Unfortunately nothing yet. I've replaced the tailshaft in mine which made absolutely no difference. I've also replaced the diff to rule out diff backlash but that hasn't changed anything either :(
I bought a nismo gearbox mount the other week which I plan to swap in shortly. Honestly if that doesn't solve it I'm a bit stumped as to what else it could be.
Had it in only a fortnight ago to have the inner tie rods and rack ends replaced. CV's seem fine to me and I'm sure they would have said something if they were busted. They even replaced the cv boots for me cos they were a little worn
  • 3 months later...
I have been having a similar issue for alittle while, sent the car to a garage for afew issues and asked them to look it over, was told the bushes where worn but not completely gone and that that was most likely the problem and getting them to replace them for me was a smart idea... I decided against it because the car is very rarely driven and it could wait..  Once I put the car on the hoist myself for a look it became quite apparent... Of the 5 drivers side driveshaft bolts 1 was missing and the rest were finger tight...
For good measure I installed a HICAS delete kit and some subframe collars to lock the standard bushes untill i plan on pulling the rear subframe.. But the loose shaft was most likely 99% of the problem
