For the last week or so it's been struggling to crank over, Sounded like a flat battery so I put the trickle charger on it on xmas eve and it started no problems.
mid week it started to struggle again, worked fine NYE and then finally went to start it yesterday and it has gotten to a point where it it cranked but struggled just like a flat battery would and wouldn't start.
Put the trickle on it again, also tried a jump starter pack and now it wont even produce the click that even a flat battery would normally do. Put a multimetre on it and its reading a consistent 12.4V even when trying to turn it over. The lights, indicators, radio and air con work as normal but now there be nothing when trying to start it..
all the normal lights come on when the acc is turned on but when trying to start the cat light comes on. but I'm not 100% if this normally flashes when trying start..
The light between the oil and battery on the right of the rev counter.
http://s688.photobucket.com/user/Brendonams/media/333518_358441544171960_100000183534541_1688374_1179138731_o.jpg.html
The battery is a little over 12 months old
The starter motor was replaced with a 34 neo one about 2 years ago
any possible avenues anyone suggest to explore?
cheers!
https://www.sau.com.au/forums/topic/461998-33-gts-t-starting-issue/
Do you have access to another battery to try? Just to rule that out. I had a similar experience years ago on an old Mazda that ended up being a starter motor fault. I kept throwing bigger batteries at it until truck batteries wouldn't turn it over anymore. Starter was drawing too much power.
  • Like 1
I had a similar issue with mine when I had no license. Week by week it got harder to start until one day fresh off the charger it wouldn't crank the car over at all. I believe one or more of the cells were failing.
Like the others said test with another battery and replace if necessary
  • Like 1
Get your battery tested at any battery world or autoelec shop. They will be able to do a load test and tell you if its OK.
Clean terminals and install new or reinstall.
Check your earth strap to chassis and then check earth strap to the motor. Easy way to check is to use a jumper lead and go from the chassis to the motor - make sure they are both good solid connections with no insulators like gaskets etc. The lifting ring or exhaust mani is good .
Check your leads to the starter motor, undo and clean then redo. If you cannot here any sound from the starter then its the solenoid not throwing out. If you here a click/clunk then the solenoid is fine and your starter motor is probably toast.
  • Like 1
    • Hey all, not sure how active SAU is anymore but will ask away anyways. Just wanted to get some experience on the 2008 model GTR CBA model.  I've hit that age in my life (43) where I'm like fk it time to get my dream (midlife crisis) car. Looking at importing one in and seeing if these can be reliable if the main flaws are fixed up. Plan is to keep money aside to do the following straight off the bat to future proof it: * install a stage 1 rebuilt trans with all new bits and pieces.  * install a new Bellhousing from the later model GTRs. Or potentially an upgraded stronger version like MAD or ATR. Besides the above two things and typical maintenance items anything else you'd recommend doing.   Been speaking to a few people and the engine on these are very reliable apparently. But keen on the view of the community here. Hoping to find a nice grade 4.5 with low mileage in Grey. I'd go black but swirls too easy. Look forward to your responses and feedback. Cheers
    • Do Alan and Keith work on Skylines now? I remember buying stuff from them when I owned my Ralliart Lancer a few moons ago. Definitely genuine guys and be excellent if they dealt with the skyline platform as well.
    • Hey all, I'm Gaston from Sydney's West.  I was a member on here when I was a younger lad and owned a mint R33 GTS-T. Ended up selling it and getting married having kids (yadda yadda) we all know how the story goes. Now I'm back with the intention to get my midlife crisis (dream) car ... a R35 GTR.  You'll see me about asking questions and searching the forums. Good to be back and can't wait to get back an Import again.
    • I have to put something here in order to post the photos. From what I could gather there's more enthusiasm for modified cars now than there has been for years. There were probably more younger people there than older (me included lol) which was a good sign.  It did seem like the record least amount of representation of the 90's era hero cars on display though. Like maybe one or two examples of S-chassis Nissans, and maybe 3 or 4 R-chassis. By comparison there were a lot of Civics from that era but in all there were about 10 - 12 EG/EK Civic Type R.  Euro exotics are always there in large numbers, led by Liberty Walk...... say what you will about kids using markers to scribble on a Ferrari F40, it did seem like a stunt to infuriate Ferrari enthusiasts, or Ferrari itself. I wonder if there's something more to it. Either way LBWK have done some heinous things to a Lamborghini Miura this time. They should stop now.
    • Engines and drivelines are not war stoppers for me mate, busted arse bodies and un-obtainium parts and panels are though Both cheap Brumbies I looked at had trashed tubs and a fair bit of rust
