I can't say I've seen any unregistered cars there, but yeh, cages/stripped sure. Mine and Chris's but two examples...... hope they give you a fair go, if for no other reason that I don't wish to be slapped around by a daily driven Supra on raod rubber! lol
A lowly Supra would not get near the GTSt! Just strip more weight out of it since you cant throw more power at it. :(
haha, trust you Roy :D
Harry's close to me in his Supra, there's only .2 seconds in it :)
I can tell you there's nothing left in mine as it stands now unfortunately. Lakeside is a very high average speed track and my little jigger just lacks in the power stakes. It's pretty awesome on the picks now though and still very quick in early and mid corner (even on these very old 02g's that haven't worn an ounce in 300 track klms). Hopefully I can get everything sorted out for the 21st and see if I can better my best :)
Well done Noel! :(
Roy... not bloody much!
The allowed to do list is short, basically;
Turbo back exhaust.
Fuel system now free.
ECU/boost control free.
Not allowed list is long.
No 'cooler upgrade.
No camor gear change.
No air intake change.
No turbo change.
Nothing internal.
Basically, NA guys can go to town, turbos are limited. And probably rightly so for a more level playing field.
doesn't really worry me if they don't let the 1200 run - i'll just have to get a clown suit and do one of their race meetings instead!
And I wouldn't mind another go in the Supra anyway - I think I can go a bit quicker yet. go a bit harder under the bridge and can work on being very smooth onto the front straight - easy to loose time there on cheapo Federals! maybe there's a tenth or two in hungry and the first half of the carousel as well. and I've got a brand new LHR tyre after Oran Park too - it's just gotta be faster! lol
Time atack at QR this morning and a new sprint pb for the old man. The wheelchair carried me to a string of 58 second lap times with a best of 58.4.
Happy old man. :D:mad:
Geez...Noel no stuffing around with posting that up!! Ha ha congratulations and keep those times coming down :D good to see :D
Happy old man. :):)
kenoath!
huge contrats Noel!
I'm sure there is more left in it with teh straight line power it has!
well done mate.
michael
:) just got off the phone with the QR officials. my Datsun is not going to be allowed at this Lakeside event, it's strictly road cars only, so I'll be back in the Supra for another go!
I'll have to wait till after the resurfacing and do a TopGear race meeting to get the Datsun onto Lakeside aparently. their reasoning is fair enough.
Well done Noel! :)
Turbo back exhaust.
No 'cooler upgrade.
No turbo change.
Nothing internal.
So NA can have a few ccs snuck in? Even so, i am betting an NA RB20 woudl be no bad thing. But the torque of the turbo engine is going to help on road rallies
So the fact that the R32 was released as as R32 GTS25 with an RB25DE doesnt allow you to run that engine. I am sure there are cars out there that have been built up from another spec of vehicle, GTR an dN1 comes to mind. So if you are allowed to go an NA RB25, throw a bucket load of compression, multi throddle bofdies and the thing would sound wild, great throttle response and make more power then you are making at the moment.
Oh, but hand on, do NA engines have the same cam etc restrictions as forced induction?
New Pb for me at Sandown today - 1.21.5 and on a damp track - very happy with the "Mark and Duncan ATTESSA controller" - first time I've really used it in the wet on the track and it works a treat on the "6" setting.
Car Make and Model: 1994 Nissan R32 GTR (N1)
Lap time: 57.55 (QR - Sprint)
Modifications
Power: 298kw
Tyres: 18" : RE55s SR2
Suspension: Apexi N1 professional
Brakes: Alcon 4 pot, 350mm, Ferrodo DS3000 Pads
done a little while back, forgot to add to this thread.
Edited by wrxkilla
    • I get that taking off the head is best but that's a bit much for "just" valve seals. I was just under the impression that one would be able to rotate to TDC and be able to temporarily drop the valve without losing it and effectively having to remove the head to then recover it. I never knew people actually pushed rope into the cylinder to do valve seals hahaha So just to confirm, just going to TDC will not work? In that case I know when I do valve seals I'll maybe just remove the head and do some other things while I'm there, or just wait until I do an engine build.
    • The old approach was to fill the cylinder/chamber with a length of rope pushed in through the sparkplug hole. The new approach is to connect compressed air to the sparkplug hole and fill it with enough pressure to push the valves up. Doing either of these things with the head on and the engine in the car is a lot less pleasant than doing it properly.
    • Can't you put the pistons to TDC and then do the valve seals? Or will the drop down too far to pull them back up?
    • One thing I can tell you is, do it properly the first time. If you encounter unexpected problems just let the car sit for a week or two if you have to get some other parts or figure stuff out.  I'd have said go and use as many OEM parts as possible but since you want to change the turbo later on a custom kit is probably the better choice. Since I have no experience with RB25 just compare parts diagrams and images before buying a line kit and it should be easy to see if it has everything you need. Amayama has very good parts diagrams and part number lists, that is what I used a bunch to figure out what I might need. And don't forget to plan ahead and possibly renew other stuff that's easy to get to while you're in there doing the turbo lines. Happy wrenching
    • Update 4:   Hi all, good news. Engine is running and all the gaskets and seals seem to be working as intended. No leaks so far, even the JB Weld seems to hold. I flushed out the old coolant a few times and put in fresh coolant, not Nissan stuff, I decided to try the Ravenol Protect FL22, they claim it works for a wide variety of JDM cars and the opinions on it by some people were pretty good. And it has the nice poison green color! And man am I glad I bought a coolant system tester earlier this year, vacuum filling works wonders on this engine. I can definitely recommend this to anyone still doing it the old school way. All you need is compressed air supply. Will have to do a small test drive as soon as I can, I removed the gauge cluster again as the tacho needle was still bouncing around a bit but it was much better than before already.  I also found some cracks on all 4 tires inner and outer sidewalls. Apparently these tires should 't be parked on for extended periods or be kept under 0 degrees during storage, which I did not know. Clearly the previous owner didn't look into those details either, he probably bought them just cause they are cool semi-slicks. I'm just wondering how tf I am supposed to reach 30-80 degree tire temperatures on the public road consistenly, these tires were never going to work for my use case. I'll probably order Continental SportContact7 ones as these are the best allround summer tire available right now and I don't think I'll need anything crazier for now. Do let me know if you have experience with various tires and which ones you recommend.
