SAU Nickname: JDSracing
Car Make and Model: 95 R33 GTST
Circuit Name: Wakefield
Lap time: 1:12.4
Modifications
Engine: Front Mount / Exhaust / 9 psi
Power: approx 160kw
Suspension: Tanabe Circuit Coilovers, Tein Tie Rods, Natetune Castor Rods
Tyres: dead RT215s (on the belts now)
Brakes: standard discs / calipers with RBF600, Ferodo DS2500s, braided lines
Body weight: unknown
Still a bit off the pace, but getting there slowly. Give me another 12 months and a bit more experience and I'll hopefully catch up to the top 10 (assuming the tail end doesn't get too much faster!)
SAU Nickname: Peterm13
Car Make and Model: 96 200sx S14
Circuit Name: Sandown
Lap time: 1:40
Modifications full exhaust,pod(with shield), 7psi.
Engine: SR20det 5spd
Power: 130-140kw
Suspension: stock
Tyres: Pirelli Dragon, 235-45-17
Brakes: standard
Body weight: standard
I just started sprints this year, only managed to do sandown twice and the island twice.
By next meeting (feb/march 08 ) will have FMIC and hopefully coilovers ! :w00t:
  • 1 month later...
not from me! :thumbsup:
After a bit on instruction from Paul K (Aussie Car champion 2006) I started doing ok!
but then it just got too wet so I was doing a few "slides" away from everyone!
I had one stuff up though, the straight just before last turn - I came in too hot, went past the braking point, and went off into the mud! :) was just sooooooooooo wet there!
Unfort a lancer EVO hit a wall and the bloke went to hospital :(
Greg (v s p e c ) had many spins :(
I got John Boston out there in my car with Georgie in the passenger seat, I said to him "make sure she has a grin on her face!"
He was putting on a great show!!!! He said my car needs more power though :( haha and the front end grip wasnt too bad, car seemed predictable, he enjoyed it!
1:20 isn't bad at all for a first time effort in pouring rain. I was hoping you'd get a dry run though, to see how you'd go against my time :)
EVO hit a wall? how on earth did that happen? Was it the main straight wall or did he spear off somewhere up the back?
hahah yeah slightly wet :thumbsup:
Apparantly was understeering last turn...and snapped back and well over corrected then went drivers side into the wall right at the start, The tyre wall, near the joining of the armco barrier along the straight.
Hi All,
Down to a 1.06.2 at Wakefield on the old motor.....hopefully the new motor gives me a bit more grunt out of the corner to crack into the 1.05's
Down to a 1.44.4 at Eastern Creek with an even older motor(built in 1992)....next year 1.43's or bust.
Oh yeh the car....GMS R31....doubt the Stagea would do those times...lol
Much difference now that the place has been resurfaced?
SAU Nickname: Jetwreck
Car Make and Model: R31 GTS (or GMS R31)
Circuit Name: Easter Creek
Lap time: 1.44.4 (natsoft)
Lap time: 1.06.2 (natsoft)
Modifications
Engine: RB20
Power: Enough....but we always want more
Suspension: Ah...no answer
Tyres: Kumo
Brakes: What ever suits the circuit.
Body weight: 1,200KG
I guess your talking about Wakefield?
I think it was still the old surface the last time I went...not sure though as I hadn't been there for about 6 years before that......It was at the Fujitsu Super Taxi Weekend in March 2007!
Modifications
Engine: RB20
Tyres: Kumo
Which GMS car is it? They are works of art and sound great :blink:
    • How much have you lowered?  I had 350Z springs in the rear and was able to pull the camber into factory spec with the factory arms on the rear, obviously the front ran negative camber as it isn't adjustable, but rotating the wheels regularly evened out the wear.
    • Either the installer needs to come back, you need an auto electrician, or you need to learn automotive electricals yourself.   First step Id look at is where that big thing came out of, is there still things unplugged at that location? Maybe they just forgot to put a relay in or something?
    • Well, this is probably where a wiring diagram and a multimeter come into play.
    • I can say to anyone thats doing this; having done a number of R clusters; just be careful if its an unknown cluster.  It takes a bit of force to pull up; but if it feels excessive then its probably stuck. I've had this and pulled the entire hair spring out; and I can tell you; its not easy getting the correct spring replacement with the correct inner diameter and winding. In my case someone had used some sort of adhesive to stick it to the spindle and it pulled the whole spindle out; which the force seperated the hairspring from the spindal and caused it to deform.  You may have to clean it (IPA); or in my case if i'd known i should have used some sort of solvent on it.  Also check out Cruizin Central on eBay. He does all sorts of dials; and you can email him with any custom designs you want. So if you want like certain logos etc...he'll send you a mock of what it will look like then you accept the order and he'll take care of the rest. Fantastic dials and he can do basically any design you want.
    • Have you confirmed its the actual axles? Also the wheel bearings that mount on the hubs to hold the axles wear out. I replaced mine as they got play in them. It sorted my play issue.
