GSX-R35 Posted December 29, 2015 Share Posted December 29, 2015 Now that we've gotten in the extended oil sump for the new RB26 that's going into my R32 I'm trying to figure out what parts we'll need to swap the front diff to the new pan. Can anyone tell me if there's a rebuild kit or install kit for the RB26 front diff and where to get them? Thanks in advance for your help. Link to comment https://www.sau.com.au/forums/topic/461930-whats-needed-for-an-r32-front-diff-swap/ Share on other sites More sharing options...
KiwiRS4T Posted January 2, 2016 Share Posted January 2, 2016 Now is the time to replace it with a Quaife LSD http://www.sau.com.au/forums/topic/440091-rebuild-gtr-front-diff/ but if you decide to keep the open diff you can just put new seals in or go to town with all new bearings. I have a list of the bearings with Nissan Part numbers but I can't remember what modfel GTR they fit. If you quote just one part number to a Nissan dealer they should be able to tell you. Front diff bearings and seals text.doc 3 Link to comment https://www.sau.com.au/forums/topic/461930-whats-needed-for-an-r32-front-diff-swap/#findComment-7660823 Share on other sites More sharing options...
GSX-R35 Posted January 3, 2016 Author Share Posted January 3, 2016 Now is the time to replace it with a Quaife LSD http://www.sau.com.au/forums/topic/440091-rebuild-gtr-front-diff/ but if you decide to keep the open diff you can just put new seals in or go to town with all new bearings. I have a list of the bearings with Nissan Part numbers but I can't remember what modfel GTR they fit. If you quote just one part number to a Nissan dealer they should be able to tell you. Thanks for the info! I'm not sure my budget has room for a front diff upgrade currently but I'm definitely considering it. Link to comment https://www.sau.com.au/forums/topic/461930-whats-needed-for-an-r32-front-diff-swap/#findComment-7661149 Share on other sites More sharing options...
sneakey pete Posted January 4, 2016 Share Posted January 4, 2016 Doing mine at the moment, that picture shall be useful for me also, thanks.Its a hard one with the diff upgrade if the budgets are marginal. It is a big chunk to add do your budget, but then again its another few thousand bucks to pull the engine to do it again in the future. Link to comment https://www.sau.com.au/forums/topic/461930-whats-needed-for-an-r32-front-diff-swap/#findComment-7661337 Share on other sites More sharing options...
R31Nismoid Posted January 7, 2016 Share Posted January 7, 2016 What are you doing with the car? Circuit, street (runs or hills) or drag? How much power? Either way, change it now. If it's anything that is going to involve RPM launches - so drag, and over 300rwkw/400rwhp... Then you absolutely MUST change it now. If you've spend big $$$ on a after market sump, you do NOT want the stock front diff blowing as it will take out some/all of the front sump if it fails badly enough which is anyone's gess. It happened to me and a few others over the years, so by spending now and doing it right, you'll thank yourself. Its not "so much" needed for circuit but honestly, the improvements you get from doing it are IMO, one of the best value vs gain mods EVER. I've said it before that if I had my time in a GTR again I would do the following - Small turbos/basic 300rwkw setup. - Diffs, both - Transfer Case Rather than rebuilding motor and doing for 550hp+ as the driving experience/speed of the car is just so greatly improved it's outta this world levels of difference. I would say Nismo for Drag and Quaife for circuit seems to be the consenses. That said I used my Nismo to blistering effect in 80-120km/h motorkhana based stuff, suited my driving style. 2 Link to comment https://www.sau.com.au/forums/topic/461930-whats-needed-for-an-r32-front-diff-swap/#findComment-7663442 Share on other sites More sharing options...
GTRPSI Posted January 8, 2016 Share Posted January 8, 2016 Dont forget that most aftermarket diffs are a little larger in casing size and wont fit into the front diff case without some grinding in the right areas, best done when its all apart when its easier to get in there with a die grinder and to clean out all the alloy shavings. We went drag direction and installed a Cusco setup as a one way diff. Link to comment https://www.sau.com.au/forums/topic/461930-whats-needed-for-an-r32-front-diff-swap/#findComment-7664255 Share on other sites More sharing options...
sneakey pete Posted January 13, 2016 Share Posted January 13, 2016 Have a Quaife front diff center sitting at my feet as we speak, doesn't look that much larger. Proof will be once i get it out i suppose. Link to comment https://www.sau.com.au/forums/topic/461930-whats-needed-for-an-r32-front-diff-swap/#findComment-7666832 Share on other sites More sharing options...
Piggaz Posted January 13, 2016 Share Posted January 13, 2016 You won't regret that, Pete! Link to comment https://www.sau.com.au/forums/topic/461930-whats-needed-for-an-r32-front-diff-swap/#findComment-7666834 Share on other sites More sharing options...
R31Nismoid Posted January 13, 2016 Share Posted January 13, 2016 Hurry up and get your car together, I'll come to Syd and go for a buzz (and of course sink a pile of piss somewhere) 1 Link to comment https://www.sau.com.au/forums/topic/461930-whats-needed-for-an-r32-front-diff-swap/#findComment-7666949 Share on other sites More sharing options...
