Nissan Skyline R33 GTS-T "turbo" 93mdl $6,500
NO RWC- can point you in the right direction
REG till april 2016
Auto
203,000kms serviced every 5k have receipts of all works done to the car since I've owned it.
Front mount intercooler
Trans cooler
Rear strut brace
Splitfire coil packs
Aftermarket exhaust,straight pipe & dump pipe
GFB response blow off valve
K&N panel filter "have apexi pod filter "new" to give to buyer with pod box.
Gates racing timing belt kit & drive belts.
full bodykit
19inch GMAX sports deep dish rims
rear tyres Falken 453 - 265/30/19 90% tread front tyres lexani 235/35/19 80% tread
Have original rims with brand new tyres to give to buyer
Original emergency flare still mounted in car "see picture"
factory sunroof
Factory "extra" stainless door seals "see picture
standard turbo & boost 7psi
cold air con
tinted windows
Heres a list of works that have recentley been done in the last 3 months "5,000km"
Gates racing waterpump
Gates racing drive belts
Standard plugs gapped to 0.8
Thermostat
all new water lines
second hand intake manifold
rocker cover gaskets
oxy sensor
fuel pump
fuel regulator
fuel filter
all new vaccum lines
ECU reset
Reason for selling : baby on the way - In saying that I'm in no rush to sell... so stupid offers will not be considered.
Car runs perfectly, its a regretful sale and a great summer cruiser.
NO TEST PILOTS
NO SWAPS unless you have a FORD TERRITORY ONLY!!!
CAR will need the following:
front wheel bearings
rear bushes
new relay for passenger window
There is a small dint and scratch on rear bumper *see picture
contact chris 0431 299 956
post-140188-0-56405600-1451526709_thumb.jpg post-140188-0-46270800-1451526808_thumb.jpg post-140188-0-54416100-1451526836_thumb.jpg post-140188-0-48902600-1451526875_thumb.jpg post-140188-0-63352200-1451526924_thumb.jpg post-140188-0-01554100-1451526996_thumb.jpg post-140188-0-66230000-1451527083_thumb.jpg post-140188-0-52413400-1451527109_thumb.jpg post-140188-0-09772700-1451527154_thumb.jpg post-140188-0-20285200-1451527183_thumb.jpg post-140188-0-96852300-1451527215_thumb.jpg post-140188-0-50563500-1451527245_thumb.jpg
    • See my post here If you put the Haltech in, you won't have to worry about any of that. And, in case you're worrying about my lack of credentials in doing your exact swap, I put a Neo in an R32. There has never been a stock boost solenoid near my car and the Neo's ECU has never cared. Nor should it, because it is electronically impossible for it to care.
    • That's 100% wrong. Did you wire in the boost sensor? If you did not, then that is 101% your answer. Neo ECUs do suck a bit.
    • Hello, I'm trying to make this thread basically the thread with all the answers to common questions regarding specifically the RB20 DE NEO + T engine, that comes in the R34. Answers will and only should be provided by those who have done this conversion or actually have some relevant real life experience please. Please feel free to ask questions in the comments if you have any so other members can answer. I feel like this thread is really needed, especially with more Americans buying (unknowingly going to regret it too) rb20 neo r34s. My first question being - What do you guys use for tuning? I have purchased a haltech elite 2500 Plug and play kit for the rb25det NEO because the ecu plug is the same, but I am unsure if any of the pins would need to be repined to match. Second question that I see asked very often - After this conversion, did you install the boost solenoid/ actuator? I see many people doing a + T setup on their rb20 NEOs while running stock RB25DET NEO ECUs with no tune. I am wondering how they are going about doing that and consistently abusing the car because many of these people have had these untuned setups running for a very long time. That was my original plan, but my engine cuts out at 5 psi of boost using the stock ecu with no tune and no boost solenoid/actuator.
    • interesting. ive read and heard otherwise over the past year. ive been doing this +t conversion on a rb20 neo using all oem rb25det neo parts including the ECU, and im having engine cut out issues when I hit around 5 psi of boost. Everywhere/everyone ive asked has told me its because I never wired in a boost solenoid/actuator to the ecu, so the ecu isn't getting the right signal once it hits 5 psi of boost, causing the engine to get shut off.
