Circuit Name: Wakefield Park
Lap time: 1:10.8
natsoft: Qstarz
Car model: American Legend
Modifications; stock
Engine: 1200cc Yamaha FJ1200
Power: ~100bhp
Suspension: Afco coilovers
Tyres: Hoosier Slicks
Brakes: F= VL Turbo R= VZ Commodore
Other: Winters Quickchange Locker
Car weight: 650kg with driver.
SAU Nickname: ssxRicho
Car Make and Model: '96 R33 GTST
Circuit Name: Calder Park
Lap time: 1:06.33
Modifications
Engine: standard, intercooler, pod, hyper-gear 21U highflow turbo, stock fpr + injectors + afm, gtr pump, pfc, greddy ebc
Power: 210rwkw
Suspension: greddy type s, swaybars, hicas lock, cusco camber arms + upper bushes, cusco solid subframe collars
Tyres: AD08 255/40
Brakes: ksport 330mm front with blue stuff, stocker rears with yellow stuff
Body weight: stock
Aero: BEE*R wing
http://www.natsoft.com.au/cgi-bin/results.cgi?24/03/2012.CPR.S25.Y
Circuit Name: Sandown
Lap time: 1:24.20
Modifications
Power: 210rwkw
Tyres: AD08 255/40
Body weight: stock
Aero: GTR Wing
http://www.natsoft.com.au/cgi-bin/results.cgi?16/10/2011.SAND.P2
SAU Nickname: nfi
Car Make and Model: 2001 Nissan 200sx
Lap time: 1:04.07
Modifications
Engine: Turbo, ex gate, injectors, cams, PFC
Power: 248.8rwkw (just touch up tuned on Saturday with R comps on)
Suspension: Bilstein coilovers, whiteline swaybars, cusco upper arms in the rear and front castor rods
Tyres: Hankook Z221's
Brakes: R33 GTR Brembo's
Body weight: 1150kg
Natsoft: http://www.natsoft.com.au/cgi-bin/results.cgi?25/03/2012.WAKE.S2.Y
In car footage:
Edited by nfi
very sloppy lap for a 1.04 well done!
I know! It was the first session of the day and unfortunately I only got two timed sessions before I broke the master cylinder. I was having issues with snap oversteer on corner exit. We later improved with swaybar and damping but a better time wasn't to be with mechanical issues setting in.
first time i've posted in here, first real track day i suppose...
SAU Nickname: R32gts-t
Car Make and Model: '89 s13 silvia
Circuit Name: Calder Park march 24th
Lap time: 1:07.50
Modifications
Engine: standard, intercooler, factory airbox, hks 2540 turbo, sard 550cc injectors, z32 afm, bosch pump, pfc, avcr ebc, tomei poncams
Power: 224rwkw
Suspension: tein jdm superstreet, gtr swaybar rear, whiteline front, cusco rear camber arms + traction arms, kazama castor rods, ikeya formula tie rods and ends, solid subframe collars, ATS 2 way lsd.
Tyres: re55s 235/255
Brakes: r32gtr front and rear, rb74 pads, rda & dab slotted rotors
Body weight: stock
Aero: no name alloy rear wing
Sau name: SkylinerGTR
Car: r32 GTR
Circuit: Mallala, SA
Time: 1.22.2
Engine: stock, 3" exhaust, nistune ecu, 15 psi boost.
Suspension: king springs bilstein shocks otherwise stock.
Tyres: 255/40/17 toyo r1r
Brakes: stock
36 degree heat plenty left in it only did about 10 hard laps and only taking it just over 7000 rpm
SAU Nickname: Kylieyeah
Car Make and Model: 1999 Honda S2000
Lap time: 1:12.6
Modifications
Engine: Stock w/ intake, headers, exhaust
Power: About 140kw atw (stock)
Suspension: Bilstein PSS9
Tyres: Dunlop Direzza Z1 Star Specs street tyres
Brakes: Stock
Body weight: 1250kg
Could anyone please let me know the average or "fast" time for a stock GTR R34 around Wakefield Park please?
  • 1 month later...
New time for Winton. Very happy with it.
E85 made a massive different. So much mid range power increase! Pulled like a train!
Now running 295 Advans. These ones were 2nd hand and only cost me $50 each!
Date: 11/06/2012
Car Make and Model: R32 GTSt
Circuit Name: Winton
Lap time: 1:31.29
Timing method: Natsoft
http://www.natsoft.c.../06/2012.WIN.S1
Modifications
Engine: RB25 with PowerFC, Garret GTX3076 turbo, lots more stuff.
Power: 325rwkw on E85
Suspension: Tein RS's, R33 LCA's, Adj susp arms, strut braces and whiteline swaybars
Tyres: ADVAN AO50 295/30/18 softs
Brakes: 256mm G4's front, rear standard
Body weight: 1280kg's without driver.
  • Like 1
  • 3 weeks later...
