SAU Nickname - Snowman
Car Make and Model - BMW 135i E87
Circuit Name - Nurburgring - Germany
Lap Time (BTG) - 9.12.3 :) - Google Earth file of lap here - http://sau.ferni.net/Snowy/20080404-1505-b...ap-1-export.kml
Mods - Half cage, Sparco Race Seat and harness, Brembo Brakes and pads and KW Suspension
Tyres - Bridgestone RE050 street tyres.
Power - 306HP
I did one slow sighting lap to see the track and get a feel for the car - which scared the crap out of me.
I then did my 1 hot lap - which really scared the crap out of me.
On my next lap it started PISSING down and then a car infront of me speared off into a wall halfway around the track and with me having a $20K excess over my head I decided it was time to call it a day. (My lap time in the rain was 10.51).
But my god - what a track that place is!
So jealous... I really regret not doing the burgerring while I was over there...
Same here.. I was over there for 2 years and it did not even enter into my head that I should goto the ring.. how f'n stupid of me
Dam snowy!!!!!Well done mate!!!!
Is that the twin turbo bmw? (same motor from the 335?)
Has anyone else here done the ring? A mate did it in a renault megane and was around the 10min mark
Yep - same twin turbo motor out of the 335i. I originally booked that car as I thought it should be fun and light and nimble. When I got there on Friday morning Theo (who runs rent-racecar) told me I had picked the "most difficult to drive" car in his fleet. LOL. I soon found out why. Because it has pretty good power but it as quite a short wheel base so it was EXTREMELY twitchy in the rear - espeically at higher speeds. And there are plently of places you find yourself having to brake and turn from high speeds and boy did I have some moments! Still - no point in not making the most of a potentially one off life experience hey. :D
BTW - Theo told me I was insane to have run 9.12 on my 1st ever lap around the place. lol
  • 4 weeks later...
SAU Nickname: Dave R (David Rodan)
Car Make and Model: 99' Honda Integra R (DC2R)
Circuit Name: Wakefield park (Re-surfaced)
Lap time: 1:11.5
Modifications
Engine: Exhaust, extractors, intake.
Power: aprox 105-110kw @ wheels
Suspension: Buddyclub Race Spec Coilovers, Buddyclub P1 Camber Kit F&R
Tyres: Dunlop D03 (semi's)
Brakes: Project Mu 500max, Slotted Rotors
Body weight: 1175kg (full tank of fuel and me)
Weather was interesting, was raining on and off during the morning and the track was fairly slippery for most of the day.
was done on 27/4/08 Round 2 of NSW SS...
http://www.natsoft.com.au/cgi-bin/re...4/2008.WAKE.SS
Yer yer i know its not a skyline :(
Edited by Dave R
SAU Nickname: Duncan
Car Make and Model: 32gtr n1
Circuit Name: Oran Park
Lap time: 49.7193
Modifications
Engine: standard n1
Power: 240awkw
Suspension: noltec coilovers
Tyres: yoko a048r
Brakes: standard brembos
Body weight: 1550kg
done at night too!
Beat my PB at Winton by 3 seconds today with 35rwkw less than before at 1.41.7-ish
Damn, I know my lines arent the best, and im going in a bit too hot on some of the corners, but I dont think theres more than 2 sec's in it (at my level of skill) unless im doing something really wrong.
Wonder how much time there is in it if I get a proper wheel alignment and some strut braces and sway bars. No matter, I wont be doing anything else to it until get into the 30's. No point spending more money to make up for the lack of driver skill :)
Edited by Yawn
The car has 280rwkw and Ohlins coilovers and RE55s. I need a wheel alignment, havent done it before, and some sway bars and strut braces might help a bit.
The first time at Winton I did 1.44-ish, which was the time before this. I had 315rwkw at that time with RE55s and GAB coilovers.
Im not that satisfied with the time because of me knowing quite a few drivers in their stock-ish evo's in the 38-39s. And your time too Roy, thats what I call respectable. You've got less power than me but presumably more suspension work?
SAU Nickname: BHDave
Car Make and Model: 32gtst nugget
Lap time: 1:07.9310 (natsoft No 12)
Modifications
Engine: rb25det
Power: 255rwkw for the moment
Suspension: cusco comp 2 coilovers, Whiteline 24mm front and rear bars yadda yadda, same as last time
Tyres: 235/45 17 RE55 well past the indicators on the rear
Brakes: R34 GTT front with pmu hcr pro rotors and HC+ pads
Body weight: Stock minus AC compressor, back seat and boot trim. GTR bonnet and front guards
Natsoft arvo standings
So Boz pulled a 1:05 out of the southern motor works exige today (running slick i might add....), does that mean my car has a low 6 in it as it stands? :D
    • I used the radium thing, makes the whole parallel assembly a lot more compact compared to any other way of doing it
    • Racetronix also sells those ethanol content sensor bypass blocks. Adapter, Flex-Fuel E85 Sensor High-Flow Bypass, In-line No Sensor (ADF-FLEX-NS): Adapters - Flex Fuel | Racetronix Ethanol content sensor are originally designed to be on the feed line. These bypass blocks are meant to be ran in the feed line and not return. The continental ethanol content sensors have a 3/8" ID and not 5/16". This is why they are ran on the return line directly in conjunction with a low threshold sampling value VS in the feed with one of these blocks.    Haha we think alike, I used both original feed/return for 8AN feed, and one of the Hicas lines as a 6AN return. I also capped off and left the other Hicas line as a spare.
    • Interesting, I haven't read about the issue with oil getting into the speedo in the cluster before. I'll have to take more notice with mine. The speedo on my R32's when I've run factory diff and tyre size have never been accurate as far as I can remember. The non Type-M GTS-t did come with 15" 5 stud wheels and smaller brakes, but that's less than 5% of them.
    • Good to hear the condenser you picked up off my brother worked all good. Do you think there could be an issue with your AC compressor itself or the clutch on it then? I don't know a lot about them so I can't really help but keen to hear what it ends up being. Keep the build thread going man, it's nice to look back on over time.
    • This is a story of my life things, I learned eventually (thanks to someone calling me out) that my enthusiasm for discussing and sharing ideas that it came across as arrogance and I'm like... WTF?!    One thing I'm pretty sure I justifiably pride myself on is knowing that everyone will have things they can teach you, and you're always going to find out that something you think you know turns out wrong - you just don't know what it is until you get there.   Just the bursting enthusiasm that comes with ADHD when you hit something that gives you dopamine dumps can come across like you think everyone else is wrong or don't matter. But yeah, I'm a software engineer by trade and also do tuning in weekends and 100% have long had a reputation for  quickly making connections when resolving problems or forming solutions that I've sometimes had to take people form a long walk from start to end to explain how I ended up where I did when it's seemed "too simple" when I've stated my initial case, and had the "WTF" type reaction when they've realised how much was actually considered haha.   My reward is that I get all the curly problems thrown at me.
