Another update....
SAU Nickname: Ant97GTR
Car Make and Model: R33 GTR
Circuit Name: Winton long
Lap time: 1:34.17
Engine: RB26 with PowerFC, std turbos (with steel wheels), exhaust
Power: 270-280rwkw
Suspension: Racepace Teins, adj arms (camber/castor/toe)
Tyres: Advan A050's
Brakes: std with DBA5000 front rotors
Body weight: Standard
My times at the moment.
Can't see them going any lower any time soon coz I'll be changing my set up a lot!
SAU Nickname: Russman
Car Make and Model: R32 GTST
Circuit Name: Winton Long
Lap time: 1:34.98
http://www.natsoft.com.au/cgi-bin/results..../2010.WIN.S23.Y
(not the fastest lap)
Circuit Name: Sandown
Lap time: 1:24.26
http://www.natsoft.com.au/cgi-bin/results..../2010.SAN.S23.Y
Circuit Name: Oran Park
Lap time: 1:24.31 (old setup and AO48s)
http://www.natsoft.com.au/cgi-bin/results....03/2009.ORAN.SL
Circuit Name: Eastern Creek
Lap time: 1.47.32 (Superlap 2010)
http://www.natsoft.com.au/cgi-bin/results..../2010.EAST.S2.Y
Engine: RB20 with PowerFC, HKS 2530 turbo, GTR injectors, intercooler etc...
Power: 225-230rwkw
Suspension: Tein RE's, R33 LCA's, Cusco Adj Caster rods, strut braces and whiteline swaybars
Tyres: ADVAN AO50's
Brakes: R34 GTT 310mm front, rear standard
Body weight: Standardish with sound deadening and A/C removed but half cage installed
  • 1 month later...
Circuit Name: Phillip Island
Lap time: 1:47.14
Natsoft here: http://www.natsoft.com.au/cgi-bin/results....2010.PHIL.S22.Y
Power: 270-280rwkw
Tyres: Advan A050's
Brakes: std with DBA5000 front rotors, RDA slotted rear rotors
7th outright at the national supersprint. so I'm not an Australian Champion any more (they didn't even ahve the same class to contest), but still pretty good for my old girl
SAU Nickname: Duncan
Car Make and Model: R32 GTR N1
Circuit Name: Morgan Park (entended)
Lap time: 1:26.644
Modifications
Engine: standard
Power: 230kw
Suspension: bilstein/eibach
Tyres: v70a kumhos
Brakes: porsche 911 front, standard rear
Body weight: 1500kg
SAU Nickname: weevil
Car Make and Model: 1994 mx5
Lap time: 1:37.5
Modifications
Engine: standard
Power: 75rwkw
Suspension: tein
Tyres: r888
Brakes: rda slotted qfm pads
Body weight: 950
  • 1 month later...
Circuit Name: Wakefield
Lap time: 1:14:1
Modifications
Engine: standard
Power: 75rwkw
Suspension: tein
Tyres: r888
Body weight: 950
new PB in the trophey race 10 lapper in mx5 challenge today
  • 1 month later...
Date: 26/2/2011
Car Make and Model: Nissan Silvia S13
Circuit Name: Eastern Creek Raceway
Lap time: 1:45.76
Timing method: Natsoft
Modifications
Engine: 3071R T2 with 0.64 rear housing running 15psi (couldn't run anymore due to issues)
Power: 230rwk approx??
Suspension: Kei Office coilovers
Tyres: Kumho V70A 245/40/17 Hard compound
Brakes: AP Racing front, stock rears
Other: Front splitter, rear wing
Car weight: 1120kg without driver
Natsoft Link: 1:45.76 Natsoft
Video Link: None
Photos Link: None
SAU Nickname: Wogboy
Car Make and Model: 2000 R34 GT-T
Circuit Name: Symmons Plains
Lap time: 1:07.75
Modifications
Engine: RB25DET stock turbo
Power: 225rwkw
Suspension: SK Bilstien group buy
Tyres: Falken RT somethings 235/45/17
Brakes: stock
Body weight: stock
Time for an update, been awhile.
Car Make and Model: 1987 HR31 GTS-R
Circuit Name: Symmons Plains, 2.4km
Lap time: 1:03.22
Modifications
Engine: RB25DET TD06 turbo
Power: 255rwkw
Suspension: Ohlins
Tyres: Falken Nitto NT01 235/35/18 & 275/30/18
Brakes: Front, EVO 8 Brembo's, Performance Friction pads & 330mm 5000 series rotors. Rear, stock R33 GTS-T.
Body weight: 1100-1200 kg, not sure.
