-- I will post photos when I get to my home computer --
It is currently priced at $17,500
I am the only Australian owner of this R34 and have had since it had only 20,000km on the odometer.
It's always been run on 8psi on the road.
It has made 200rwkw on the dyno running 10psi.
It has many many mods - some of which I'm bound to forget but let's give it a go:
ARC intercooler
HKS Silent high power catback exhaust
3" from the turbo split dump and high flow cat
HKS EVC
Apexi timing controller
Apexi SAFC
HKS boost gauge
Bosch fuel pump
Apexi pod filter
Aftermarket coil packs
Tein street coil overs - complete service only a few months ago
Front and rear strut bars
Bushes, tie rod ends etc
17" Driftek gloss black rims
Overall I've spent well over $20k on this car and have had it for around 7 years now.
It runs great - there are no issues whatsoever! I'm selling it as I would like to upgrade my motorcycle.
Always serviced regularly - 5k - sometimes at home and sometimes at a shop (CNJ motorsports)
This has got to be one of the cleanest R34s getting around.
There are a couple of hail dents on the bonnet.
The interior is in great condition with no rips or tears etc.
Any questions - feel free to ask.
Edited by so_tred
https://www.sau.com.au/forums/topic/461935-white-r34gtt-qld/
  • 5 weeks later...
  • 1 month later...
    • If doing that ^, I'd take the idle up valve out and plug the hole in the pump.
    • You can try capping the power steering idle up valve at both ends if it's old. The valve and the intake manifold. That is something that is known to fail in Toyotas with age and it will suck power steering fluid into the intake and burn it in the engine which can cause issues. Then bleed it again with engine off first. Do like 30+ lock to lock turns with the front wheels off the ground.
    • Hi Brent, I am wondering if you ever worked this out? I have upgraded this unit to a newer one and everything works bar the reverse camera, so i really want to know what plugs are what so I can patch the camera through. many thanks in advance Mike
    • Once you have to get up in the morning and be useful, you suddenly value sleep it turns out :p
    • Update:   smoke test all pipes no issues cleaned reservoir   fluid put in ( dexron 3 atf)   steering turn side to side and could hearing  gurgling from steering rack which I assumed was air lock, opened one of the steering rack connections and could see loads of air getting pushed out( not sure if you meant to do that / whether it will re introduce air into system)   anyways, loads of side to side sound was gone. Turned car on, pump was slightly ( barely) wining so turned side to side few more turns and fluid level when car on was almost none in resorvoir which I guess is normal if car is one. Turned car of and fluid was gushing out. Almost 200-300cc was pushed out. Repeated engine off side to side followed  by engine on and same result       going mad now. It seems system is either sucking air in whilst on or there is tons of air which I am not giving it enough time to bleed. Thoughts?   would it work like brake caliper if I open steering rack copper pipes and let gravity pull all air out?   or maybe have a restriction somewhere? What is the red circled item, could that be blocked? It i
