SAU Nickname: franks
Car Make and Model: Nissan Skyline ER34
Circuit Name: Wakefield Park
Lap time: 1:12.5 (stop watch)
Modifications
Engine: fmic, exhaust, powerfc @ stock boost 0.7bar
Power: ~160kw
Suspension: fr/rr swaybars/camber/castor kits, variable rate springs
Tyres: toyo trampios r1r - fr:235/45/17 rr:255/40/17
Brakes:stock nissan with rb74 racebrake pads (fr) and bendix crap-timate (rr)
Body weight:stock nissan ER34 LESS spare space saver tyre PLUS fat bastard :P
Hey Carlo, you sure have done some improving over the past 12 months. Can you post the details of your car please?
Modifications
Engine:
Power:
Suspension:
Tyres:
Brakes:
Body weight:
...also how the lap was timed? :rofl:
Man im going to have to go to the Sept Motoconcepts EC day, i am about to drop out of the Top 10 :rofl:
2003 Eastern Creek Mods
Engine:RB25DET (26DETT is for girls! hehe), HKS pod filter, Cat Back Exhaust.
Power: 140rwkw due to boost leak
Suspension: Bilstein Shocks HKS Springs
Tyres: Worn out simex baby! hehee
Brakes: Std Calipers, RB74 Pads & DBA 4000 Rotors
Body weight: Me 65kg
2004 Wakefield Park
Engine: RB25DET, FMIC, Apexi Pod, Trust Cat Back Zorst
Power: 160RWKW
Suspension: Bilstein Shocks HKS Springs, Whiteline Swaybars F & R
Tyres: Falken Semi-Slicks
Body weight: 65kg
I personally think I can do better at both tracks, Wakefield is a track I was only getting used to when I fuxx0red my exhaust manifold. So I cant wait to have the car all sorted and get back to EC which is my favorite track by far. Wakefield is fun but EC is alot more fun. :rofl:
Cool, your lapping about the same time as me with similar mods. Do you still have the speed limiter on your car? Im only askign as i want to know how realistic my goal for a 1:49.99 is with no speed limiter, good R compound rubber and a bit more power (approx220-250rwkws)
let me know how you go next time you go to Eastern with good rubber, keen to find out a time improvement from good rubber alone :rofl:
Yeah still the stock ECU.. I wont go back to EC until my car is sorted which includes new ECU, Cam Gear, Turbo sorted out, new coil packs and new semi slicks.. My next goal is 1:53ish which I think I can do.. I think there is 2-3 seconds in the change to good rubber as the simex I was using where thrashed.. I did 6 trackdays no 7 trackdays on them. The last 3 of which where just me sliding through corners..
SAU Nickname: skylinegeoff
Car Make and Model: R33 GTS25t
Circuit Name: Phillip Island
Lap time: 1:58.5
Modifications
Engine: GTR fuel pump and rods, Arias Forged pistons
Power: 221rwkw
Suspension: Std shocks, RSR lowered springs, Whiteline adjustable swaybars, HICAS lock and pineapples
Tyres: Dunlop D01J
Brakes: Slotted front, plain rear, RB74 front pads
Body weight: 1470kg
Lap time: 2:03.2 same day as above PIARC Group 5 sprint.
HSV Track day 19 Sept 04: 2:00.55 on the road rubber and lower boost.
Modifications
Tyres: Dunlop 9000 255 40 ZR17 rear and Continental Sport Contact 235 40 ZR17 front
Circuit Name: Sandown
Lap time: 1:36.1 speed limited to 190kmh :edit 24-10-04: new lap time 1:31.6. Hoped to go faster but for a slow M3 and even slower TVR Griff spoiling me for 4 flying laps straight.
SAU Nickname: Adzmax
Car Make and Model: 1999 ER34 GTT
Lap time: 1:58.04
Modifications
Engine: Bosche 975 Fuel pump, 10psi boost, Power FC, 3" turbo back exhaust, ARC Fount mount cooler, Oil cooler.
