Qld Raceway Sprint Track - 59.30 sec
Qld Racway Clubman Track - 1:02.25 sec
Qd Raceway National Track - 1:25.61 sec
Can anyoen clarify the number of circuit formats you guys use up there...it seems i have made a mess of the times as i didnt realise there was 3?!?!?! Is there more?
This was from a *very* long time ago:
SAU Nickname: 46n2
Car Make and Model: R32 GTST
Circuit Name: Qld Raceway, sprint circuit
Lap time: 1:07.78
Modifications
Engine:RB20DET
Power: dyno'd at ~110rwkw a few months before before hitting the track
Suspension: HKS non Adjustable coilovers, Front Hollow Swaybar
Other Mods: None - stock right down to the exhaust :D
Tyres: Ventus (cheapo rubber that came with rims) - useless with no grip
Brakes: RB74 Front, rear standard, rotors standard
First time with new setup
SAU Nickname: Stealth
Car Make and Model: R33 SII GTST
Lap time: 1:00.95
Modifications
Engine:RB25DET
Power: dyno'd at 347hp atw
Suspension: Tein Adjustable coilovers, Nismo Swaybar
Other Mods: Race pipe, GT35/40 int w/g turbo, intercooler, PwrFC,
Tyres: Bridgestone Potenza RE540s
Brakes: bendex ultimates Front, RB74 rear, rotors standard
__________________
Updated Winton time - 4.5s off my previous PB to a 1.35.2. Very happy. (updated original post)
Mostly due to upgraded brakes and modified transfer case. Anyone with a GTR that's keen on track work the upgrades to the transfer case is one of the best mods I have ever done to my car.
ahh I got to knock 1 sec of my wakefield time today, but I am cheating now :D
SAU Nickname: Duncan
Car Make and Model: 32 GTR N1
Circuit Name: Wakefield
Lap time: 1.10.2
Modifications
Engine: Standard N1 spec
Power: tba
Suspension: some jp coilovers
Tyres: Dunlop DZ02G
Brakes: standard
Body weight: 1460 wet
ahh good question that was Andrew that has made transfer case mods, I assume more clutch plates? personally i reckon the controller acheives the same end but I would have to try em back to back.
How is your additional block ventilation mod going?
andrew what did you do to the transfer case? and mind telling me what pressures (HOT) to run the RE55 tyres :D
I was at wakefield on saturday.... however had oil catch can issues! hmmm back there on the 11th to try again!
how do we go about timing for the no speed limit days?
cheers....
Duncan guessed right here. I've never used the controllers but I have been told there are some advantages of the transfer case mods over the controllers - how marginal the difference is I'm not sure so like Duncan could only tell with a back to back trial. But god damn through the tight stuff it's made a huge difference.
Ben - I run my RE55's at 30psi hot.
:rofl:
duncan now all you gotta do is drive a 31 round the track. here is chris' effort
SAU Nickname: Chris
Car Make and Model: HR31 GTS-X
Lap time: 1.12 (something decimal pointish)
Modifications
Engine: R32 RB20DET
Power: 160kw from last count
Suspension: HD Coilovers
Tyres: turanza or some e30 stuff
Brakes: R33 4-pistons at front, R32 at rear
Body weight: 1400
Actually Chris was doing some great laps considering the drives a POS 31 :D but the tyres he was using were dunlop D01J. Hope he makes it to the drift nats in Adl OK :)
I was out there last monday, Powerplay had a private track day and I took the opportunity to give the car a final shake down before the state champs at Oran Park this weekend. It ran great except for the cracked rear rotor so I should be out there OK.
We found with just the controller, it would get some slip towards the end of a race and the oil temps would climb rapidly. No slip with the additional plates, last the whole race and lower transfer case oil temps all the time.
:goddam: I had better ring around and warn everyone.
PS; Only kidding :innocent: good luck.
    • My take on gg2 48mm, 54mm, 58mm, and 62mm compressor map for same size compressor vs gg1 : All gg2 only outflow gg1 above 20 psi. As all g gen 2 surge line at lower left of comp map move to the right, all gg2 sacrifice spool vs same size gg1, surge line move to the right worst for 54mm gg2. So for same size compressor if you want best response, use gg1, if you want max hp at >20psi use gg2 but you will be laggier vs same size gg1. Max compressor efficiency drops to max 75% on all gg2 vs max 76%-80% of same size gg1. Iirc lower efficiency means hotter iat less dense air so lower hp at same operating point of comp map. Also curious why gg2 is mapped to lower max rpm vs same size gg1 (only 48mm size both gg1 gg2 mapped to same rpm) : 54mm gg1 165,000 rpm  vs  gg2 160,000 rpm. 58mm gg1 150,000 rpm vs gg2 140,000rpm. 62mm gg1 145,000 rpm vs gg2 140,000 rpm. If gg2 can safely spin to gg1 rpm then they can flow a bit more than as mapped. Good thing that all gg 2 interchange compressor and turbine housings with same size gg 1. So gg1 owners can buy gg2 chra only if planning to boost >20psi.
    • My stuff is all with Shannon's, granted, I don't really have imports I'm driving on the road, however, I've had multiple cars at the same time with them. Presently we have the Landcruiser on laid up cover, Sarah's Kluger on full cover, and the house insured. About 18 months ago Sarah wrote her Subaru Liberty GTB off, insured with Shannon's, and the payout, and buy back of the wreck was super quick. In 2020 we had the VF Commodore totalled in a major hailstorm. Storm was on the Saturday, I called on the Sunday and lodged it, vehicle was towed on Tuesday night, assessment team called on Wednesday to say it was a total loss and get payout details, money was in the bank on Thursday morning. Have had a few other claims both at fault, and not at fault, over the years, and never had an issue with them.   Funnily enough, they're also the cheapest insurer I find for things like Sarah's Kluger.   I will say I'm less impressed dealing with them lately around "the experience", as a lot of their staff that you deal with aren't car enthusiasts. Shannon's has a much more main stream feel ever since they decided to become "big corporate", laid a heap of staff off, and then hired a bunch of non enthusiasts. At the same time they've been making a push to be less "call us and we'll personally have someone who cares help" to "hey, this computer can do stuff for you" and are trying to get more square pegs to fit round holes. (That's just the vibe I get from them). Again, have had no issues with claims with them, but get a bit of a "less personal" feel from them.
    • A thing I wasn’t happy with with enthusiast was during the initial phone call they told me they’d insure it for 130k but needed photos.   I then sent them photos and they told me $80k as there were other cars either similar modifications available for around that price, I told them to send me the links to said cars so that I can buy them. i then sent the modification list with prices of the parts (no labor) and the price then came to 115k, which is still shy of the 130 that was agreed in the initial phone call
    • Ask me a bit later this week before payday
    • I agree that delayed payment probably isn't the most suitable solution. It seems a solid complete transaction would be best. As I wouldn't be using this sale as a line of credit that would typically earn interest, we can probably arrange a much cleaner single transaction deal. I can do $92.52 today. Would you prefer EFT, or Cash on Pickup?  😛
