SAU Nickname: Fatz
Car Make and Model: Nissan R33 GTR
Circuit Name: Wakefield
Lap time: 1.05.3 (faster than mick above)(Natsoft)
Modifications: pt6262 single kit e85
Engine: RB26
Power: about 350kw
Suspension: RP tein
Tyres: Hankook Z221 in 295/30/18 (50 bux a tyre used)
Brakes: 6 piston APs on 355mm rotors upfront and 4 piston APs on 343mm discs out back
Body weight: 1780 with me in the girthy whore
rwd all day which made it fun
  • Like 1
SAU Nickname: Bazil_1
Lap time: 1.05.329 (faster than the fatz and Mick above)(Natsoft)
Modifications: forged pistons, n1 turbos, e85
Engine: RB26
Power: 350kw on 23psi
Suspension: MCA Gold
Tyres: Yoko A050 medium 265/35/18 that I drove there on
Brakes: 6 piston APs on 343mm rotors upfront and 4 piston APs on 330mm discs out back
Body weight: 1590kg with driver
  • Like 2
  • 1 month later...
Date: 13/09/15
Car Make and Model: R33 GTS-T
Circuit Name: Winton
Lap time: 1:37.89
Timing method: Natsoft
Modifications
Engine: RB25 with PowerFC, Kinugawa something something turbo
Power: 260rwkw on E85
Suspension: BC Racing ER series
Tyres: RE55S SR2 compound, 235/45/17
Brakes: GTR rotors, stock calipers, Project Mu HC+ pads
Body weight: Stock with half cage and minus rear seat
  • Like 1
SAU Nickname: FLN75S
Car Make and Model: 1994 R33 GTST
Circuit Name: Eastern Creek GP Circuit
Lap time: 1:54:91
Modifications
Engine: RB25DET
Power: 150RWKW Stock unopened engine with 3inch exhaust (no cat) running 10psi with R34 GTT Intercooler.
Suspension: MCA Reds
Tyres: KHUMO 16inch V7000 Semi slick
Brakes: STD - A1RM PADS
Body weight: 1475KG
Car has Half Cage, Race seat & harness with HICAS removed
  • 3 months later...
Update:
Lap time: 1:14.7 (damp to wet track)
Timing method: Q-Starz
Modifications
Engine: Unopened RB25DET with a Hypergear SS2 running 1.4bar (couldn't run more due to misfire)
Power: ~300kW
Suspension: Lower sprinngs with Bilstein Shocks + 24mm F&R Whiteline anti-roll Bars
Tyres: 255/40/17 Nitto NT01(Front) & 255/40/17 Federal 595 RS-R (Rear)
Brakes: Stock, with Project MU HC800 pads all round
Body weight: 1500 kg?
Update:
Lap time: 1m12.038 (37 degree day, tyres were like butter)
Modifications
Engine: Unopened RB25DET with a Hypergear SS2 running 1.5bar on E85
Power: ~300kW
Suspension: MCA X-Race 10kg(f) and 7kg® + 24mm F&R Whiteline anti-roll Bars
Tyres: 255/40/17 Nitto NT01 all round
1st outing with the new setup, still don't have the full confidence to throw the car into turns yet and also was so damn hot.. shirt was pretty much drenched in sweat after each session! Got about 4 to 5 laps at time before car started to get into the too hot region.
  • 5 months later...
Update:
Modifications
Power: ~300kW
Round 2, Fight!
Lap time: 1m11.05
Modifications
Engine: Unopened RB25DET with a Hypergear SS2 CBB Version running 1.5bar on E85
Power: ~340kW (at 1.7bar she makes 372kW but that's asking for a grenading motor recipe)
Brakes: Brembo up front with Intima Type-D Pads, Stock Rears with Project MU HC800 (that died, metal on metal back home)
  • Like 2
SAU Nickname:ke55pig
Car Make and Model:r32
Circuit Name:mallala
Lap time: 1.24
Modifications
Engine:t67 rb25neo
Power:350rwkw
Suspension:isc
Tyres:235 kenda 265 nankang
Brakes:stock bendix ultimate pads
Body weight:full trim 32 2 door plus amps stereo
  • 4 weeks later...
SAU Nickname: 34GeeTeeTee
Car Make and Model: Nissan R34 GTT
Circuit Name: SMSP Brabham Circuit
Lap time: 2.06.x (Natsoft)
Modifications: Stock... Officer! Basic bolt on gear as per build thread.
Engine: RB25 NEO
Power: about 320kw on 21PSI
Suspension: MCA Red - 15kg front 6kg rear combo
Tyres: Hankook Z221 in 295/30/18 - Time set on a mix of worn medium and soft due to an earlier puncture.
Brakes: Alcon front, stock rear
Body weight: 110kg and damn good looking.... No idea about the car! :laugh:
  • Like 2
  • 2 months later...
Circuit Name: Wakefield Park
Lap time: 1.047 (Natsoft)
Engine: RB25 NEO
Power: about Gate pressure only - At a guess maybe 280kw @ 16-17PSI
Suspension: MCA Red - 15kg front 6kg rear combo - Stock swaybars - Understeery
Tyres: Hankook Z221 in 295/30/18 - Time set on medium tyres.
Body weight: Heavy nugget still!
