Mx5 nugget
Circuit Name: Wakefield
Lap time: 1:13.8 NATSOFT
Modifications
Engine: standard 1.8L nugget
Power: massive 75rwkw
Suspension: tein coilovers
Tyres: r888
Brakes: RDA slotted and QFM pads
Body weight: 1000?
well, a PB is a PB and I'll take it....even if it isnt by much!
1.13.6 now
New PB for me
SAU Nickname: Ant97gtr
Car Make and Model: R33 GTR
Circuit Name: Phillip Island
Lap time: 1:44.47
http://www.natsoft.com.au/cgi-bin/results.cgi?13/11/2011.PHIL.Q1
Engine: Built RB26
Power: 330kw @ Racepace Dyno
Suspension: Racepace Tien RA's with adj arms
Tyres: ADVAN AO50 265/35/18 mediums
Brakes: Stock with DBA5000 front and RDA slotted rear rotors
In car vid on its way
New PB at the last Supersprint round at E.C. on the weekend. Not so many Nissans in attendance but flew the flag anyway.
Results: http://www.natsoft.com.au/cgi-bin/results.cgi?12/11/2011.ARDC.S2
Time: 149.50
Car: R32 GTSt
Engine: Stock RB20DET, HKS 2530, GTR Inj and a big thanks to Dr Drift for fantastic remote tuning from Mel.
Power: Around 220kw
Tyres: Kumho, V70A, 245/17
Suspension: Buddy club race spec coil overs.
Brakes: Stock GTSt, Intima pads.
Weight: 1263kgs.
Drove it to and from the track with no issues.
SAUnickname=dougmo
Circuit Name: phillip island
car:S13
Lap time: 1:49.2613
natsoft: http://www.natsoft.com.au/cgi-bin/results.cgi?13/11/2011.PHIL.Q1
Modifications turbo,cams,pfc,cooler,3" exh
Engine: stock na bottom ended sr20
Power: 220-230kw
Suspension: tanabe
Tyres: toyo ra1 205/55r16
Brakes: front r32 gtst,rear stock
Other: wing on the boot(bootlid all bent from the drag)
Car weight: 1250ish kg with driver
Edited by DOUGMO
SAUnickname=dougmo
Circuit Name: eastern creek
Lap time: 1:37.654
natsoft: http://www.natsoft.com.au/cgi-bin/results.cgi?06/08/2011.EAST.S2.Y
Car model:evo 7 RS
Modifications;inlet man,turbo,cams,cooler,4" exh etc.......
Engine: 2.2 4g63
Power: 370kw
Suspension: tein
Tyres: A050 265/35r18
Brakes:front brembo monoblock, rear stock
Other:some aero
Car weight: 1350ish kg with driver
incar
My link
Edited by DOUGMO
SAUnickname=dougmo
car:S13
Lap time: 1:49.2613
Power: 220-230kw
Suspension: tanabe
LOL, bugger. I did a 1:49.3 on Saturday but sat out Sunday with a gearbox leak. So were you in the black S13?
I just watched your lap side by side with mine and its funny that they are identical everywhere. I thought we could be stronger in differt sections but they seem even evreywhere
My car was 1335 on the PI weighbridge as well so I have some work to do to take some weight out of it :whistling:
SAU Nickname: Mitch_rona
Car Make and Model: R34 GTT
Circuit Name: Wakefield Park
Lap time: 1:09:7
Modifications
Engine: RB30DET
Power: 330rwkw
Suspension: Tein Flex
Tyres: R888
Brakes: Stock w/ DBA4000 & A1RM Pads
Body weight: Stock
Pos 12
http://www.natsoft.com.au/cgi-bin/results.cgi?31/07/2011.WAKE.S2
1:09s is hooking for a standard weight R34, well done!
what size R888's?
and I see old Stretch has the S15 in the 1:05s now
Thanks. It's mostly the grunt that gets me the time lol. Biggest difference was a big front swaybar and nismo diff, cut 2 seconds off my times from those mods.
I am running 235 and 255 front and back on standard 350z 17's. With a slight pump of the rear guards I hope to squeeze a 275 under there maybe on r33 gtr wheels.
  • 4 weeks later...
another PB for me :)
SAU Nickname: DriftGTS
Car Make and Model: HR31 GTS
Lap time: 1:07.449 - Qstarz datalogger
Modifications
Engine: RB30DET
Power: 315kw
Suspension: S13 coilovers
Tyres: 235/45/17 & 255/45/17 Federal FZ201's -awesomely sticky!!
Brakes: Standard R32 GTSt with Ferodo DS2500 (now destroyed :) )
Body weight: 1200kg
SAU Nickname: sycorb
Car Make and Model: r32 gtr
Lap time: 1:04.68 - racelogic datalogger
Modifications
Engine: RB27DETT
Power: 370kw
Suspension: bc coilovers
Tyres: 295/30/18 ao50
Brakes: 356mm ksport with Ferodo DS2500 (now destroyed :) )
Body weight: dont know just took rear seat out
drove to and from the track on the day 16/12/11
  • 1 month later...
SAU Nickname: racegtst
Car Make and Model: 1995 R33 Skyline GTS-T
Circuit Name: Barbagallo Long Circuit
Lap time: 1:07.6895
Modifications
Engine: HKS 2835 turbo, FMIC, nistune
Power: 330 rwhp
Suspension: bilstein coilovers, camber, castor kits, whiteline sway bars, hicas lock bar and pineapples
Tyres: Toyo R888
Brakes: Standard calipers, rda 4000 front discs and QFM race pads front
Body weight: standard
Circuit Name: Collie
Lap time: 52.8611
Modifications
Power: 330 rwhp
Tyres: Toyo R888
Circuit Name: Barbagallo Short Circuit
Lap time: 58.3995
Modifications
Power: 330 rwhp
Tyres: Toyo R888
  • 1 month later...
New PB for me
Circuit Name: Calder
Lap time: 1:02.78
http://www.natsoft.com.au/cgi-bin/results.cgi?24/03/2012.CPR.S19
Engine: Built RB26
