Car: R32 Gtst
Modifications: PowerFC, HKS 2530 Turbo, Injectors, Exhaust, FMIC
Engine: RB20DET
Power: ~170rwkw @ 0.9 bar
Suspension: Whiteline Sway bars & front strut brace.....rest stock
Tyres: some Nankangs
Brakes: Front - DBA 4000 Rotors/ultimate pads Rear - Stock Rotors/ultimate pads
Body weight: normal r32
Oran Park GP - 1.34.12
SAU Nickname: BBGTR
Car Make and Model: 1994 R32 GT-R
Circuit Name: Calder
Lap time: 1.05.37
Circuit Name: Sandown
Lap time: 1.22.35
Circuit Name: Phillip Island
Lap time: 1.51.26
Modifications
Engine: Stock bottom end, 2530's, PFC, Sard 800cc injectors, AVO FMIC, HKS Oil Cooler, 40mm Alloy Radiator, NISMO Exhaust
Power: 318 RWKW
Suspension: Whiteline Kit
Tyres: RE55 265/35/18
Brakes: CSC 6 pot front, CSC 2 pot Rear
Body weight: 1554kg's without me in it (road wheels) maybe knock off 15 kgs for race wheels.
Regards
Andrew
Edited by BBGTR
Update people. If you see an error with any of your times or they need updating then shoot me a PM:)
Jason (jlnewton) and the QLD guys. Can you go back over your times and verify the track layout for your times.
Also Jason that great little pic you posted of the layouts sint working, and i have been slack in updating...for which i apologise...
It has sooo much left in it.
Thats not what GTST drivers like me want to hear :)
...and thanks for the PMs ppl...all fixed
  • 3 weeks later...
SAU Nickname: provo
Car Make and Model: 1999 R34 GTR V-Spec
Circuit Name: Sandown (11/6/2006 WRX/SAU Sprints)
Lap time: 1:25.19
Modifications
Engine: N1's, full Nismo Weldina exhaust, ECU
Power: 307 rwkW (Racepace)
Suspension: stock
Tyres: 265/35 RE55s
Brakes: stock Brembo's, Endless CCR pads
SAU Nickname: BBGTR
Lap time: 1.06.35
Lap time: 1.23.27
Circuit Name: Phillip Island - No 4WD - attessa Fluid well under minimum
Lap time: 1.57.16
Modifications
Power: 318 RWKW
This car drives completely differently to my STi. It has sooo much left in it.
Regards
Andrew
Sandown Time Updated 11/6/06
Edited by BBGTR
Though I might as well put a Tassie time in.
SAU Nickname: sav man
Car Make and Model: 89 R32 GT-R
28/06/06
Circuit Name: Symmonds Planes - 2.41 km
Lap time: 1:06.00
Modifications
Engine: Power FC, big FMIC, 0.85 bar
Power: 226 rwkw
Suspension: some brand non adjustible shocks (after market), HICAS lock bar.
Tyres: 245/40/18 Buggered Bridgstone G-Grid II
Brakes: Stockers - Bendex Ultimate Pad's
Good work...a little birdy flagging said you may have had a moment? Car ok?
Yes, no issues - just a 180 spin and a duck to the infield to avoid another spinning R34 GT-R :P
It got very greasy in that supersprint after some rain - 2 others behind me spun in sympathy :laugh:
I have at least another second I can take out of the lap time according to my best theoretical lap from my data.
Just need bigger balls.
Regards
Andrew
ps. Would love get any video footage from any of the flaggies if they had any...
Ahh, good news then.
As for footage, Done! ...Ryan was getting footage at turns 3 and 4. Ill speak to him and see what he has got over the next week or so once he has had a chance to edit it up.
I will get around to comign up and sayign hello one of these days, i always come and have a sticky at your car but your not normally around. Do you know how the handbrake setup works with your rear rotors?
That's great, I don't know what my car sounds like from the outside :P
Yeah, I'm usually off trying to impress people about how little I know about car control.
The hand brake is the same as factory. The Rotor Hat is steel and contains the factory bits and pieces.
Regards
Andrew
  • 3 weeks later...