  • Like 2
SAU Nickname: BenM
Car Make and Model: Radical SR3
Lap time: 62.34 (Natsoft)
Modifications: Radical Spec
Engine: Suzuki Hayabusa 1500cc
Power: ~150rwkw
Suspension: Radical Spec
Tyres: Radical Spec Dunlop Slicks
Brakes: Radical Spec
Body weight: ~600kg
  • Like 1
SAU Nickname: WAGON_BOY
Car Make and Model: 2000 Mazda RX7 S8
Circuit Name: SMSP North
Lap time: 1:15
Circuit Name: SMSP South
Lap time: 1:05
Circuit Name: SMSP GP
Lap time: 1:51
Lap time: 1:09
Modifications
Engine: 13BREW TT
Power: 192Kw@W
Suspension: BC racing BR Type RH Series
Tyres: Nitto NT-01's
Brakes: stock disc's with remsa pads
Body weight: 1200kg???
On 5/31/2016 at 1:36 PM, Dose Pipe Sutututu said:
Round 2, Fight!
Lap time: 1m11.05
Modifications
Round 3, Fight!
Lap time: 1m09.06
Modifications
Brakes: Brembo up front with Intima Type-D Pads, Stock Rears with Intima SR Pads
Only difference this time was a GT-R wing with the blade set at the 3rd setting. Surprisingly made a massive difference to rear end grip!
Circuit Name: Morgan Park
D Circuit (1.5km) Lap time: 0:49.1
E Circuit (2.1km) Lap time: 1:09.8
K Circuit (3.0km) Lap time: 1.27.5
Timing method: MyLaps, QStarz
Modifications
Engine: RB30DET, cams 8.9mm 265 deg, Kinugawa TDO6H-25G turbo, ViPec ECU
Power: 375rwhp on 16.5psi
Suspension: MCA Red, springs 14kg F, 5kg R.  Also 15kg F, 5.5kg R.  Stock swaybars.
Tyres: Hankook Z221 C70, 265/35x18 F, 295/30 x18 R
Brakes: Evo Brembo fronts, Evo 10 350mm rotors, stock rear rotors and calipers, Winmax pads
Body weight: 1375kg, caged and race seat
  • Like 2
  • 1 month later...
SAU Nickname: Racer5
Car Make and Model: Skyline R32 Gtr
Circuit Name: GP circuit Sydney Motorsport Park
Lap time: 1.39.65 natsoft WTAC 2016 open class
Modifications : Aero,  Front gearbox removed. RWD. Tremec Tk05 gearbox
Engine: V8 6.2 Litre Holden Ls3 crate motor with cam.
Power: 432Hp ATW
Suspension: BC
Tyres: 295.35.18 A050 Yokohama
Brakes: project mu pads, Evo9 calipers, DB5000 evo10 rotors.
Body weight 1200kg
https://youtu.be/7FjD2zaGPDY
Edited by Racer5
Link added
  • 4 weeks later...
SAU Nickname: BenM
Lap time: 60.46 (Natsoft)
Power: ~150rwkw
Body weight: ~600kg
SAU Nickname: BenM
Lap time: 1:37.8 (20Hz GPS + Harry's Laptimer)
Power: ~150rwkw
Body weight: ~600kg
SAU Nickname: darrenjc
Car Make and Model: Nissan Skyline R32 GTR V-Spec II
Circuit Name: Sandown
Lap time: 1:21.999 (Natsoft)
Circuit Name: Phillip Island
Lap time: 1:49.960 (Natsoft)
Modifications
Engine: Racepace built, secret squirrel response turbos
Power: 325kw track tune
Suspension: Rock hard Jap spec Tein monoflex
Tyres: A050 Medium
Brakes: Stock Brembo + HC800 Pads
Body weight: Stock
  • 1 month later...
Lap time: 1.035 (Natsoft and Race Chrono with GPS Reciever)
Engine: RB25 NEO
Power: Low Boostish - At a guess maybe 325kw @ 21PSI
Suspension: MCA Red - 14kg front 6kg rear combo - Whiteline Swaybars F + R - Understeery but massive imrovement to before!
Tyres: Hankook Z221 in 295/30/18 - Time set on same medium tyres from last year, have done around 6 track days now.
Brakes: Alcon 365mm front, Alpha Omega 350mm rear setup
So in summary, rear brake upgrade, 4PSI boost and swaybars made up a full second gain with plenty of room to improve!
  • 1 month later...
SAU Nickname: Mitch_Dubya
Car Make and Model: R33 GTS-T LS1
Circuit Name: Winton (first time)
Lap time: 1:39.7X
Modifications: ext lcas neg 7deg, big wang, surge, locked dif,
Engine: LS1 with mild cam
Power: 260rwkw
Suspension: cusco coilovers
Tyres: (F) old as f**k Nitto semis (R) piss poor Nankangs
Brakes: standard and completely f**ked (see pic below)
Body weight: est. 1200kgs, fully stripped inc dash, door cards, light weight bonnet and boot, lighter drivetrain, no cage at the time
very green to racing and first time at Winton. I left smiling but knowing there was a couple more seconds in the car with a better driver. The brakes were down to metal and still managed to set my best time on the second last lap for the day. Looking forward to having another crack with new brakes (inc braided lines, rotors and cooling), more seat time and better rubber.
  • 4 weeks later...
Date: 11/09/16
Lap time: 1:35.74
Modifications
Power: 257rwkw on E85
Tyres: Hankook z221 255/40/17
Brakes: 324mm RDA blank rotors, stock calipers, Project Mu HC+ pads
  • 2 months later...
Engine: RB25 NEO
Update, AUS TIME ATTACK at Wakefield Park we managed to shave a bit off our time and now have a 1.034
  • Like 1
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
    • Shimmed or shimless, still solid, no hydraulic pump up stuff.
    • They have said food will be limited. Mainly meat pies and sausage rolls from memory. But they have a coffee van!
