SAU Nickname: Angus Smart
Car Make and Model: Skyline Gtr 32
Circuit Name: Eastern Creek
Lap time: 1:59:3
Modifications
Engine: n1 turbos pistons etc
Power: low boost only running 1 bar probably around 250kw?
Suspension: Aragosta
Tyres: re55s, ao48
Brakes: Brembo f50, standard rear
Body weight: around 1300
First time giving circuit racing a go! i'm hooked it was loads of fun! i really really really dont like turn two damn off camber make me slide
Edited by Angus Smart
Hahaha you damn mexicans!!!
I need to rock a better suspension setup. the local mr bob jane know it all is a tosser.
and get myself a tune! and a catch can.... oil everywhere after first Session
SAU Nickname: Liz
Car Make and Model: 180sx
Lap time: 2.03.37
Modifications
Engine: s14 sr20det
Power: under 140rwkw - car was dyno'd at 140 when the turbo was working. And pretty busted now.. so under that.
Suspension: Tein Monoflex
Tyres: kumhos (sp?)
Brakes: s15, rda slotted rotors front... bendix pads all round.
Body weight: around 1280 ???
I'll be happy when i'm under 2mins i think.
SAU Nickname: BHDave
Car Make and Model: 92 GTSt
Circuit Name: Wakefield
Lap time: 1:12.37 (natsoft)
Modifications
Engine: RB25DET
Power: ~260rwkw (was only running 1.2 bar)
Suspension: Cusco Comp 1s, 24mm f&r sway bars, lots of adjustable bushes and arms
Tyres: 215/45 17 AO48 front 235/45 17 RE55 rear
Brakes: R34GTt calipers with p mu rotors and pads
Body weight: stock minus back seat and spare
2nd time on a track, understeering pig all day combined with a ham fisted driver = not good
I think i have a bit of work ahead of me to make it onto the list. should be fun :)
SAU Nickname:Simonster
Car Make and Model:Nissan Sil80
Circuit Name:QR Sprint Ct
Lap time:58.7
Modifications
Engine:RB25 HKS3037S
Power:370rwhp
Suspension:HKS Hypermax2 7kg/5kg
Tyres:Dunlop Direzza F215/45/17 R235/45/17
Brakes: Nissan R32 braided lines RB74 pads
Body weight:~1300kg
SAU Nickname: Simonster
Circuit Name:QR Clubman
Lap time: 62.3
Hi Roy,
Please update my time to 58.3 for sprint track and 61.8 for clubman :(
Thanks gone softer on rear suspension as well!
Well im pumped to get back to the track now. I did a comfortable 1:38.2 on the weekend at Winton, whilst being held up by a F430 which i ended up overtakign around the outside. Only had two laps as part of the event...so cant wait to get back there now. Need to bang out a few good times whilst BBGTR is off the road and Ferni is waiting for his new wheels :) I am hoping to get to PI this weekend to give this new suspension a real work over. With any luck i will get into the 1:49s
Amazing, a mod that actually works sure does increase enthusiasm to get back out there :)
Need to ban out a few good times whilst BBGTR is off the road and Ferni is waiting for hsi new wheels :)
AAARRRGGGHHHH, the wait is killing me. Troy, was also looking forward to the MSCA day this weekend but alas it is not to be.
Just don't bin it going for a 220 kmh entry into turn one......
LOL...good point, but im more worried about the entry onto the straight. So keen to get back out there, I really dont know what to expect from the car. I seem to recall you have been punting around on the Bilsteins as well. I hope you like your new suspension as much as i like mine....its so much easier to drive now :).
SAU Nickname: Wogboy
Car Make and Model: 2000 R34 GT-T
Circuit Name: Symmons Plains
Lap time: 1:07.75
Modifications
Engine: RB25DET stock turbo
Power: 225rwkw
Suspension: SK Bilstien group buy
Tyres: Falken RT somethings 235/45/17
Brakes: stock
Body weight: stock
Gettin' there, Bendix Road Street & track pads only change from above. 1:06.43 26th Aug track day.
Had the fronts in for Winton, however it was all unbalanced with the old setup in the back.
mmmmmmm. Green goodness..... :)
SAU Nickname: 9krpm
Car Make and Model: R32GTR
Circuit Name: QR Sprint
Lap time: 58.1 (drift box)
Modifications
Engine: 2.6
Power:350+rwkw
Suspension: Bilstein
Tyres: 255/40/17 RE55R
Brakes: AP
Body weight: 1500 kg
Circuit Name: Mallalla
Lap time: 1:20 (AIM lap timer)
Anything change to pull a second out of your lap time...or was it just more seat time?
Better tyres (Dunlop D02 Semi's), bigger balls/stupidity under brakes.
I got down to a 1:01.64 today, I'll be interested to see what I can do when i have the diff repaired.
    • Yep, that was one of the things we learned fast in the past with our MX5. When you drive with the top down, you are effectively standing out in the sun, 100% of the time, and not getting in any shade (because roads aren't shaded generally!). Just like standing out in the middle of a field on a sunny 27C day is a bit of a bad plan, so is sitting in a MX5 without sun protection.
    • I also just ordered some Frankenstein bolts and side mounts to fit a hard top Just in case I do find one, basically so it doesn't need to be fixed to the car with only the front latch.......and then gaffa tape to keep it in place for the RTN journey from wherever I get it
    • If your temps are fine now, you probably won't have any issues with where your vents are as they don't look right up at the windscreens high pressure area, so any differences when giving it the beans for extended happy laps would be minimal, but, they should vent heaps when stuck in traffic  Much like how that reverse cowl on my SS let "visible" heat out when stationary, but, because it was basically at the windscreen my coolant temps on the Hwy actually raised because air was being fed into it at speed (110kph), to only come back down to around 90° when I got off the Hwy And your 100% correct about the NC currently not needing vents, but, if I was to add a turbo, and a oil cooler and intercooler in front of the condenserand radiator, and then take it to the track???? It is apparently a recommend requirement if I don't want to worry about coolant or oil temp issues, but, any of the above are possible scenarios, over time As it sits now, with the triple pass radiator and stock air conditioning system, I have absolutely no issues with either temps or air conditioning efficiency, I've been basically daily driving thie car for the last month, both on the Hwy, and peak hour, bumper to bumper traffic, but, that's pretty much expected from basically a standard engine  Talking about no issues daily driving, it was 39° the other day and I was sitting in bumper to bumper traffic on the M5 and then M7, with the top down, and with the air conditioning blowing nice cold air on my feet, balls, and face, well, there was one issue, my head and arms got pretty sun burnt Note to self: leave a hat and sunscreen in the car for such days 🤣
    • I would agree, unless you need something specific to the HV motor/battery side repaired or investigated, any mechanic will be able to perform normal services, but if you prefer, maybe look for a mechanic who regularly services/repairs Nissans, the VQ engines are pretty common in the Nissan lineup.  Sorry, I can't make any suggestions, I don't live in Vic.
    • Some of them keep working fine. 9 out of 10 of them end up causing an absolute misery bleeding the system and get thrown on the workshop floor in a tantrum and never thought about again because they were never really needed and just added crap to the car that we could have done without. Same-same with HICAS, A-LSD, and various other stupidities that over eager 10x engineers thought we had to have.
