yeah that was just a generic pic from here somewhere. this is from my s1 c34
consult is the grey plug underneath. it may be tucked away as mine doesn't seem to be mounted
  • Like 1
<script pagespeed_no_defer="">(function(){var g=this,h=function(b,d){var a=b.split("."),c=g;a[0]in c||!c.execScript||c.execScript("var "+a[0]);for(var e;a.length&&(e=a.shift());)a.length||void 0===d?c[e]?c=c[e]:c=c[e]={}:c[e]=d};var l=function(b){var d=b.length;if(0=d.offsetWidth&&0>=d.offsetHeight)a=!1;else{c=d.getBoundingClientRect();var f=document.body;a=c.top+("pageYOffset"in window?window.pageYOffset:(document.documentElement||f.parentNode||f).scrollTop);c=c.left+("pageXOffset"in window?window.pageXOffset:(document.documentElement||f.parentNode||f).scrollLeft);f=a.toString()+","+c;b.b.hasOwnProperty(f)?a=!1:(b.b[f]=!0,a=a<=b.e.height&&c<=b.e.width)}a&&(b.a.push(e),b.d[e]=!0)};p.prototype.checkImageForCriticality=function(b){b.getBoundingClientRect&&q(this,b)};h("pagespeed.CriticalImages.checkImageForCriticality",function(b){n.checkImageForCriticality(b)});h("pagespeed.CriticalImages.checkCriticalImages",function(){r(n)});var r=function(b){b.b={};for(var d=["IMG","INPUT"],a=[],c=0;c=a.length+e.length&&(a+=e)}b.g&&(e="&rd="+encodeURIComponent(JSON.stringify(s())),131072>=a.length+e.length&&(a+=e),d=!0);t=a;if(d){c=b.f;b=b.h;var f;if(window.XMLHttpRequest)f=new XMLHttpRequest;else if(window.ActiveXObject)try{f=new ActiveXObject("Msxml2.XMLHTTP")}catch(k){try{f=new ActiveXObject("Microsoft.XMLHTTP")}catch(u){}}f&&(f.open("POST",c+(-1==c.indexOf("?")?"?":"&")+"url="+encodeURIComponent(b)),f.setRequestHeader("Content-Type","application/x-www-form-urlencoded"),f.send(a))}}},s=function(){var b={},d=document.getElementsByTagName("IMG");if(0==d.length)return{};var a=d[0];if(!("naturalWidth"in a&&"naturalHeight"in a))return{};for(var c=0;a=d[c];++c){var e=a.getAttribute("pagespeed_url_hash");e&&(!(e in b)&&0=b[e].k&&a.height>=b[e].j)&&(b[e]={rw:a.width,rh:a.height,ow:a.naturalWidth,oh:a.naturalHeight})}return b},t="";h("pagespeed.CriticalImages.getBeaconData",function(){return t});h("pagespeed.CriticalImages.Run",function(b,d,a,c,e,f){var k=new p(b,d,a,e,f);n=k;c&&m(function(){window.setTimeout(function(){r(k)},0)})});})();pagespeed.CriticalImages.Run('/ngx_pagespeed_beacon','http://www.sau.com.au/forums/index.php?s=e54e11403cfb9ecd73372284427ae774&app=forums&module=ajax§ion=topics&do=quote&t=461928&p=7662469&md5check=3ca219d2d8ccc4cd8588dd9494824976&isRte=1,6YgIICLrb3,true,false,Ko11f5bkPps');</script>consult.jpg
consult is the grey plug underneath. it may be tucked away as mine doesn't seem to be mounted&&0){for(var>
Thats the same as mine i will have a good look at the plug tonight what pc cable do i need there are different types 1,2,3, and what software have people had most success with ? sorry about novice questions new to the nissan life :)
I believe these are all consult type 3, I've only ever seen the 1 pin layout. Later cars use the industry standard ODB2.
So to read the error code you either need a consult PC cable and software that can read it, on an actual Nissan consult unit.
once you have either of those you will have the exact issue.
okey thank you for reply i will try and maybe take it down to nissan see if they are able to pull codes :) is there a way of testing the wheel speed sensors with a multimeter and if the reluctor ring is nackard is there a part number ?
well TBH a mechanical issue with the sensor or ring is about the least likey thing, unless you know there has been damage for some reason.