SAU Nickname: ssxRicho
Car Make and Model: '96 R33 GTST
Circuit Name: Calder Park
Lap time: 1:07.2
Modifications
Engine: standard, intercooler, pod, highflow turbo, stock fpr + injectors + afm, gtr pump, pfc, greddy ebc
Power: 215rwkw
Suspension: greddy type s, swaybars, hicas lock, cusco camber arms + upper bushes, cusco solid subframe collars
Tyres: 595RSR
Brakes: ksport 330mm front with blue stuff, stocker rears with yellow stuff
Body weight: stock
  • 1 month later...
Current times for me,
Lap time: 2:03.2480 http://www.natsoft.com.au/cgi-bin/results.cgi?09/04/2011.PHIL.S15.Y
Modifications
Engine: 2lt turbo
Power: 166kwatw
Suspension: Bilstein Shocks, Custom Springs
Tyres: DZ03G
Brakes: AP 4 pot
Body weight: 1300kg roughly
Circuit Name: Calder National Circuit
Lap time: 1:08.8142 http://www.natsoft.com.au/cgi-bin/results.cgi?05/03/2011.CPR.S31.Y
Modifications
Engine: 2lt turbo
Power: 172kwatw
Tyres: DZ03G
Brakes: AP 4 pot
Circuit Name: Winton Long Track
Lap time: 1:45.4830 http://www.natsoft.com.au/cgi-bin/results.cgi?23/05/2010.WIN.S6.Y
Modifications
Engine: 2lt turbo
Power: 166kwatw
Tyres: KU36's
Brakes: AP 4 pot
Circuit Name: Sandown Raceway
Lap time: 1:31.8400
Modifications
Engine: 2lt turbo
Power: 166kwatw
Suspension: Bilstein Shocks/Struts, Custom Springs
Tyres: KU36
Brakes: AP 4 pot
SAU Nickname: a20089
Circuit Name: Wakefield Park
Lap time: 1:10.69
link: http://www.natsoft.com.au/cgi-bin/results.cgi?05/03/2011.WAKE.S6
Engine build: Standard with a tune and EBC
Power: 266kw
Suspension: 15yo+ standard
Tyres: Federal 595 RS-R (Worn)
Brakes: standard with RDA rotors and EBC yellow pads
Body: Standard
new sandown PB
SAUnickname=dougmo
Circuit Name: sandown
Lap time: 1:23.79
natsoft: http://www.natsoft.com.au/cgi-bin/results.cgi?24/04/2011.SAN.S12
Modifications turbo,cams,pfc,cooler,3" exh
Engine: stock na bottom ended sr20
Power: 220-230kw
Suspension: tanabe
Tyres: toyo ra1 205/55r16
Brakes: front r32 gtst,rear stock
Other: wing on the boot(bootlid all bent from the drag)
Car weight: 1250ish kg with driver
New PB for Winton :)
Lap time: 1:41.8480 http://www.natsoft.com.au/cgi-bin/results.cgi?09/05/2011.WIN.S1
Modifications
Engine: 2lt turbo
Power: 168kwatw (From last dyno which I think is a bit low)
Tyres: DZ03G
Brakes: AP 4 pot
New PB for Winton
Lap time: 1:37.42 http://www.natsoft.com.au/cgi-bin/results.cgi?15/05/2011.WIN.S1
Modifications
Engine: std RB20DET with 6boost manifold and Greddy TD06-20 8cm
Power: 245rwkw (running less ignition then usual and 98RON)
Suspension: Custom Tein RA, ARC Swaybars,
Tyres: 4yr old flat spotted RE55s
Brakes: Custom 343mm Stoptech ST-40 fronts and std R33 GTR Brembo rears
Body weight: 1300-1320kg roughly
Will be interesting to see how i go next time back with new tyres and a proper wheel alignment and ride height changes. Currently running std ride height. If you have decent sound on your computer you can hear the flat spot on the front left...especially on right hand corners. (i am a whore at posting vids :) )
New time set yesterday.
SAU Nickname: grippy
Car Make and Model: R32 GTSt
Lap time: 1.49.89 http://www.natsoft.com.au/cgi-bin/results.cgi?22/05/2011.ARDC.S1
Modifications: HKS 2530, GTR injectors, re-map.
Engine:RB20DET
Power:215kw
Suspension: Buddy Club Race spec
Tyres:Kumho V70A
Brakes: Stock
Body weight: 1270
New PB for Winton
Modifications
Go the RB20!! Sounds like it has a very short xorst? Goes like shit off a sling shot..
1st time out with car and 1st track day
SAU Nickname:sycorb
Car Make and Model:r32 gtr
Circuit Name:wakefeild park
Lap time: 108.2
Modifications
Engine:jun 2.7
Power:400kw
Suspension:sydney kid bilsteins pack
Tyres:yokohama ad08
Brakes:k sports 355mm
Body weight:full body with 2 subs and 2 amps
