Update from Winton on the weekend
SAU Nickname: Nurb608
Car Make and Model: Astra VXR
Circuit Name: Winton Long Track
Lap time: 1:45.48
Modifications
Engine: 2lt turbo
Power: 166kwatw
Suspension: Bilstein Shocks, Custom Springs
Tyres: KU36's
Brakes: AP 4 pot
Body weight: 1300kg roughly
SAU Nickname: badhairdave
Car Make and Model: S13 Silvia
Circuit Name: Wakefield
Lap time: 1:07.67
Modifications
Engine: s15 SR20DET, 3071
Power: as run approx 260rwkw @ 1bar
Suspension: front S15 stock struts with camber tops and heavier springs, castor rods, rear old bilstein struts with heavier springs, nismo traction arms and LCA's, d project camber and toe arms.
Tyres: 235/45-17 RE55's MH compound
Brakes: r34 gtt front with Pmu HC+ pads, rear s15 with cheap shit pads
Body weight: Around 1000
natsoft
If you're updated the list please add these in.
SAU Nickname: Russman
Car Make and Model: R32 GTST
Lap time: 1:37.1
Circuit Name: Sandown
Lap time: 1:24.91
Circuit Name: Oran Park
Lap time: 1:24.31 (old setup and AO48s)
Circuit Name: Eastern Creek
Lap time: 1.47.32
Engine: RB20 with PowerFC, HKS 2530 turbo, GTR injectors, intercooler etc...
Power: 225-230rwkw
Suspension: Tein RE's, strut braces and larger rear swaybar.
Tyres: ADVAN AO50's
Brakes: R34 GTT front, R32 GTR rear
Body weight: Standardish with half cage
Updated time for me....
SAU Nickname: Ant97GTR
Car Make and Model: R33 GTR
Lap time: 1:23.8
Engine: RB26 with PowerFC, std turbos (with steel wheels), exhaust
Power: 270-280rwkw
Suspension: Racepace Teins, adj arms (camber/castor/toe)
Tyres: RE55's
Brakes: std with DBA5000 front rotors
SAU Nickname: nfi
Car Make and Model: S15 Silvia
Circuit Name: Wakefield Park
Lap time: 1:06.9
Link to natasoft
http://www.natsoft.com.au/cgi-bin/results..../2010.WAKE.S2.Y
Modifications
Engine: SR20DET
Power: 220rwkw
Tyres: A050 255/40/17
Brakes: r33 gtr brembo
Body weight: full weight, full interior
Edited by nfi
SAU Nickname: ssxRicho
Car Make and Model: R33 GTST
Lap time: 1:38.8
Lap time: 1:26.6
Engine: RB25, PowerFC, standard turbo hyper-gear internals, intercooler, pod, standard inj/fpr and fuel pump
Power: 210rwkw
Suspension: Greddy Type S, strut brace f/r, swaybars, front camber arms
Tyres: 595RSR
Brakes: UAS 324mm spacers with standard calipers and dba5000
Lap time: 1:38.8
Lap time: 1:26.6
Power: 210rwkw
Tyres: 595RSR
Nice times Richo!
I was in my white 34 the same day you did the 38.8(winton). I managed a 1.43.3 in the cars first track outing. I have done 100s of laps around winton on a bike but not in a car. I think my lines are a little different to most(being bike orientated). Would be good to hopefully be put in your class next time and tag on the back to see what lines your taking.
Are you heading over for the Nationals at Mallala in Sept?
Cheers mate, James
SAU nickname:dougmo
Car Make and Model: 1991 s13 silvia
Modifications turbo,cams,pfc,cooler,3" exh
Engine: stock na bottom ended sr20
Power: 220-230kw
Suspension: tanabe
Tyres: toyo ra1 205/55r16
Brakes: front r32 gtst,rear stock
Other: wing on the boot(bootlid all bent from the drag)
Car weight: ???no back seat or inner trims
date: 18/7/2010
Circuit Name:phillip island
Lap time: 1:50.4561
Timing method:natsoft http://www.natsoft.com.au/cgi-bin/results....2010.PHIL.S25.Y
Date: 14/6/2010
Circuit Name: winton
Lap time: 1:38.8560
Timing method:natsoft http://www.natsoft.com.au/cgi-bin/results..../06/2010.WIN.S1
Date: 27/6/2010
Circuit Name: sandown
Lap time: 1:24.6947
Timing method:natsoft http://www.natsoft.com.au/cgi-bin/results....06/2010.SAN.S14
Its tempting, I'm not heading to SA at this stage. But I maybe persuaded :(
You should head to Winton this Saturday with WRX club.