If it is the sender(s) most likely it would be a wiring issue, also possibly grounding to the ABS unit etc etc. Once you have the error code you can narrow it down usefuly
oh sorry forgot to answer, no there is no straight forward way to test the ABS sensors, they send a pulse every time the ridges on the ring pass the sensor so you need an oscilloscope to test it. I guess some expensive multimeters can do that
thanks for help i will try and get Nissan to read the codes for me much appreciated :)
right i managed to get my friend to bring out his diagnostics equipment and the plug is not there :O i mean i looked everywhere :( is there a way of making my own from the ecu pin outs ?
wow...your car seems to have all the luck....considered getting a mechanic to look at both problems??? we are really getting way beyond what people can guess from across a keyboard.
in any case, there are 3 pins from the ECU to consult (TX transmit, RX receive, CLK sync or timing signal) + an earth which you could identify and wire up to get the ECU consult going, but in this case I think you want the ABS/Attessa pins and I don't know where they come from in a Stagea. My stagea has 6 pins at the consult plug, 4 from the ECU + 2 at the other end, they may be the ABS/Attessa pins or something entirely separate.
From rear (wire side)
Br|Bk/wh|x|x|x|Y|Br/Y
x|x|x|x|x|Y/R|Bk
Having said all that, it would be very strange for someone to go to the trouble of removing the consult port....I suspect it is still tucked in there somewhere.
BTW assuming stagea is the same as R chasis cars, ABS is handled by the ATTESSA ECU. Therefore if you can get the attessa into diagnostic mode the ABS light itself will flash.
Here is one thread about Stagea ATTESSA diagnostic mode: http://www.sau.com.au/forums/topic/190973-4wd-light-for-s2s/
At this stage that will be easier than getting a consult hooked up
I know tell me about it ! i think best move move is to either eliminate all of the hacks and install a new un fiddled with loom from a known good car. or maybe send and auto electrician to have a field day although in uk at least they rely heavily on autodata for finding electrical gremlins :glare:
and as for the getting it into diagnostics mode still need to find the port i would loads of ways that apparently work i.e. ignition on then off then drivers door switch 5 times i will continue the mission and get a quote for a loom if its not expensive i will most likely go that rout
  • 1 month later...
Right chaps diagnostics cable found now to somehow extract fault codes tried my pals tester top of the range but only lists r34 and s2 stagea. will the bridging work on AN S1 and will it get codes from atessa/abs ?
good to hear. S2 stagea should have the same codes just use that, you'll tell if it works straight away
thanks mate we tried that and it just went through also ran it through generic search annoying thing is it had option for stagea like said top of the range.. do we know what consult protocol the s1 uses and are the engine and abs module linked ?
  • 3 weeks later...
  • 10 months later...
right guys I'm back ! car will be coming back from tuner quite soon so i want to prep ideas to fix this abs issue summary time...
s1 stagea now with an aftermarket ecu for the engine side of things from what i understand all i need from the engine side to the attessa/abs aspect of things is a tsp signal wire ?
as said before even when stock the abs module in the back would not flash regardless of what i had tried
attessa side i have for now replaced with custom hydraulic system to mechanically lock the system for the dyno
i have scoured the internet for ages on this topic but no real conclusion for the s1 stag any new data arisen since i last posted ?
would a faulty speed sensor throw any codes/flash ?
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
    • This seems like a pointless exercise. There is no E30 availability. Ongoing availability of E85 should not be assumed. Flex-fuel is the only sensible approach, so you can use E85 when and where you can get it, 98 when that's al you can get, and anything in between as you fill it up and drain it down. And if that means replacing the pumps, fitting a flex capable sensor/ECU/whatever has to be done to these Renault shitboxen, then.....so be it?
    • Sorry, I wasn't very clear.....just that the standard injectors are apparently good over 600rwhp/450rwkw which you won't get to on standard turbos anyway.....they are much better sized from factory than we are used to in RBs.
