Hi guys and girls, up for sale is my 1996 180sx
RARE AND COLLECTORS ITEM IMMACULATE CONDITION INSIDE AND OUT
NO RUST
STRAIGHT CHASSIS
A TRUE HEAD TURNER
Open to offers NO LOWBALLERS!!!
Has a s15 sr20de VCT engine with 115xxxkm (has a black s14 rocket cover)
Chasis has 196xxxkm
FULL FLUID SERVICE including gearbox,engine oil, radiant fluid, brake fluid all replaced by GWORX on the 9/11/2015
S15 Spec R rear subframe
5 stud conversion
S15 Spec R breaks and Hubs
Hurricane Headers, and customs exhaust system cat back from Radiant Exhaust Laverton
Wiring, Loom and ECU was done by GWorx
5 Speed Gearbox
Strut Brace
Type X lights
Uncracked Dash
Aftermarket Bodykit
Body is straight and has been registered before
A few other goodies are there just cant think of any on the top of my head.
I have spent 12k in total on parts and labor to get the car in perfect working order
Currently missing oxy sensor and airbox
Also currently unregistered but can be registered
Has been resprayed in midnight purple, no dents or rust..most immaculate 180sx in victoria
you won't find a better one than this
also has a GENUINE TYPE X FRONT BAR, rare as unicorn farts now
still needs some work done
needs a stock airbox
radiator shroud
oxy sensor
battery relocated to the front
and new lights
PRICE IS 16K ONO
LOBALLERS WILL BE IGNORED
willing to throw in some slide worx coilovers for the right price
paid 1.5k for the slideworx coilovers (brand new)
here are the photos of before and after the respray
  • Like 1
https://www.sau.com.au/forums/topic/461962-fs-1996-180sx-na-vic/
how can you justify your price?
my brother is contemplating asking 14k for his full house 280kw 180sx with well over 40k spent on it... and is still unsure that he will get that price.
full of confidence, you are.
  • Like 1
But has spent 12k on parts. Everyone knows you get all your money back on the parts you put in.
Can get much better cars for less money. By the time you actually get this running on the road it will be near 20k
and all this time i was lead to believe modifying cars is an investment
Non turbo 180sx for 16k? Sheesh
I see you say "bae"
Also you said it isnt regod?
you don't like the price don't buy it...simple....this is my car and it will be priced to how i want it to be, and to be honest here...it's are rare car so i think it's pretty cheap
yeah it's regoed now....garage worx gave me the rwc
say what you like mate....it'll smack your gtr any day, rolling or launch
  • Like 1
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
    • Dort sounds above 3k rpm are dorty 🤣 I might krinkle black the alloy 🤔