R31Nismoid Posted January 13, 2016 Share Posted January 13, 2016 But yes, 100% - you will NEVER regret a front diff upgrade - as long as you have done the rear.Simple some of the best mods you can do to a GTR if you are aiming to enjoy the driving of it 1 Link to comment https://www.sau.com.au/forums/topic/461930-whats-needed-for-an-r32-front-diff-swap/#findComment-7666950 Share on other sites More sharing options...
Piggaz Posted January 13, 2016 Share Posted January 13, 2016 But yes, 100% - you will NEVER regret a front diff upgrade - as long as you have done the rear. Simple some of the best mods you can do to a GTR if you are aiming to enjoy the driving of it Even without doing the rear, it was one of, if not the best mod I did. Front, rear, transfer was my order. It just gets better every time! Link to comment https://www.sau.com.au/forums/topic/461930-whats-needed-for-an-r32-front-diff-swap/#findComment-7666989 Share on other sites More sharing options...
GSX-R35 Posted January 15, 2016 Author Share Posted January 15, 2016 Thanks for the replies everyone. I ended up getting a Nismo LSD. Although the Quaife is the better unit for road course no one carries it here in the US and at over twice the price of the Nismo I couldn't justify it anyway since my R32 will mainly be a weekend/show car and will probably only see the track on a very rare occasion. Either way, I figured if the Nismo was good enough for their JGTC cars then it'll do fine in my R32 lol. 1 Link to comment https://www.sau.com.au/forums/topic/461930-whats-needed-for-an-r32-front-diff-swap/#findComment-7667892 Share on other sites More sharing options...
HarrisRacing Posted February 2, 2016 Share Posted February 2, 2016 Thanks for the replies everyone. I ended up getting a Nismo LSD. Although the Quaife is the better unit for road course no one carries it here in the US and at over twice the price of the Nismo I couldn't justify it anyway since my R32 will mainly be a weekend/show car and will probably only see the track on a very rare occasion. Either way, I figured if the Nismo was good enough for their JGTC cars then it'll do fine in my R32 lol. Look at my build for pretty detailed pictures. It should be noted that I cut my own shims, but buying factory would have been easier (beware there are a LOT of factory shims). Here's a link http://www.sau.com.au/forums/topic/447384-r32-gtr-build-in-usa/?p=7559306 Link to comment https://www.sau.com.au/forums/topic/461930-whats-needed-for-an-r32-front-diff-swap/#findComment-7676704 Share on other sites More sharing options...
GSX-R35 Posted February 3, 2016 Author Share Posted February 3, 2016 Look at my build for pretty detailed pictures. It should be noted that I cut my own shims, but buying factory would have been easier (beware there are a LOT of factory shims). Here's a link http://www.sau.com.au/forums/topic/447384-r32-gtr-build-in-usa/?p=7559306 Thanks for chiming in. I saw your thread before and that's partly why I got the Nismo LSD since like you I couldn't find a better alternative that was available to someone in the US. I'm waiting to see what my friend finds when he dives into the swap but yeah it's amazing how many sizes of shim Nissan lists for the LSD lol. Link to comment https://www.sau.com.au/forums/topic/461930-whats-needed-for-an-r32-front-diff-swap/#findComment-7677515 Share on other sites More sharing options...
HarrisRacing Posted June 22, 2016 Share Posted June 22, 2016 FYI. Now that my car is on the road and I have about 1000 miles on it, I'll comment on the Nismo Diff. I LOVE IT! Super quiet, after about 500 miles of street driving any noticeable chatter has gone away. There is a slight drag when pulling into driveways or at low speeds and extreme steering angles, but that thing grabs like a cat on carpet on throttle. You'd better have the wheel pointed where you want the car to go on throttle because it almost pulls the car in the direction when it hooks. Incredible unit for the money. Link to comment https://www.sau.com.au/forums/topic/461930-whats-needed-for-an-r32-front-diff-swap/#findComment-7749687 Share on other sites More sharing options...
Piggaz Posted June 22, 2016 Share Posted June 22, 2016 Front diff... Best mod ever!!! Link to comment https://www.sau.com.au/forums/topic/461930-whats-needed-for-an-r32-front-diff-swap/#findComment-7749703 Share on other sites More sharing options...
WHITER33GTS-T Posted July 9, 2016 Share Posted July 9, 2016 So a quaife front diff is the go.? Link to comment https://www.sau.com.au/forums/topic/461930-whats-needed-for-an-r32-front-diff-swap/#findComment-7755796 Share on other sites More sharing options...
niZmO_Man Posted July 10, 2016 Share Posted July 10, 2016 Only two ways to find out. Link to comment https://www.sau.com.au/forums/topic/461930-whats-needed-for-an-r32-front-diff-swap/#findComment-7755989 Share on other sites More sharing options...