Power: 205rwkw
Suspension: Standard
Tyres: Dunlop D01J
Brakes: Standard
Body weight: 1400kg (claimed - yeah right)
SAU Nickname: 88silhouette
Car Make and Model: Nissan R31 Skyline Silhouette SII
Lap Time: 1m24s
Engine: RB30E
Power: About 70kW (the car is dying slowly)
Suspension: El cheapo Monroe Gas
Tyres: Worn out A539 Yokohamas
Brakes: Worn out
Body Weight: bout 1320
It was just a Wakefield Practice Day. Only 20 cars showed up during the day. Being N/A I thrashed the car for a long time that day. Go the stocker 31!!!
SAU Nickname: look over there <---
Car Make and Model: '93 GTS25t
Circuit Name: Eastern Creek
Lap time: ~2:03
Modifications
Engine: nil
Power: stock ~136rwkw
Suspension: stock and old! :uh-huh:
Tyres: 17" Dunlop FM901
Brakes: Ferodo DS2500 pads all round and DBA 4000 discs up front
Body weight: 1370kg (? stock)
SAU Nickname: Jimbo2000
Car Make and Model: R33 GTSt
Circuit Name: Oran Park
Lap time: 0:56.4600 :Oops:
Modifications
Power: 215rwkw
Suspension: stock
Tyres: hancook K104 300K's old still getting scrubbed in
Brakes: standard
Body weight: fatass
ok i suck, but i had fun ok!!
    • Haha luckily we don't have emissions, inspections, or any laws against power adders here. They only thing they somewhat keep an eye out for are ridiculously loud exhausts.
    • Just wanted to pop in an update on my setup. The CD swap has been great, I love the mazworks housing for the overall simplicity. I ended up sealing my trans tunnel with a thin sheet of aluminum reused some of the holes on the trans tunnel, and laid some window sealing EPS foam around the edges. Works great, really quieted things down and sealed up the car.  As for the power comment. Right now I am also running about 650whp. with the way the bell housing is attached to the face of the transmission I have zero doubts it would be fine, mainly because the input shaft and main shaft bearings are seated into the bell housing adapter. This means the load is NOT on the bolts to maintain the power, rather into he casing of the bell housing; Yes the bolts are doing some work there, but with both shafts locked in zero worries.  End of the day, the Mazworks solution is the easiest and safest. no need to take your trans to a shop to get milled perfectly, it fits with minimal clearancing, and you can use all your existing clutch and flywheel.  Driving wise the CD has been great compared to the big box, I'll probably swap my final drive at some point. The serial 9 shifter is gooooood, my only qualm is how tight it is, it takes a fair bit to get use to, 5th and 6th are a bit eh/hard to find at times, but maybe I need re-adjusting, and I think my clutch master is very tired and needs a rebuild.
    • If you are keen, have a look at my build thread. Car is for sale for the right money or straight swap for a F80 M3 LCI.
    • Welcome mate.  No point in over thinking it, buying any one of those cars you mentioned is not a smart or logical choice with the availability of many "better" (re price to performance) cars available to you.  The heart wants what the heart wants, buy whatever it leads you too.
    • Hey everyone! Im so grateful to be apart of this community and ill do my best to be apart of this. Firstly, i'm not disclosing my real name due to in real life circumstances surrounding my privacy and public image (sorry lol) Secondly, The only thing personal I am willing to share is that I'm from Sydney and a descendant of one of Sydneys largest mortgage firms. I got gifted my first ever car, a 2022 Porsche Cayenne and I love it to death. Ive been driving it for about 5 or 6 months now and honestly Im so grateful for my parents for gifting me this vehicle. However recently I've been working my ass off to afford my second car (which I need help deciding soooooo community help me out please?). Once decided, im planning to try modify it myself. Recent I've been thinking about getting a Skyline, particularly a 25GT or GT-V, yes I know overrated as hell, but I'm also considering a Chaser which I recently came to love. However my dream is to one day own a 180SX (So hard to find clean versions and im not really into importing).  Lastly before I send this off, I want to apologize if I sound tacky or pretentious. I try not to and want to genuinely learn from everyone and anyone. (Im no expert in this area) Thanks for reading!