Thought it was time I put some times up as a benchmark of my first few track days
SAU Nickname: Liz
Car Make and Model: 1994 R33 GTS-T
Circuit Name: Oran Park GP
Lap time: 1:36.0970
Circuit Name: Wakefield
Lap time: 1:19.7580
Modifications
Engine: FMIC, Highflow Cat +3inch Cat Back, Highflow air filter and hicas locked out.. so pretty stock!
Power:??? 170 perhaps?
Suspension: Stock
Tyres: Fulda Excellero on stock rims. Very much a wet whether tyre!
Brakes: Stock
Body weight: Whatever stock is!
Cheers
Liz.
Car '97 S2 R33 GTS-T
Mods 3inch turbo back exhuast, pod filter.
Oran Park GP 1.31.6 with falken 326 shit tyres.
Wakefield Park 1.13.6 with semi slicks, RE55s
Mods same as above plus 27mm front sway bar.
    • My take on gg2 48mm, 54mm, 58mm, and 62mm compressor map for same size compressor vs gg1 : All gg2 only outflow gg1 above 20 psi. As all g gen 2 surge line at lower left of comp map move to the right, all gg2 sacrifice spool vs same size gg1, surge line move to the right worst for 54mm gg2. So for same size compressor if you want best response, use gg1, if you want max hp at >20psi use gg2 but you will be laggier vs same size gg1. Max compressor efficiency drops to max 75% on all gg2 vs max 76%-80% of same size gg1. Iirc lower efficiency means hotter iat less dense air so lower hp at same operating point of comp map. Also curious why gg2 is mapped to lower max rpm vs same size gg1 (only 48mm size both gg1 gg2 mapped to same rpm) : 54mm gg1 165,000 rpm  vs  gg2 160,000 rpm. 58mm gg1 150,000 rpm vs gg2 140,000rpm. 62mm gg1 145,000 rpm vs gg2 140,000 rpm. If gg2 can safely spin to gg1 rpm then they can flow a bit more than as mapped. Good thing that all gg 2 interchange compressor and turbine housings with same size gg 1. So gg1 owners can buy gg2 chra only if planning to boost >20psi.
    • My stuff is all with Shannon's, granted, I don't really have imports I'm driving on the road, however, I've had multiple cars at the same time with them. Presently we have the Landcruiser on laid up cover, Sarah's Kluger on full cover, and the house insured. About 18 months ago Sarah wrote her Subaru Liberty GTB off, insured with Shannon's, and the payout, and buy back of the wreck was super quick. In 2020 we had the VF Commodore totalled in a major hailstorm. Storm was on the Saturday, I called on the Sunday and lodged it, vehicle was towed on Tuesday night, assessment team called on Wednesday to say it was a total loss and get payout details, money was in the bank on Thursday morning. Have had a few other claims both at fault, and not at fault, over the years, and never had an issue with them.   Funnily enough, they're also the cheapest insurer I find for things like Sarah's Kluger.   I will say I'm less impressed dealing with them lately around "the experience", as a lot of their staff that you deal with aren't car enthusiasts. Shannon's has a much more main stream feel ever since they decided to become "big corporate", laid a heap of staff off, and then hired a bunch of non enthusiasts. At the same time they've been making a push to be less "call us and we'll personally have someone who cares help" to "hey, this computer can do stuff for you" and are trying to get more square pegs to fit round holes. (That's just the vibe I get from them). Again, have had no issues with claims with them, but get a bit of a "less personal" feel from them.
    • A thing I wasn’t happy with with enthusiast was during the initial phone call they told me they’d insure it for 130k but needed photos.   I then sent them photos and they told me $80k as there were other cars either similar modifications available for around that price, I told them to send me the links to said cars so that I can buy them. i then sent the modification list with prices of the parts (no labor) and the price then came to 115k, which is still shy of the 130 that was agreed in the initial phone call
    • Ask me a bit later this week before payday
    • I agree that delayed payment probably isn't the most suitable solution. It seems a solid complete transaction would be best. As I wouldn't be using this sale as a line of credit that would typically earn interest, we can probably arrange a much cleaner single transaction deal. I can do $92.52 today. Would you prefer EFT, or Cash on Pickup?  😛
