasn't supposed to have one) to make the sloppy, useless, viscous diff into a hybrid viscous/mech abortion. In case it isn't clear, I consider the process to be stupid. Nike.
    • How much does the shifter move when the car is in gear with the engine off? If it is more than about 1cm you need to replace your shifter bush. Your shifts will just get crunchier, not faster, with a short shifter unless you also rebuild the whole box
    • I should video mine, will prob do it tomorrow    Between 1st and 3rd, you could fit another two gears. That is how loose and wobbly it is   horrible:(
