SAU Nickname: Bass Junky
Car Make and Model: 1998 Nissan Skyline R34 GTT
Circuit Name: Winton Long Track
Lap time: 1.45:4270
Modifications
Engine: PowerFC, Boost Kit, Full Exhaust
Power: <200rwkw
Suspension: Whiteline Springs, Koni Shocks, Whiteline Sway bars, all alignment stuff
Tyres: Hankook Ventrus Sport K104
Brakes: Stock, Bendix Ultimate Pads
Body weight: Stock
SAU Nickname: Abo Bob
Car Make and Model: 1999 Nissan Skyline R34 GTT Auto
Circuit Name: Wakefield Park
Lap time: 1:12.45
Modifications
Engine: Chipped ECU, GCG Highflow, Full Exhaust, 480cc injectors
Power: 228rwkw
Suspension: Stock
Tyres: RE55's
Brakes: Stock
Body weight: Stock 4 door
Took 0.2s off PB at Winton on Sunday (1.35.0). Should be able to get into the 1.34's next time on the condition it a) it dry and B) I'm not full of Benalia Wang Busters from the night before.
Have both Calder and PI in the next few weeks so will hopefully improve times for both tracks.
hey Roy you have any times for Mallala yet?
I will be there shortly... :)
Not yet...will be looking at doing a day in November when everyone is a little more organised...including me... http://www.skylinesaustralia.com/forums/in...ic=46214&st=100
Updated times...
And Abo Bob, so you only saw a 2sec improvement with the RE55s??? Still a huge improvement, but do you think that semis are worth 2seconds, or were there problems on the day which meant you couldnt get the most out of the tyres?
I improved by 3 seconds actually. 1:15 to 1:12. I also have about 30 more rwkw but my new transmission is a bit different than the old one which required some learning.
I would say that I'll get a 1:11 next time down with current setup but I have some bilsteins waiting to go in, still got stock suspension. I'd love to do a 1:10 in an auto.
Howdy fellas,
Did a supersprint on sunday at Wakefield and got my best time down to a 1:10.63.
Results are here:
http://www.natsoft.com.au/cgi-bin/results....09/2005.WAKE.S1
All guys above me were running slicks or R-spec tyres. I'm on stock 05 STi Bridgestone RE070s. I'm getting very tempted to try a set of stickies.
...Ben
SAU Nickname: jlnewton
Car Make and Model: R33 GTR V-spec
Circuit Name: Queensland Raceway - Clubman layout
Lap time: 1:03.15
Circuit Name: Queensland Raceway - Sprint Layout
Laptime: 1:00.96
Modifications
Engine: RB26DETT
Power: 196.7awkw
Suspension: Apexi T-max coilovers with king springs (F 400lbs, R 225lbs), Whiteline front camber bush and pineapples, Cusco adj caster rods and rear camber arm.
Tyres: Dunlop DO2G 235/45 R17
Brakes: Brembos with slotted DBA 4000s front and rear, Hawk Pads front and rear, Braided Brake lines front and rear, Motul fluid and cusco brake cylinder stopper.
Body weight: ????
...for all the guys with the r33 gtr's how do they compare to cars such as type-r's, s2000's, sti's, and evos?
Unless they are serioulsy modded, almost std GTRs with semi slicks leave them for dead. The EVOs seem to get close at some tracks, but not close enough...hell even my little GTST keeps the late model hatch/hairdresser brigade honest :D
And storms to the top of te Queensland Raceway time card :D
SAU Nickname: captainah
Car Make and Model: 1995 GTR V-Spec R33
Circuit Name: Sandown
Lap time: 1:30
Modifications : 0.95bar, 4" exhaust, pod filters, pump & surge tank, fmic
Engine: stock
Power: 217awkws
Suspension: stock v-spec (hard!)
Tyres: 245/45 17 bridgestone S02
Brakes: R33 stock (brembos)
Body weight: stock
Car Make and Model: 1992 GTR R32
Lap time: 1:35
Modifications : 0.95bar, 4" exhaust, pod filters, pump & surge tank, fmic, unichip piggy back computer
Engine: stock
Power: 205awkws
Suspension: stock - oversteer city
Tyres: 245/45 17 cheapies
Brakes: stock (didn't cope well!)
Body weight: stock
Edited by captainah
    • I know this one’s the BB one. My tuner did make mention about the actuator. I am curious about the VCT as well
    • Might also needs a stronger actuator with the right preloading. With older 2019 built bush G3 units, BB upgrade or 21U housing down size makes a pretty decent gain in response as well.
    • Hey lads  so im finally putting together my rb30 forged bottom end and ran into an issue. I measured my main bearing clearance with arp main studs torqued to 60 ft-lbs using ACL H series STD size bearings and standard, un-ground crank shaft journals and got an oil clearance reading of about 1.3 thou measuring straight up and down and about 2.8 thou measuring at a 45 degree angle (just above and below the parting line). My machine shop said they measured the main tunnel and it was all within spec (they didnt say the actual measurement) and to go with a standard size bearing, which i have done and the clearance is too tight, I'm guessing because of the extra clamping force from the arp studs distorting the main tunnel. I was wanting to run about 2.5 thou main bearing clearance.  My questions are: 1. could i just use the HX extra 1 thou clearance ACL bearings? that would fix my straight up and down clearance making it about 2.3 thou, but then would the side to side clearance be too big at around 3.8 thou? 2. what actually is the recommended main bearing clearance for measuring near the parting line / side to side. i know its supposed to be bigger as the bearing has some eccentricity built into it but how much more clearance should there be compared to the straight up and down measurement? at the moment there is about 1.5thou difference, is that acceptable or should it be less? 3. If i took the engine block + girdle back to the machine shop and got them to line bore the main tunnel (like i told them to do the first time, but they said it didnt need it) what bearing size would i buy? the STD size bearing shells already slide in fairly easily with no real resistance, some even falling out if i tip the girdle up-side-down. If im taking material out of the main tunnel would i need a bearing with extra material on the back side to make up for it? this is probably confusing af to read so if something doesn't make sense let me know and ill try explaining in a different way. My machine shop doesn't come back from christmas break until mid January, hence why i'm asking these questions here. TIA for any help or info
    • I bought the model back in Japan in Feb. I realised I could never build it, looked around for people who could build it, turns out there's some very skilled people out there that will make copies of 1:1 cars or near enough. I'm not really a photo guy... but people were dragging me in a group chat for the choice of bumper as someone else saw the car before it was finished as they are also a customer of that shop. I took the photo in the above post because I was pretty confident that the lip would work wonders for it. Here's some more in-progress and almost-done pics. It gives a good enough idea as to what the rear looks like!   I have also booked in a track day at the end of January. Lets all hope that is nothing but pure fun and games. If it's not pure fun and games, well, I've already got half an engine spare in the cupboard
    • Well, do ya, punk? Seriously though, let's fu<king go! The colour and kit looks amazing on the car. Do you have any shots from the rear? I don't quite follow how the model came around. You bought the white kit and he modified it to match your car? Looks nuts either way!