Yeh the old man likes his bikes as well. His lines in the car are somewhat 'abnormal' as well.
Update on the Island
1.51.9
Nice times Richo!
Cheers mate, James
This is from the SAU wakie day, hand timed by a friend.
suspension still set up for drift cause i ran outta time. :(
SAU Nickname: DriftGTS
Car Make and Model: HR31 GTS
Lap time: 1:10.7
Modifications
Engine: RB30DET
Power: 230kw
Suspension: S13 coilovers
Tyres: 215/45/17 & 235/45/17 Federal 595RSRs
Brakes: Standard R32 GTSt with Ferodo DS2500
Body weight: 1150kg (dry)
Lap time: 1:35.337
Natsoft results available (24.07.2010)
Power: 270-280rwkw
Tyres: RE55's
  • 5 weeks later...
Another update....
Circuit Name: Haunted Hills
Lap time: 56.36 (std configuration)
Lap time: 63.64 (Fig8 configuration)
Power: 270-280rwkw
Tyres: Advan A050's
SAU Nickname: evil weevil
Car Make and Model: mx5
Circuit Name: EC
Lap time: 1.59
Engine: 1.8l non turbo
Power: 75rwkw
Suspension: Tein coilovers
Tyres: r888
Brakes: std with RDA rotors and QFM pads
finally cracked 2.00
Date: 15th August, 2010
ns nickname: sublah
SAU Nickname: subliminial
Car Make and Model: 1995 Nissan 200SX
Circuit Name: Mallala
Lap time: 1:23.49
Modifications
Engine: SR20DET
Power: 169rwkw
Suspension: Pedders lowered springs and comfort gas shocks, Whiteline adjustable sway bars, shimmed diff
Tyres: Federal SS-595 245/45/17 all around on 17x8 and 17x9 Super Advan Racing rims
Brakes: RDA slotted discs with Bendix Ultimate pads front, QFM HPX rear with stock discs.
Car weight: ~1240kg (full street trim)
Natsoft link http://www.natsoft.com.au/cgi-bin/results....08/2010.MALL.E5
update here also
Power: 220-230kw
Suspension: tanabe
haunted hills clockwise - 59.15
haunted hills figure 8 - 66.56
Edited by DOUGMO
  • 3 weeks later...
SAU Nickname: isc-performance
Car Make and Model: S14 200sx
Lap time: 1:18.03
Modifications : 2860RS, 1000cc inj, exhaust, fmic, pod, 040 pump.
Engine: sr20det
Power: 244rwkw on E85
Suspension: ISC N1 coilovers, ISC adj camber, toe, castor etc
Tyres: R888
Brakes: R33gtst front/S14 rear
Body weight: 1250kg?
Lap time: 1:26.1
Power: 210rwkw
Tyres: 595RSR
  • 3 weeks later...
Winton today before my wastegate pipe cracked ;)
Power: 220-230kw
Suspension: tanabe
Tyres: used mini cup 215/45R17 slicks
Car weight: 1155kgs dry - no driver
1:35.92
http://www.natsoft.com.au/cgi-bin/results....10/2010.WIN.S11
Edited by DOUGMO
Date: 7/10/10
nickname: Simon-r32
Car Make and Model: Nissan S14
Lap time: 1.18.08
Modifications
Engine: Neo RB25det
Power: 360 rwkw
Suspension: BC ER coilovers
Tyres: Federal RSR fronbts KU36 rears
Brakes: R34 GT t fronts stock S14 rear
Other: tape measure last min wheel alignment, drift car set up and nothing changed.
Car weight: dunno
Photos Link:
top time fastest bottom time cool down lap
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
