Last time i was out circuit racing.(January hot summers day.)
Circuit Name-Wakefield Park
Time-1:14.3
Car:R33GTST
Modifycations:-
Engine/Power mods-Full zorst,13psi,pfc,gtr pump,adj fpr & pannel filter=185rwkw
Suspension-Whiteline handeling kit,HKS hyper D shocks (Fronts rooted rears ok) & strut braces front and rear.
Brakes-Rotors stock with rb74 pads and castrol response super dot 4.Though i have my reservations about the ones i was given.They sit 5mm down from the outer edge of the rotor.Which doesnt seem normal to me but was assured that it was.
Tyres-Near new 17inch Federal 595SS street tyres.
djr81:
put somemore air in? I would have assumed that I had too much air in, more like 35psi cold, which i know is way too much but i didnt have a tyre pressure gauge on me to adjust it and it was my first time out so i was concentrating more on learning the track :cheers:
it pulls like a teenager more like at 5000rpm up, :S haha
Snowman:
I definitely take turn 1 and 2 in 3rd, those I feel I am doing quite ok.
Thinking about it, I now realise i take the flip flop in 4th :D at least i know what to do next time haha
Im not sure which is turn 8,9 or 10, but looking at the winton circuit map, I need more practice with the Northern BM corner. I am probably taking it too hot since I experience that vibrating understeer there quite often and have understeered into the gravel more than once heh.
Another problem area is the Advanced Petroleum corner and the one right after that before the Kitome straight. What gears do i take those in? Is the Advanced Petroleum corner turn 8 (the one you recommended to take in 2nd)? I find if i take the one before the Kitome straight (9?) in 3rd i am a bit off full boost going onto the straight. Are those the corners 8 and 9 you are referring to?
Thanks to you guys for the tips and recommendations, still very new to this. As snowman said, just need more practice (and a tyre pressure gauge!) ;)
Edited by Yawn
Nothern Corner (turn 8) is definitely 2nd. What you don't realise when you are on the track is that the corner is infact more than 90degs. So the apex is actually a little behind the corner. When you first start out you tend to visit gravel a lot in that turn mostly because you'll be turning in too early as you'll be treating it as a 90 deg turn. Thats something you can learn following some other people around (that know where they are going).
Advanced petroluem (9) and then the following one onto the straight are the ones that are driver dependant. I know in Scotsmans R33 GTR which has the same gearing as you that he takes those in 2nd and I take them in 3rd.
Mind you this was the last time we were both at Winton so maybe it's best not to listen to us....
hi all
wakefield park 1:06.3
eastern creek 1:45.5
oran gp 1:17.0
IPRA R32GTR A048 tyres 2 x 27mm restrictors
good to see you on here Dave!
Richard here, with the grey 32 GTR. the guy that parks in front of your house when visiting my mate in annandale!
I am not involved with any cars in the state champs anymore but will definately come out and say hello at the next EC or Oran round. Good to see you doing well. What is happening with your under 2 litre car? We all have a soft spot for that one. especially as it sounds like it's going to suck someone in as it's going down the straight.
Dodgy tyres? Hell yeh. Why not. Would feel like 1:32s :(
Apologies to those that have posted up the last two pages or so. By this weekend the Top 10s will all be sorted.
Right now, im fighting dial up so easier to do at work. Also fighting the urge to get truly, never before seen in the history of modern science drunk...cause that will mean im too blind to see the turn 6 renovations from Sandown. Maybe i can send the vid in to Funniest Home Video and win some white goods :rolleyes:
Dodgy tyres?
Oh yeah :D I just got back from overseas and didn't get a chance to change the tyres, so I was running super worn out ones from last time I hit the track.
That and the brake pads I was planning to change wore out completely.
lol...If i ran the 1:23.1 in the previous session. I was so going to run deep into the 1:22s. From there is was going to need more suspension, but i wanted a 1:22 goddammit!
Yeh, its interesting to look at the progression of lap times as ppl have got more experience.
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
    • Awesome writeup and details. Thanks for sharing the story so far. I can relate to parts of it with my previous car and some of the issues I had to deal with.
    • Wow the colour matched hard top completely transforms the car. Are there any nice front lip options for the car or is that off the table?
    • Generally yes but for some reason I've been ruthless this time around!  I might even need to do another tip run after the way I've finally been able to hit the delete button on shit I've stepped over, stepped around and tripped over for the past 10 years!
    • I just quote the Rolling Stones. Paint it black.
