I'm parting out an R32 GTST race car. I've got a few other parts let me know if you need anything else.
1) R32 bolt in six point roll cage, built by Independent Race Cars. CAMS compliant $700
2) R32 stainless steel exhaust, 2.5 inch with "cat" custom made $300
3) R32 Turbosmart Kompact BOV, new $100
4) R32 GTR wheels x 6 reasonable condition a few chips but no rash $500 for the grey set of 4 $250 for the green set of 2 No tyres
5) 205/55/16 RE55 semi slicks x 6 $70 each 75-80% tread
6) TFN brand R33 GTR rotors slotted, brand new $120
7) R32 HICAS lock bar $40
8) Cobra Imola S race seats x2 good condition and very comfortable $650
Blitz SE return flow cooler, pipes, clamps and joiners $300
Heaps of Tilton, Quatermaster and AP racing clutches in 26 spline, PM if you are interested.
Direct clutch twin plate (200mm) to suit SR20 with flywheel. Newly serviced with new drive plates $1000
Motec UTC $100
Motec to R32 patch loom $200
RB20 and S1 RB25 yellow jacket coils $150
R32 GK-Tech cooling plate $20
R32 GTR front calipers and near new slotted RDA rotors $250
Edited by Komdotkom
ill take cooling plate if your will to post at my cost on top of asking price?
i am after radiator shroud, stock or lowed springs with or with out shocks,and a stock steering.
Edited by mr turbo
  • 1 month later...
    • Get a timing light on it and verify it's sparking reliably at a sane ignition timing. Use a COP extension lead to be 100% sure about timing instead of hoping that the timing loop on the back of the engine is accurate. Make sure it's actually injecting fuel. MAF is not used on the stock ECUs for initial cranking.
    • RE5R01A is the transmission. Didn't realize they had a 5 speed for the NA cars but for some reason the turbo engines stuck to 4 speeds. Looks like the solenoid block is still available from Nissan directly at a somewhat reasonable price: 31940-60X01 https://www.amayama.com/en/genuine-catalogs/epc/nissan-japan/skyline/er33/6568-rb25de/trans/317 I would move sooner on this than later. The moment the de minimis exception for Japan goes away expect to be paying 25% tariffs even for stuff like this.
    • Only RB26 are low from factory. And even then the ECU actually want high impedance, because it's essentially the same ECU as the RB20 anyway, and thus they have a f**king resistor pack!
    • Is this preventable by priming the system with external oil pressure? I've seen the speed academy folks hook up an external oil priming system to the oil pressure sensor port with an air compressor to check for oil leaks before putting an engine back in a car. Something like this: https://www.jegs.com/i/JEGS/555/23550/10002/-1?gPromoCode=SPRINGINTOSPEED_APR25_5Off&gQT=1
